Old 06-02-2012, 03:39 AM   #1
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
FR-S / BRZ Wheel Directory, Gallery and Fitment Guide Chart
Mods/Admin DIY Update Topic: http://www.ft86club.com/forums/showthread.php?t=80971
EVERY SINGLE new topic that is posted in this forum area is reviewed. If a new wheel combo
is posted then I will add it to the directory when I do my next updates, every 2-3 weeks.
If you posted a new topic about a wheel that is already in the directory, in that particular
size, width and offset, then I will combine your topic with the preexisting topic.
THIS TOPIC IS NOW BEING UPDATED BY
@CSG Mike
DO NOT PM US FOR FITMENT INFO! USE:
http://www.ft86club.com/forums/showthread.php?t=15007
TIPS ON USING THE WHEEL DIRECTORY
1. Control-F is your friend. That allows you to find a particular size. Every wheel spec is
listed consistently, so if you want to find an example of 18x8.0 +40 then type that into
your browser's FIND box and you will toggle through every wheel that is listed in that size.
2. Use the offset charts, for front and rear wheels. To see examples of a wheel in a particular
size just match the wheel size/width on the left column with the offset numbers in the top row.
STICKY IMPORTANT LINKS
Wheel 101
Fitment Calculator
Wheel Weights
FT86 Wheel Weight Topic
M3post.com Wheel Weight Topic
measurespeed.com
wheelweights.net
Winter Tire Reviews
OTHER IMPORTANT LINKS
Meaty Tire Thread
Fuji Online Shopping Simulator
Tire Rack Simulator
Tire Size Calculator (miata.net)
Wheel/Tire Size Comparer Light (rimsntires.com)
Wheel Offset Calculator (1010tires.com)
WillTheyFit.com
Want to play with some tire sizes on an app just for the 86?
http://www.frsproject.com/tire_size.php
Do you need an expert to assist you with your fitment Qs?
Want more information on the stock wheels and tires?
http://www.ft86club.com/forums/showp...39&postcount=3
Want more information on the tire pressure sensor system?
http://www.ft86club.com/forums/showthread.php?t=5970
You can only have one TPMS set programmed at one time:
http://www.ft86club.com/forums/showthread.php?t=19221
Want to find a replica brand of a more expensive wheel?
http://www.ft86club.com/forums/showthread.php?t=63497
Want to see how much work is required to maintain this topic?
http://www.ft86club.com/forums/showthread.php?t=41248
Need a good laugh? Do 18" wheels fit on an 86?
http://www.ft86club.com/forums/showthread.php?t=62118
Flush Wheel Offset Chart
Code:
WHEEL   |-- STOCK HEIGHT --|  |-- LOWERED 1" --|
WIDTH      FRONT     REAR       FRONT     REAR
7.0         +25       +18        +23       +13
7.5         +31       +24        +29       +19
8.0         +38       +31        +36       +26
8.5         +44       +37        +42       +32
9.0         +50       +43        +48       +38
9.5         +57       +50        +55       +45
10.0                  +56                  +51
WHEN LOWERED 1" YOU WILL NEED TO REDUCE THE FRONT OFFSET
BY 2MM AND THE REAR OFFSET BY 5MM FOR PERFECT FLUSHNESS
 (FLUSH = TOP OF WHEEL FLUSH WITH TOP CENTER OF WHEEL OPENING)
DECREASING THE OFFSET NUMBER PUSHES THE WHEELS OUT AND
INCREASING THE OFFSET SUCKS THE WHEELS IN.
Code:
Average Wheel Weights by @coyote
I've listed what I'd consider to be average weights.
Anything under or over these ranges would be light
and heavy, respectively.
16x7 14-18lb
16x8 15-19lb
17x7 16-20lb
17x8 17-21lb
17x9 18-22lb
18x7 18-22lb
18x8 19-23lb
18x9 20-24lb
19x & 20x... Who cares, they are all heavy.
Color-Coded Badges
You can quickly scroll to wheels you are interested in by looking for
the following color-coded badges shown underneath each selection.
Wheel Size
Wheel Style
*updated Nov 6, 2018*
New fitment calculator link
The Following 526 Users Say Thank You to DarrenDriven For This Useful Post:
03Z33 (03-12-2013), 2015firestormFRS (05-07-2015), 20valvewynn83 (03-18-2013), 2much (11-05-2013), 350zgoingFRS_lol (05-04-2014), 5hairpins (07-14-2012), 86 Dreams (09-16-2013), 86 South Africa (10-30-2015), 86BRZ (01-09-2013), 86drift (07-22-2012), 86X86 (07-15-2012), 8987846 (02-08-2013), @Art_Mighty (04-30-2013), Acree (11-30-2012), Adrian002 (05-30-2015), ahausheer (07-14-2012), AirborneDeth (12-17-2013), AjaxKing (03-02-2017), akahenry (09-14-2013), Akuma-ZN6 (02-12-2018), Alabang 86 (12-14-2012), Alan (01-02-2013), alexand3r (12-23-2014), alexisfire02 (06-11-2014), AlexTheGreek (10-06-2013), Alienate (03-16-2014), Allankh (10-02-2012), Altorhys (01-31-2015), Ammunition (01-14-2014), Anaxilus (07-30-2013), Anduz (11-04-2012), armythug (11-20-2012), Ash (04-17-2013), Asphalt TG (03-02-2014), Asphalt~86 (02-09-2013), ATL BRZ (12-11-2013), AtlasMick (01-22-2014), atomicalex (03-20-2019), AUmarvin (05-06-2016), ayilar (08-14-2014), azian_advanced (07-14-2012), BabyPubes (06-26-2013), banane63 (12-07-2013), BatStig (04-04-2014), bear89103 (06-20-2013), Bg8780 (07-17-2012), bhbnuckle (04-01-2016), BigJyoungblood (08-26-2012), Billy2224 (07-15-2012), BLACK->BULLET (06-06-2015), BlaineWasHere (11-19-2013), blanco (03-12-2013), BlUURZ (02-03-2015), Boba_kz (06-15-2014), BolognaWalrus (07-06-2014), Bonburner (07-26-2012), Bowen (03-08-2016), Brandar (05-31-2015), brandonblt2 (10-10-2014), Brently (08-12-2013), Brett (07-30-2013), brewloc (08-07-2021), Brody602 (08-02-2013), brybot (04-01-2020), BRZ21 (11-25-2013), BRZ? (11-21-2013), Brzce (12-31-2012), BRZranger (08-02-2012), bugsie (08-08-2013), Bunsin (04-02-2019), burningjello (02-17-2017), buzznasa (01-13-2013), BWilky (12-09-2015), CallmeDave (05-27-2015), Calum (01-10-2013), Camotec (07-30-2012), Capt Canuck (07-28-2012), CaptainSlow (10-14-2012), CatDaddysBBQ (05-17-2014), cdo221 (03-23-2013), Cesium Rainbow (06-17-2015), Chad11491 (05-10-2015), chanomatik (09-11-2012), Chazzzy (08-30-2016), Cheddar (07-26-2012), Chee-Hu (06-14-2013), Chewie4299 (04-08-2013), Choco (01-21-2015), chrisp1992 (03-23-2014), civicdrivr (06-16-2012), clickfiveZ (03-21-2013), CLTBRZ (07-02-2012), clzzical (08-11-2013), CockpitCruiser (11-04-2021), Coheed (11-22-2012), Cope (05-20-2015), Cotnoir (06-18-2012), craigpitts7 (08-13-2014), CrazyWookiee (05-28-2013), crimespree (08-04-2012), CrispyCheddar (02-22-2015), CSkap21 (02-20-2019), cwpbrz-ji (10-31-2015), CxG (04-19-2016), d1ck (07-16-2013), Dadhawk (11-12-2014), DarkSunrise (06-19-2014), DatDudeLoso (02-07-2013), DeanStevenson (04-01-2014), demonpoofball (09-19-2014), denkigrve (07-12-2012), dennis.s.s (07-26-2013), derpz86 (04-04-2016), diBreezy (02-02-2015), digital_assassin (07-24-2012), diirk (09-21-2012), diss7 (07-19-2013), djdnz (08-08-2012), djfuller (12-26-2012), dnjshin0bi (07-11-2012), DocWalt (09-21-2015), Dominus (12-12-2014), DoomsdayJesus (04-17-2015), dori. (08-06-2012), Dr Evil (07-30-2014), Dr.Science (12-01-2013), Draco-REX (08-19-2012), Draco_PR23 (07-17-2013), Drebin252 (04-03-2014), drewbot (03-19-2014), DriftEightSix (08-26-2012), DriveDriftDogfight86 (10-04-2025), dsrttigr (10-05-2013), dubbrand (08-21-2014), Dustin2JZ (07-20-2013), DylanFRS (05-07-2013), D_Thissen (11-13-2016), Efferalgan (05-24-2013), egraphic (09-06-2012), ElijahF (04-27-2020), enderw88 (07-21-2019), Enlight (06-25-2013), Entropy (08-02-2012), epitaph (07-15-2012), Ericfrs (08-19-2012), ericmpena (09-24-2013), Error (05-07-2015), ESBjiujitsu (06-02-2012), exequtor1987 (01-15-2013), F1point4 (08-20-2012), F3dzo (07-13-2012), FA5 (01-31-2013), Fast_Freddy (07-11-2013), faz1 (07-25-2012), FearBoy (03-19-2014), fender9530 (10-22-2012), fenton (08-28-2012), fer3d (03-02-2019), feyrerm (08-22-2012), Fish Eagle (05-22-2013), flippy (08-29-2013), Floggin Tires (08-21-2012), Flow (04-05-2013), Fly Guy (06-02-2012), Foobar (11-14-2012), FR-S_Tacoma (10-11-2012), FrancoFRS (08-23-2013), Freedom (10-09-2014), freerunner (05-10-2016), FRSFirestorm (12-29-2012), FRSPhil (03-12-2015), FRS_FIEND (06-05-2014), frumplejoon (07-07-2014), fstlane (07-07-2013), ft86Fan (07-12-2012), FT86Z (06-06-2018), ftc~brz (01-16-2014), FTEIGHTSIX (07-08-2012), FT_86_SM_GP (09-10-2014), FUN BRZ (05-27-2015), Funktional (04-30-2014), Future (07-12-2012), FutureFT86 (01-15-2013), fx35s (01-26-2014), GaN-MaN (04-24-2013), Ganthrithor (09-10-2018), Giccin (07-15-2012), GinDo (07-14-2012), giraffee (07-29-2012), Gixxersixxerman (01-17-2013), gkubed (02-05-2019), Goldensun89 (02-01-2016), GotBRZ1691 (09-10-2014), GregV (01-08-2013), Griever423 (10-30-2015), Gshoxx (08-08-2012), gt8613 (11-06-2013), GT86_PRAGUE (09-15-2015), gtengr (12-06-2016), GTHachiRoku (07-16-2013), GuerillaRacing (11-12-2012), Guff (09-09-2012), Guillaume (08-16-2012), Gums (11-15-2014), guslucatero (02-28-2014), Gusto (03-25-2013), Hachiroku (07-14-2012), hankster (08-04-2012), Hawk77FT (05-29-2014), Hazard (03-30-2015), helloimgil (07-17-2012), Here2rock (11-09-2015), Hook (02-14-2013), HotLavaFRS (09-09-2015), HotLeopardMama (04-01-2013), HotRodPA (12-25-2014), humanshield (12-27-2013), hur1ey02 (01-13-2014), Hydaral (01-01-2015), HyperTech (04-19-2014), iBRZ (11-11-2012), idreamofdrifting (03-21-2013), Imti (07-15-2012), iRep8OH8 (02-19-2014), j2digit (05-05-2013), jabbathewhat (03-26-2014), JackSmiley (02-28-2013), Jacob G. (02-19-2013), JARunning (03-06-2015), Jason@DSG (05-16-2014), JasonCDC (12-20-2012), Jay2420 (10-14-2013), JD001 (07-25-2021), Jdmjunkie (02-02-2021), jdubious (07-14-2014), jedibow (09-23-2012), Jeff-RS (06-07-2015), JEFFSTYLE (01-06-2014), JellyForSale (05-18-2015), Jesse (01-11-2013), JiB (07-14-2012), jkamelo (12-30-2020), jliongh (10-14-2019), JMx86 (12-10-2013), JoeBoxer (07-14-2012), JoeHK (08-25-2014), Jolt182 (04-27-2015), jonnyozero3 (02-24-2013), JonnyRocket (10-29-2012), jordydiaz (07-19-2012), Josue Cafe FR-S (05-12-2017), jstans84 (09-03-2012), Juzzotec (08-05-2018), jwbrocloud (02-12-2014), Kabong (02-10-2017), Kakawate (11-29-2013), karma003 (07-15-2013), kaybee123 (03-06-2014), Keenercarguy (06-04-2016), kendalldwhite (03-24-2014), Kevstra (02-16-2014), KGFRS86 (08-06-2015), kidgogeta (07-16-2012), Killerbee (11-20-2012), Kimsey47 (05-10-2013), Kiske (12-03-2014), Kosmos (06-23-2013), Kris86 (10-12-2018), kwood9000 (10-01-2012), lazyluka (01-29-2014), LeeMaster (02-10-2013), leicaboss (01-06-2014), Lemar58 (03-25-2014), LetsGo (05-08-2013), levifig (04-03-2015), LivingLegend (07-25-2012), llawd (11-14-2017), Lonewolf (07-14-2012), lonewolfworks (06-23-2018), loogs (07-07-2014), Lost (10-05-2012), LostSalad (07-05-2015), lucchesi423 (07-16-2012), LXXXV1 (09-05-2014), M4TT (11-26-2012), MadFRS (03-19-2013), Mageep (07-14-2012), Mandy (11-28-2014), Mango22 (03-02-2013), MannyO (08-24-2012), Maowc (05-30-2014), MarkRacerX (07-06-2012), MattR (06-04-2012), Maverickgear (09-08-2014), mboory (09-25-2013), mechaghost (07-13-2012), Mehrshad (05-07-2018), melon (07-31-2013), Metabrz (06-02-2012), meWant (01-02-2013), MF_DEUCE (09-07-2012), Michael Blue (05-28-2014), MidnightRunner (08-05-2014), mid_life_crisis (09-12-2013), MiguelAE86 (08-16-2012), Mild2Wild (07-31-2012), Milotic (04-13-2016), Mim (11-05-2015), miodculae (07-25-2012), MisterSheep (12-04-2016), Mitch (07-12-2012), MJones_RB (07-30-2015), mkiisupra (03-27-2014), ML (11-12-2012), MmmHamSandwich (04-18-2013), Mo707 (11-03-2012), Mo7ammed (11-27-2016), MoarGeesPlease (07-14-2012), Mooseknuckle44 (06-18-2014), Mr. (04-30-2013), mrha (08-19-2012), MTCRX (09-09-2013), Mulder (12-12-2013), mwjcyber (08-19-2013), n2oinferno (10-15-2012), Nambo (07-12-2012), Nasty Sausage (04-08-2014), NickFRS (04-04-2014), Nikuku (04-20-2013), NLS8520 (07-31-2015), normancw (09-21-2012), Norville Rogers (08-18-2016), NoVtec (06-04-2012), NRGBalanced (09-18-2012), nubbster927 (02-11-2013), NWFRS (12-03-2013), nzer (10-28-2013), Ooops (09-10-2013), os86 (09-03-2012), ovm_catalyst (01-05-2015), P86RAVES (03-12-2015), Palmy (07-14-2012), ParangWala (08-15-2012), Pascal_TTH (02-15-2013), pauland (05-23-2013), Paulo86 (01-29-2017), pcuerpo (09-24-2013), PerCompLLC (02-23-2023), Pete (02-15-2013), Pete156 (12-08-2012), PHLonomenal (08-02-2014), phm14 (06-24-2013), pinoy_dorifto (06-03-2013), pinski (10-01-2014), pmccut (05-07-2013), polarstorm (04-15-2013), poormans_LFA (08-27-2012), Prava (06-20-2012), PrDarkKnight (01-11-2016), prettyslowbrz (07-18-2018), Pseud0logik (05-21-2014), pszuvela (02-12-2014), punchdrunkjuice (07-13-2012), pyro530 (08-21-2012), R2RO (08-17-2012), r4m3n (12-18-2012), racecaresuaceb (11-14-2012), RaceR (06-03-2012), Rai-zero (11-05-2018), Rakshaa (05-10-2016), RallySport Direct (11-28-2012), random0 (02-04-2014), raul (09-25-2012), Ray@Carsmo (09-30-2012), Rayme (06-19-2014), raytrix (12-10-2013), redKnight (02-02-2013), Reflex (07-30-2012), RehabJeff86 (05-30-2013), Reign (10-17-2014), rene0023 (03-26-2014), Ris (04-08-2014), riyal (04-29-2013), Rulin (05-07-2015), ruskymx (08-25-2013), russv (08-17-2012), rusty959 (06-19-2013), RWD_only (07-16-2012), Rybot (12-25-2015), RyleyMA61 (11-29-2012), RYU (09-07-2012), S2kphile (08-22-2012), sajonf (10-31-2012), Sandman3zb (09-05-2012), Satanasso (09-30-2013), sato (03-03-2019), SciOnDrifTtSlIdeR (09-08-2013), ScionFR-J (06-12-2013), Scooby (07-15-2012), Scooby South (01-01-2013), sdiver68 (07-26-2012), sergiomordo (10-08-2015), Seth Hawkins (11-20-2015), sftateofmind (01-26-2015), shaunsweeney (02-15-2014), Shedd22 (07-18-2014), ShoGun (02-24-2013), ShoNUFF (01-07-2013), ShutterSpeed (01-02-2014), Sideways? (01-21-2014), Sigh-on-Rice (09-14-2012), SikCee (07-08-2014), SILENT (05-14-2013), SirBrass (11-12-2013), sirus (07-02-2012), sittinSideways (11-20-2014), sklimo (03-25-2013), Slade (09-15-2015), Slartibartfast (08-27-2012), Slipstream (02-19-2014), SloS14 (06-05-2013), Slysdexia (11-07-2014), Snoopyalien24 (07-02-2012), SoCal909 (12-10-2013), softgrip (11-13-2016), soros151 (10-21-2012), soundman98 (09-22-2013), Spacemane969 (04-28-2016), Spartarus (06-08-2015), spdfreak (06-23-2014), Spec C Wannabe (01-04-2018), SpeedR (09-24-2012), spookyz (12-26-2013), Staf00 (08-27-2013), Starscream15 (07-26-2012), Stevo22 (07-29-2013), Stewie (02-07-2015), stranger things (06-09-2017), stratodyne (06-20-2013), Sugi (02-05-2015), SuperGTS (09-30-2013), Superhatch (09-15-2012), SuperSatinBrz (06-26-2013), SurfAndSand (09-10-2013), surfuxalot (06-18-2015), Surok (11-25-2012), SVThis (10-31-2012), SVTSHC (08-09-2012), SWAMechFRS (06-19-2013), swarb (05-11-2015), sweeney208 (01-30-2013), Takumidesh (10-03-2021), taosracer (07-01-2012), Teclis (05-08-2015), Teseo (08-14-2015), Thatguyjeremy (02-04-2015), The Robot Cow (01-25-2014), thealtaholic (02-01-2015), TheSt|G (10-06-2012), TheVoiceOfReason (01-10-2015), TheWatchman (07-31-2013), The_Societan (08-22-2013), Those Meddling Kids (08-26-2012), Thrilled (01-16-2017), TJ3000 (05-02-2014), TM (06-17-2015), tnle (08-27-2014), tonylop33 (07-30-2013), Toyota GT 86 (01-28-2013), toysub (07-23-2013), TOZER (07-27-2013), travace (09-03-2012), trigger happy (10-06-2015), Tristor (02-21-2018), trvth (07-12-2018), ts87 (07-21-2013), tuckdaddy (11-27-2012), Turbowned (07-14-2012), TuxedoCartman (07-31-2012), twitism (11-13-2012), Tye300 (10-11-2013), Tylub (02-25-2014), Tyrant (04-21-2015), ultra (06-02-2012), unvevo (04-10-2014), Username (09-06-2012), usptwins (08-27-2012), Verge (09-03-2012), Vulcan (08-29-2016), Wasabi (02-09-2013), Wayno (10-03-2014), WazzuGrad (10-12-2014), whataboutbob (08-08-2012), wheeladdict (07-10-2012), wheelhaus (01-23-2014), white devil (09-29-2013), WhiteFRS69 (07-09-2014), WhiteLightning (03-23-2014), white_knight (03-30-2013), WillBRZ (11-12-2013), Wise (08-24-2016), WithNolock (06-24-2012), Wolfdogelite (03-06-2015), wparsons (03-12-2015), WRB-DZA-BRZ (06-27-2012), WryGuy (01-03-2017), wulfstan (04-15-2017), Wyllliam (04-21-2014), xFury (10-27-2015), Xiijuwa (10-17-2015), xpicer (09-05-2012), xxthrillxx (05-12-2013), Yardjass (11-14-2016), yaser.salameh (01-30-2015), YinYang1980 (07-16-2012), ysu (06-16-2016), Yuck (09-28-2012), Zaku (08-23-2014), zAnSh1n (07-15-2012), Zed (06-03-2016), ZeHeadBanger (03-26-2014), ZetaPerformance (09-22-2012), zex (10-08-2012), zkubidu (10-22-2012), zohare (07-02-2013), zoomzoomers (06-22-2012)
Old 06-03-2012, 01:52 PM   #2
DarrenDriven
NW Region Moderator
Front Wheel Size/Offset Chart
= link to perfect flush @ stock height
= link to perfect flush @ lowered 1"
= link to topic with proven fitment
= link to topic with proven problem
= predicted to have a problem
Code:
        <---- MORE POKE                                MORE SUCK ---->
        06 12 14 18 21 22 23 25 29 30 31 32 33 34 35 36 37 38 39 40 42 43 44 45 46 47 48 49 50 51 53 55
15x6.0
15x6.5
16x6.5
16x7.0
16x7.5
16x8.0
16x8.5
17x7.0
17x7.5
17x8.0
17x8.5
17x9.0
17x9.5
17x10.0
18x7.5
18x8.0
18x8.5
18x9.0
18x9.5
18x10.0
18x10.5
19x8.0
19x8.5
19x9.0
19x9.5
19x10.0
19x10.5
The Following 91 Users Say Thank You to DarrenDriven For This Useful Post:
8R6 (02-28-2014), 93cc (02-26-2014), Akuma-ZN6 (02-12-2018), Alabang 86 (06-26-2013), Ammunition (07-26-2014), ATL BRZ (12-11-2013), AtlasMick (01-22-2014), AZOOZ_95 (06-16-2013), BlaineWasHere (11-19-2013), Bonburner (12-26-2012), brybot (07-30-2020), BRZ86_ (04-14-2015), br_z1Lch (05-04-2014), Bunsin (04-02-2019), CaptainSlow (10-14-2012), chjno86 (08-23-2013), Choco (01-21-2015), CxG (04-19-2016), derpz86 (04-04-2016), djdnz (07-27-2012), DownFracture (05-30-2013), Dr.Science (12-01-2013), drewbot (03-19-2014), dubbrand (08-21-2014), epitaph (07-15-2012), Esoteric (07-15-2012), flippy (08-29-2013), Freedom (09-08-2015), FRSPhil (03-11-2015), fstlane (07-16-2013), FUN BRZ (05-27-2015), Fussy08X (08-21-2012), Ganthrithor (09-10-2018), Goldensun89 (02-01-2016), GTHachiRoku (07-16-2013), Gums (07-15-2012), guslucatero (03-04-2014), Hazard (03-30-2015), humanshield (12-27-2013), ihaskrayon (09-10-2012), Imti (07-15-2012), JAS4 (10-04-2020), JD001 (07-25-2021), Jdmjunkie (02-02-2021), jkamelo (12-30-2020), JMx86 (12-10-2013), LostSalad (07-05-2015), lupindub (05-15-2016), LXXXV1 (09-05-2014), matsayswhat (08-15-2012), MmmHamSandwich (08-10-2013), Mooseknuckle44 (06-18-2014), Mr. (04-30-2013), mwjcyber (08-31-2014), NickFRS (04-04-2014), NRGBalanced (09-18-2012), onabulletride (01-03-2014), P86RAVES (03-12-2015), Paulo86 (01-29-2017), pcuerpo (10-07-2013), phm14 (02-12-2016), R2RO (08-25-2012), RaceR (06-03-2012), raul (06-05-2013), Rybot (01-19-2016), sato (03-03-2019), sdiver68 (12-30-2012), ShutterSpeed (01-02-2014), Sigh-on-Rice (09-14-2012), SILENT (05-14-2013), SirBrass (11-12-2013), sirus (07-14-2012), SOCON (07-05-2021), soundman98 (09-22-2013), Staf00 (08-27-2013), StarsGarrador (08-26-2012), Sugi (02-05-2015), SuperGTS (09-30-2013), Surok (09-21-2012), Thaeyo (12-31-2017), tripjammer (07-15-2012), Username (09-06-2012), VoiD (01-30-2013), Vracer111 (01-16-2013), whataboutbob (12-21-2013), Wolfking (11-08-2012), WRB-DZA-BRZ (08-31-2012), Xiijuwa (01-09-2016), Yamaha_R6 (06-24-2014), YinYang1980 (07-16-2012), ysu (06-16-2016)
Old 06-04-2012, 02:43 AM   #3
DarrenDriven
NW Region Moderator
Rear Wheel Size/Offset Chart
Code:
        06 13 16 17 18 19 22 24 25 26 30 31 32 33 34 35 36 37 38 39 40 42 43 44 45 46 47 48 49 50 51 53 55 56
15x6.0
15x6.5
16x6.5
16x7.0
16x7.5
16x8.0
16x8.5
16x9.0
16x9.5
17x7.0
17x7.5
17x8.0
17x8.5
17x9.0
17x9.5
17x10.0
18x7.5
18x8.0
18x8.5
18x9.0
18x9.5
18x10.0
18x10.5
18x11.0
19x8.0
19x8.5
19x9.0
19x9.5
19x10.0
19x10.5
The Following 60 Users Say Thank You to DarrenDriven For This Useful Post:
ATL BRZ (12-11-2013), azian_advanced (07-14-2012), BAE (07-17-2012), banane63 (12-22-2013), bhbnuckle (04-01-2016), BigFatFlip (07-15-2012), Bonburner (12-26-2012), brybot (07-30-2020), BRZ86_ (04-14-2015), Bunsin (04-02-2019), Choco (01-21-2015), Deepseadiver (07-31-2015), derpz86 (04-04-2016), djdnz (07-23-2012), DownFracture (05-30-2013), Dr.Science (12-01-2013), dubbrand (08-21-2014), epitaph (07-15-2012), flippy (08-29-2013), FRSPhil (03-11-2015), FUN BRZ (05-27-2015), Goldensun89 (02-01-2016), GTHachiRoku (07-16-2013), helloimgil (07-23-2012), ihaskrayon (09-10-2012), Imti (07-15-2012), JD001 (07-25-2021), jkamelo (12-30-2020), JMx86 (12-10-2013), LostSalad (07-05-2015), LXXXV1 (09-05-2014), MarkMash (09-03-2012), MmmHamSandwich (08-10-2013), mwjcyber (08-31-2014), NickFRS (04-04-2014), NoVtec (08-09-2012), onabulletride (01-03-2014), Paulo86 (01-29-2017), raul (04-18-2014), Rybot (01-19-2016), Sigh-on-Rice (09-14-2012), SirBrass (11-12-2013), sirus (07-14-2012), sobrz (02-20-2017), soundman98 (09-22-2013), spookyz (12-26-2013), Staf00 (08-27-2013), SuperGTS (09-30-2013), Teseo (08-14-2015), track_warrior (07-25-2012), Turbowned (07-14-2012), twitism (08-15-2012), Username (09-06-2012), VoiD (01-30-2013), whataboutbob (04-11-2018), Wolfking (11-08-2012), WRB-DZA-BRZ (08-31-2012), Xiijuwa (01-09-2016), xpicer (09-05-2012), Yamaha_R6 (06-24-2014)
Old 06-04-2012, 01:41 PM   #4
DarrenDriven
NW Region Moderator
2Crave________________________
2Crave MACH-4 19x8.5 +??/19x9.5 +??
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 1/1/13 / MFG LINK
2Crave MACH-9 17x7.5 +45
WEIGHT UNKNOWN / ADDED 11/24/13 / MFG LINK
3SDM____________________________
3SDM 0.01 18x8.5 +35/18x9.5 +35
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 12/2/13 / MFG LINK
3SDM 0.06 18x9.5 +35
5Zigen________________________
5Zigen FN01R-C 17x7.0 +35
5Zigen FN01R-C 17x8.0 +35
~16 LBS / ADDED 7/8/13 / MFG LINK
5Zigen FN01R-C 18x8.0 +48
WEIGHT UNKNOWN / ADDED 11/12/12 / MFG LINK
5Zigen Inperio Sports RS1 18x8.0 +45 / 18x9.0 +45
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 7/5/12 / MFG LINK
A-Line____________________________
A-Line 029 GT 17x7.5 +35
WEIGHT UNKNOWN / ADDED 7/8/13 / MFG LINK
Ace___________________________
Ace V12 18x8.5 +38
WEIGHT UNKNOWN / ADDED 7/31/12 / MFG LINK
ADV1___________________________
ADV ADV5.01 19x8.5 +?? / 19x10.5 +??
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 7/8/13 / MFG LINK
Advan_________________________
Advan GT 18x9.5 +40
Advan Kreutzer VI 18x7.5 +50
WEIGHT UNKNOWN / ADDED 7/30/12
Advan RC II 17x8.5 +43
16.5 LBS / ADDED 10/1/12
Advan RC II 18x?.? +??
WEIGHT UNKNOWN / ADDED 8/20/12
Advan RG II 17x8.0 +37
Advan RG II 17x8.0 +45
WEIGHT UNKNOWN / ADDED 7/27/12 / MFG LINK
Advan RG III 18x9.5 +45
17.6 LBS / ADDED 1/26/14 / MFG LINK
Advan RG-D 18x8.0 +45
WEIGHT UNKNOWN / ADDED 5/2/12 / MFG LINK
Advan RG-D 18x8.5 +33
WEIGHT UNKNOWN / ADDED 5/9/14 / MFG LINK
Advan RG-D 18x8.5 +33 / 18x9.5 +40
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 3/12/13 / MFG LINK
Advan RG-D 18x9.5 +40
Advan RS 17x7.5 +48
WEIGHT UNKNOWN / ADDED 3/18/13 / MFG LINK
Advan RS 17x8.0 +45
WEIGHT UNKNOWN / ADDED 5/14/14 / MFG LINK
Advan RS 18x8.0 +45
17.0 LBS / ADDED 6/30/12 / MFG LINK
Advan RS II 18x8.5 +35 / 18x8.5 +42
17.5 LBS / 18.3 LBS / ADDED 2/28/13
Advan RS II 18x8.5 +35 / 18x9.5 +42
17.5 LBS / WEIGHT UNKNOWN / ADDED 7/8/13
Advan RS II 18x9.5 +42
Advan Super Advan Racing v2 18x?? +??
Advan TC II 17x8.5 +45
Advan TC III 18x9.5 +40
Advanti Racing_________________
Avanti Racing Vigoroso M993 17x?.? +48
WEIGHT UNKNOWN / ADDED 8/15/12
ASA Wheels____________________
ASA JS5 17x7.5 +40
ASGA Wheels___________________
ASGA Spirit 18x8.0 +40
21 LBS / ADDED 2/28/13
Autec__________________
Autec Zenit 17x7.0 +40
Avant Garde__________________
Avant Garde F150 18x8.5 +32 / 18x9.5 +39
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 6/25/13
Avant Garde M220 18x9.0 +30
WEIGHT UNKNOWN / ADDED 1/20/14 / MFG LINK
Avant Garde M310 18x9.0 +30
WEIGHT UNKNOWN / ADDED 8/15/12 / MFG LINK
Avarus____________________________
Avarus AV8 18x8.0 +48
Axis__________________________
Axis OG-SAN 17x9.0 +32
Axis X-Factor 18x8.5 +45
WEIGHT UNKNOWN / ADDED 2/28/13
Axis Xcite 17x7.5 +45
Axis Xplode 18x8.0 +45
~20 LBS / ADDED 3/14/14
Bavaria________________________
Bavaria BC-5 Concave 20x8.5 +??
WEIGHT UNKNOWN / ADDED 1/2/13 / MFG LINK
BBS___________________________
BBS CF 17x7.5 +35
BBS CH 18x8.5 +30
BBS CH-R 18x8.0 +38
WEIGHT UNKNOWN / ADDED 6/5/12 / MFG LINK
BBS RI-D 005 19x8.5 +43
BBS LM 18x8.0 +50
BBS LM 19x8.5 +25
WEIGHT UNKNOWN / ADDED 7/28/12
BBS LM090 17x7.5 +48
BBS RC 18x7.5 +38
WEIGHT UNKNOWN / ADDED 10/26/12
BBS RE 18x8.0 +50
WEIGHT UNKNOWN / ADDED 5/25/13 / MFG URL
BBS RF 17x7.5 +48
WEIGHT UNKNOWN / ADDED 6/7/12
BBS RG-R 18x7.5 +49
WEIGHT UNKNOWN / ADDED 8/19/12
BBS RG-R 18x8.5 +35
BBS RG345 17x7.0 +48
WEIGHT UNKNOWN / ADDED 9/1/12
BBS RK 17x7.0 +48
16.2 LBS / ADDED 6/19/12
BBS RS 17x10.0 +22
WEIGHT UNKNOWN / ADDED 2/24/14
BBS RS 18x8.5 +35 / 18x9.5 +35
BBS RS-GT 18x8.0 +40
BBS SR 18x8.0 +48
BC Forged_____________________
BC Forged HB-05 19x8.5 +?? / 19x9.0 +??
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 7/9/13 / MFG LINK
BC Forged HB-05 19x8.5 +45 / 19x9.5 +40
BC Forged TM-08 19x8.5 +35 / 19x9.0 +45
Bee*R________________________
Bee*R B5 18x?? +?? / 18x?? +??
Black Racing___________________
Black Racing Pro N1 17x8.0 +38
20.5 LBS / ADDED 6/22/12
Blitz__________________________
Blitz BRW Profile 08 18x8.0 +45 / 18x8.0 +38
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 8/27/12 / MFG LINK
Bremmer Kraft___________________
Bremmer Kraft BR10 18x8.0 +45
Bremmer Kraft BR10 18x8.0 +45 / 18x9.0 +42
Bremmer Kraft BR10 18x9.0 +42
Bridgestone___________________
Bridgestone BEO ar.S-03 18x8.0 +49
WEIGHT UNKNOWN / ADDED 9/5/12
Brock_________________________
Brock B30 18x8.0 +45
WEIGHT UNKNOWN / ADDED 9/12/12 / MFG LINK
Buddy Club____________________
Buddy Club P1 Racing 17x7.0 +48
Buddy Club P1 Racing 17x7.5 +50
WEIGHT UNKNOWN / ADDED 8/19/12 / MFG LINK
Buddy Club P1 Racing 18x8.5 +40
20.5 LBS / ADDED 7/10/13 / MFG LINK
CCW_________________________
CCW Classic 16x8.5 +14 / 16x9.5 +16
CCW Classic 18x9.5 +33 / 18x10.0 +38
~20 LBS / ~20 LBS / ADDED 7/9/13 / MFG LINK
Cor___________________________
Cor Cipher 19x8.5 +?? / 19x10.5 +??
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 8/31/12 / MFG LINK
Cosmis___________________________
Cosmis MRII 18x8.5 +22
Cosmis XT-005R 18x9.0 +25
CST___________________________
CST Zero-1 Hyper 18x8.0 +43
D-Force__________________________
D-Force 5 17x9.0 +??
Desmond_______________________
Desmond Regamaster Evo 17x8.0 +35
WEIGHT UNKNOWN / ADDED 11/15/13
Desmond Regamaster Evo 17x8.0 +35/17x9.0 +38
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 12/30/13
Desmond Regamaster MP 17x8.0 +35
WEIGHT UNKNOWN / ADDED 3/17/14
Doall__________________________
Doall Algernon Fenice TT1 19x7.5 +50 / 19x8.0 +45
WEIGHT UNKNOWN / ADDED 9/1/12 / MFG LINK
DPE___________________________
DPE R08 Variant S 19x?.? +?? / 19x?.? +??
Drag__________________________
Drag DR-9 17x7.0 +40
(Volk Racing CE28 Replica)
Drag DR-9 17x8.0 +47
Drag DR-19 17x7.5 +45
WEIGHT UNKNOWN / ADDED 7/24/12 / MFG LINK
Drag DR-31 17x8.0 +47
(Work Emotion CR Kai Replica)
WEIGHT UNKNOWN / ADDED 10/28/12 / MFG LINK
Drag DR-31 18x8.0 +35 / 18x9.0 +38
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 9/19/12 / MFG LINK
Drag DR-34 17x7.5 +45
WEIGHT UNKNOWN / ADDED 9/17/12 / MFG LINK
Drag DR-38 17x7.0 +40
18.6 LBS / ADDED 8/28/12
Drag DR-38 17x8.0 +??/17x9.0 +??
Drag DR-38 17x9.0 +38
Drag DR-50 17x7.0 +40
18.1 LBS / ADDED 7/26/12
end of section 1 A-D wd1
The Following 22 Users Say Thank You to DarrenDriven For This Useful Post:
20valvewynn83 (09-11-2012), Bonburner (12-26-2012), BRZebra (01-10-2015), CaptainSlow (08-26-2013), Choco (01-21-2015), DieselDog (07-01-2015), ihaskrayon (09-10-2012), Maowc (05-30-2014), MmmHamSandwich (08-10-2013), Mr. (04-30-2013), mwjcyber (08-31-2014), nix (11-17-2012), onabulletride (01-03-2014), ShoNUFF (01-10-2013), Sigh-on-Rice (09-14-2012), sirus (09-02-2012), soundman98 (09-22-2013), Staf00 (08-27-2013), Username (09-06-2012), VoiD (01-30-2013), whataboutbob (04-11-2018), Yamaha_R6 (02-03-2014)
Old 06-04-2012, 02:59 PM   #5
DarrenDriven
NW Region Moderator
Effect_________________________
Effect Sengen 17x7.5 +40
18.4 LBS / ADDED 8/16/12
Enkei__________________________
Enkei 5S05RR 18x8.5 +42
Enkei Compe 16x8.0 +25
WEIGHT UNKNOWN / ADDED 3/14/13 / MFG LINK
Enkei ES-Tarmac 16x7.0 +45
Enkei EV5 17x7.0 +38
~18.0 LBS / ADDED 11/12/12 / MFG LINK
Enkei EV5 18x7.5 +38
Enkei FLC-01 17x7.0 +40
Enkei Fujin 17x7.5 +40
WEIGHT UNKNOWN / ADDED 9/20/12 / MFG LINK
Enkei Fujin 18x8.0 +40
Enkei GP5 17x8.0 +45
24.4 LBS / ADDED 7/9/13 / MFG LINK
Enkei GTC01 17x7.5 +48
17.8 LBS / ADDED 7/31/12 / MFG LINK
Enkei GTC01 18x8.0 +35
WEIGHT UNKNOWN / ADDED 8/29/12 / MFG LINK
Enkei GTC01 18x8.0 +48
Enkei Klamp 18x7.5 +45
Enkei Kojin 17x8.0 +40
Enkei Kojin 17x8.0 +45
Enkei Kojin 17x9.0 +45
Enkei Kojin 18x8.5 +45 / 18x9.5 +45
Enkei Kojin 18x9.5 +45
Enkei NT03+M 17x7.5 +35
17.9 LBS / ADDED 5/9/14 / MFG LINK
Enkei NT03+M 18x8.0 +35
WEIGHT UNKNOWN / ADDED 9/8/12 / MFG LINK
Enkei NT03+M 18x9.5 +40
WEIGHT UNKNOWN / ADDED 1/4/13 / MFG LINK
Enkei PF01 17x7.5 +38
WEIGHT UNKNOWN / ADDED 1/7/13 / MFG LINK
Enkei PF01 17x8.0 +45
17.3 LBS / ADDED 8/16/12 / MFG LINK
Enkei PF01 18x7.5 +38
17.5 LBS / ADDED 6/15/12 / MFG LINK
Enkei PF01 18x7.5 +45
Enkei Raijin 18x8.0 +40 / 18x9.5 +45
Enkei Raijin 18x8.0 +45
WEIGHT UNKNOWN / ADDED 6/21/12 / MFG LINK
Enkei Raijin 18x8.5 +45
21.2 LBS / ADDED 11/12/12 / MFG LINK
Enkei Raijin 18x8.5 +45 / 18x9.5 +45
21.2 LBS / WEIGHT UNKNOWN / ADDED 11/12/12 / MFG LINK
Enkei Raijin 18x9.5 +45
Enkei RC-T4 18x8.5 +48
WEIGHT UNKNOWN / ADDED 9/27/12 / MFG LINK
Enkei RP03 17x8.0 +48
17.9 LBS / ADDED 5/25/13 / MFG LINK
Enkei RP03 18x9.5 +38
WEIGHT UNKNOWN / ADDED 3/17/14 / MFG LINK
Enkei RPF1 17x7.0 +42
Enkei RPF1 17x7.5 +48
WEIGHT UNKNOWN / ADDED 11/15/13 / MFG LINK
Enkei RPF1 17x8.0 +35
Enkei RPF1 17x8.0 +45
16.1 LBS / ADDED 6/30/12 / MFG LINK
Enkei RPF1 17x9.0 +35
WEIGHT UNKNOWN / ADDED 8/21/12 / MFG LINK
Enkei RPF1 17x9.0 +45
Enkei RPF1 18x9.5 +38
WEIGHT UNKNOWN / ADDED 10/29/12 / MFG LINK
Enkei RPF1 Type II 17x7.0 +48
16.2 LBS / ADDED 9/17/12 / MFG LINK
Enkei RS+M 17x8.0 +35
Enkei RS-7 17x7.0 +35
Enkei RS05 18x7.5 +50
19.5 LBS / ADDED 7/28/12 / MFG LINK
Enkei RS05RR 18x8.5 +42
WEIGHT UNKNOWN / ADDED 10/1/12 / MFG LINK
Enkei RS05RR 18x8.5 +42/18x9.5 +43
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 2/3/14 / MFG LINK
Enkei RS05RR 18x9.5 +43
Enkei RSF5 18x8.0 +45
Enkei RSM9 18x7.5 +48
Enkei RSM9 17x8.0 +48
Enkei RSM9 19x7.5 +48
Enkei T6S 18x8.0 +45
Enkei Tenjin 18x8.0 +45/18x9.5 +45
Enkei Tenjin 18x8.5 +45/18x9.5 +45
Enkei TSP6 17x8.0 +45 / 17x9.0 +45
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 5/9/14 / MFG LINK
Enkei WTE II 17x7.0 +41
Enkei ZR1 18x8.0 +35
ESM___________________________
ESM 004 17x9.0 +38
(BBS LSM Replica)
WEIGHT UNKNOWN / ADDED 3/13/13 / MFG LINK
ESM 004 18x8.0 +35 / 18x9.0 +38
(BBS LSM Replica)
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 8/15/12 / MFG LINK
ESM 004 18x8.0 +40
(BBS LSM Replica)
WEIGHT UNKNOWN / ADDED 6/4/12 / MFG LINK
ESM 004 18x9.0 +38
(BBS LSM Replica)
WEIGHT UNKNOWN / ADDED 10/18/12 / MFG LINK
ESM 004 19x8.5 +32 / 19x9.5 +38
(BBS LSM Replica)
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 9/24/12 / MFG LINK
Exel___________________________
Exel Ennio 18x8.0 +35
WEIGHT UNKNOWN / ADDED 7/1/12
Fast________________________
Fast Hayaku 17x9.0 +35
WEIGHT UNKNOWN / ADDED 7/10/13 MFG LINK
Fast Hayaku 18x9.0 +35
Fifteen52____________________
Fifteen52 RSL Tarmac 18x8.5 +38
WEIGHT UNKNOWN / ADDED 12/2/13 MFG LINK
Five:AD by Five Axis____________
Five:AD R5:F 19x8.5 +45 / 19x9.5 +35
WEIGHT UNKNOWN / ADDED 9/3/12 MFG LINK
Five:AD S5:F 19x8.5 +45? / 19x9.5 +45
WEIGHT UNKNOWN / ADDED 9/12/12 MFG LINK
Five:AD S7:F 19x8.5 +45
WEIGHT UNKNOWN / ADDED 8/15/12 MFG LINK
Five:AD X5:F 19x8.5 +40
WEIGHT UNKNOWN / ADDED 11/24/13 MFG LINK
Forgeline______________________
Forgeline GA1R 19x9.0 +45/19x10 +47
Forgestar______________________
Forgestar CF5 18x8.5 +42 / 18x9.5 +45
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 7/10/13 / MFG LINK
Forgestar CF5 19x8.5 +42 / 19x9.5 +35
Forgestar CF5V 19x8.5 +?? / 19x9.5 +??
19.8 LBS / WEIGHT UNKNOWN / ADDED 11/24/13
Forgestar F14 17x8.5 +38
16.2 LBS / ADDED 3/18/13 / MFG LINK
Forgestar F14 18x8.5 +38 / 18x9.5 +38
WEIGHT UNKNOWN / 19.2 LBS / ADDED 2/24/14 / MFG LINK
Forgestar F14 18x9.5 +38
19.2 LBS / ADDED 7/8/13 / MFG LINK
Forgestar F14 18x9.5 +40
19.2 LBS / ADDED 5/9/14 / MFG LINK
Forgestar F14 19x8.5 +35 / 19x9.5 +38
Forgestar F14F 17x8.5 +38
WEIGHT UNKNOWN / ADDED 12/30/13 / MFG LINK
Forgestar F14F 17x9.5 +38
Gram Lights (Rays)_____________
Gram Lights 57C6 18x9.5 +25 / 18x9.5 +12
Gram Lights 57C6 18x9.5 +40
WEIGHT UNKNOWN / ADDED 11/14/13 / MFG LINK
Gram Lights 57DR 17x9.0 +35
20.2 LBS / ADDED 9/15/12 / MFG LINK
Gram Lights 57DR 17x9.0 +38
20.2 LBS / ADDED 3/13/13 / MFG LINK
Gram Lights 57DR 18x8.5 +38
Gram Lights 57DR 18x9.5 +38
Gram Lights 57FXX 18x8.0 +45
20.3 LBS / ADDED 3/17/14 / MFG LINK
Gram Lights 57FXX 18x8.5 +45
~21 LBS / ADDED 3/17/14 / MFG LINK
Gram Lights 57FXX 18x9.5 +38
Gram Lights 57Gainer 17x7.0 +42
Gram Lights 57Getter 19x8.5 +35
WEIGHT UNKNOWN / ADDED 2/24/14 / MFG LINK
Gram Lights 57Xtreme 17x7.0 +42
Gram Lights 57Xtreme 17x9.0 +40
Gram Lights 57Xtreme 18x7.5 +40
WEIGHT UNKNOWN / ADDED 9/5/12 / MFG LINK
Gram Lights 57Xtreme 18x8.5 +33 / 18x9.5 +40
20.4 LBS / 20.6 LBS / ADDED 10/7/12 / MFG LINK
Gram Lights 57Xtreme 18x8.5 +45 / 18x9.5 +40
WEIGHT UNKNOWN / 20.6 LBS/ ADDED 12/30/13 / MFG LINK
Gram Lights 57Xtreme 18x9.5 +40
~22 LBS / ADDED 1/7/13 / MFG LINK
Gram Lights 57Xtreme 19x8.5 +33 / 19x9.5 +43
~21 LBS / ~22 LBS / ADDED 8/20/12 / MFG LINK
Gram Lights 57Xtreme 19x8.5 +43 / 19x9.5 +45
~21 LBS / ~22 LBS / ADDED 11/24/13 / MFG LINK
Gram Lights 57Xtreme 19x8.5 +45 / 19x9.5 +45
~21 LBS / ~22 LBS / ADDED 7/27/12 / MFG LINK
Gram Lights 57Xtreme 19x9.5 +43
~22 LBS / ADDED 7/8/13 / MFG LINK
Gram Lights 57Maximum 18x8.5 +45
WEIGHT UNKNOWN / ADDED 6/30/12 / MFG LINK
Gram Lights 57Ultimate 18x7.5 +??
Gram Lights 57Ultimate SC Spec 17x8.0 +45
end of section 1 E-G wd2
The Following 12 Users Say Thank You to DarrenDriven For This Useful Post:
CaptainSlow (08-26-2013), Choco (01-21-2015), chrisp1992 (03-23-2014), dubbrand (08-21-2014), Guff (09-30-2013), MmmHamSandwich (08-10-2013), mwjcyber (08-31-2014), onabulletride (01-03-2014), spookyz (12-26-2013), Staf00 (08-27-2013), whataboutbob (04-11-2018), Yamaha_R6 (02-03-2014)
Old 06-05-2012, 01:46 AM   #6
DarrenDriven
NW Region Moderator
Hayashi____________________________
Hayashi New Street STL 17x7.5 +35
HD Tuning____________________________
HD Tuning Gear 18x7.5 +35 / 18x9.0 +40
HRE____________________________
HRE 540 19x8.5 +?? / 19x9.5 +??
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 1/7/13
HRE C106 18x9.0 +35
HRE Flowform FF01 19x8.5 +30 / 19x9.5 +43
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 3/18/13 / MFG LINK
iForged__________________________
IForged Retro 18x9.5 +50
Ings__________________________
Ings TS06 18x8.5 +43
WEIGHT UNKNOWN / ADDED 7/8/12 / MFG LINK
ISS Forged____________________
ISS Forged Blonix M/8 19x9.0 +?? / 19x10.5 +??
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 8/3/12 / MFG LINK
Kingpin____________________
Kingpin KP 307 18x8.0 +35 / 18x9.0 +35
(BBS CH Replica)
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 5/14/14 / MFG LINK
Klutch_________________________
Klutch SL5 18x8.5 +35 / 18x9.5 +30
Klutch SL5 18x8.5 +35 / 18x9.5 +42
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 12/30/13 / MFG LINK
Klutch SL14 18x8.5 +35 / 18x9.5 +30
Klutch SL14 18x8.5 +38 / 18x9.5 +42
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 7/27/12 / MFG LINK
Konig_________________________
Konig Daylight 17x7.0 +40
14.6 LBS / ADDED 7/24/12 / MFG LINK
Konig Feather 17x7.5 +45
18.1 LBS / ADDED 7/24/12 / MFG LINK
Konig Forward 16x7.0 +40
Konig Zero-In 17x7.0 +40
17.9 LBS / ADDED 8/27/12 / MFG LINK
Kosei__________________________
Kosei K4R 17x8.0 +36
15.8 LBS / ADDED 6/21/12
Linea Corse________________________
Linea Corse LC818 19x8.5 +38
Linea Corse Lemans 18x8.5 +40 / 18x9.5 +40
(BBS LM Replica)
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 3/14/13
Mach V________________________
Mach V Awesome 17x9.0 +42
16.8 LBS / ADDED 3/12/13 / MFG LINK
Mach V Awesome 17x9.0 +42 / 18x9.5 +42
16.8 LBS / WEIGHT UNKNOWN / ADDED 3/12/13 / MFG LINK
Mach V Wicked Awesome 18x9.5 +42
19.0 LBS / ADDED 3/12/13 / MFG LINK
MB____________________________
MB Octane 17x7.5 +40
Mille Miglia__________________________
Mille Miglia EVO-R 19x8.5 +35
Miro__________________________
Miro 111 18x8.5 +35 / 18x9.5 +40
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 10/7/12 / MFG LINK
Miro 112 18x8.5 +35/18x9.5 +40
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 2/24/14 / MFG LINK
Miro STP1 18x10.0 +25
Momo_________________________
Momo Tuner 18x8.0 +38
Motegi________________________
Motegi DP6 18x7.5 +35
Motegi MR116 16x7.0 +40
WEIGHT UNKNOWN / ADDED 10/31/12 / MFG LINK
Motegi MR116 18x8.0 +35/18x9.0 +35
Motegi MR121 17x7.0 +48
17.0 LBS / ADDED 6/15/12 / MFG LINK
Motegi MR125 17x7.5 +42
16.3 LBS / ADDED 6/30/12 / MFG LINK
Motegi MR125 18x8.0 +?? / 18x9.5 +??
Motegi MR221 Traklite 1.0 16x7.0 +40
12.0 LBS / ADDED 7/10/13 / MFG LINK
Motegi MR221 Traklite 1.0 16x7.0 +50
12.0 LBS / ADDED 7/24/12 / MFG LINK
Motegi MR221 Traklite 1.0 17x7.0 +42
14.0 LBS / ADDED 6/9/12 / MFG LINK
Motegi MR274 7 SP10 18x8.0 +40
18.6 LBS / ADDED 7/8/13 / MFG LINK
MM6__________________________
MM6 Mesh 18x8.5 +38 / 18x9.5 +40
MSR__________________________
MSR Style 042 20x7.5 +40
MSR Style 045 18x8.0 +35
MSW__________________________
MSW Style 14 16x7.0 +38
Neuspeed______________________
Neuspeed RS10 18x8.0 +35
17.8 LBS / ADDED 10/2/12
Neuspeed RS10 19x8.0 +35
19.0 LBS / ADDED 1/7/13
Niche_________________________
Niche NR6 18x8.0 +40
WEIGHT UNKNOWN / ADDED 7/11/12 / MFG LINK
OE Wheels__________________________
OE Wheels RS4 17x7.5 +35
(OEM Audi RS4 Replica)
WEIGHT UNKNOWN / ADDED 2/28/13 / MFG LINK
OEM BRZ/FR-S/86________________
OEM BRZ/FR-S/86 17x7.0 +48
(PAINTED BLACK)
20.1 LBS / ADDED 7/5/12
(PAINTED GOLD/BRONZE)
20.1 LBS / ADDED 10/26/12
(PAINTED SILVER/GRAY)
20.1 LBS / ADDED 7/10/13
(PAINTED WHITE)
OEM Subaru BRZ (JDM STi Version) 17x7.5 +48
18.4 LBS / ADDED 7/1/12 / MFG LINK
OEM Subaru BRZ (JDM STi Version) 18x7.5 +48
WEIGHT UNKNOWN / ADDED 9/13/12 / MFG LINK
OEM Toyota 86 (JDM Modellista Wing Dancer II) 18x7.5 +46
OEM Toyota 86 (JDM RC Version) 16x6.5 +48
15.9 LBS / ADDED 5/30/12
OEM AUDI_________________________
OEM Audi TT (2000-2006) 17x7.5 +32
OEM NISSAN_________________________
OEM Nissan GT-R (4x Fronts) 20x9.5 +45
~22 LBS / ADDED 7/10/13
OEM Nissan Skyline R33 17x9.0 +30
OEM PORSCHE_________________________
OEM Porsche 911 (Twist Style) 18x10 +15 / 18x11 +25
OEM TOYOTA________________
OEM Scion tC 17x7.0 +45
OEM SAAB__________________
OEM Saab 9-2X Aero (2006) 17x7.0 +55
OEM SUBARU________________
OEM Subaru Forester Sport XT (2008) 17x7.0 +48
OEM Subaru Forester STi 16x6.5 +48
OEM Subaru Forester STi (2005) 18x7.5 +48
OEM Subaru Forester XT (2004-2006) 16x6.5 +48
OEM Subaru Impreza 2.5RS (1998-1999) 16x7.0 +53
16.5 LBS / ADDED 2/3/14
OEM Subaru Impreza STi (2004) 17x7.5 +53
~15 LBS / ADDED 7/10/13
OEM Subaru Impreza STi (JDM 2001) 17x7.5 +53
OEM Subaru Impreza WRX (2002) 16x6.5 +53
WEIGHT UNKNOWN / ADDED 2/3/13
OEM Subaru Impreza WRX (2012) 17x8.0 +53
WEIGHT UNKNOWN / ADDED 6/6/12
OEM Subaru Legacy GT (1997-2004) 16x6.5 +55
20 LBS / ADDED 1/26/14
OEM Subaru Legacy GT (2005-2007) 17x7.0 +55
OEM Subaru Legacy Spec B 18x7.0 +55
OEM Subaru Legacy STi S402 18x8.0 +53
OEM Subaru Option BBS 17x7.0 +53
WEIGHT UNKNOWN / ADDED 6/14/12
OEM VW___________________
OEM VW AVUS 15x6.0 +38
WEIGHT UNKNOWN / ADDED 10/11/12
OEM VW Corrado (BBS RSM) 17x8.0 +35
OEM VW Jetta GLi (BBS RC) 18x7.5 +38
OZ____________________________
OZ Alleggerita HLT 17x7.5 +48
15.1 LBS / ADDED 6/27/12 / MFG LINK
OZ Alleggerita HLT 17x8.0 +48
OZ Alleggerita HLT 18x7.5 +48
16.9 LBS / ADDED 2/24/14 / MFG LINK
OZ Alleggerita HLT 18x8 +48
WEIGHT UNKNOWN / ADDED 7/10/12 / MFG LINK
OZ Formula HLT 17x7.5 +35
OZ Formula HLT 17x8.0 +48 / 17x9.0 +42
OZ Formula HLT 18x7.5 +48
OZ Leggera 18x8.0 +45
18.3 LBS / ADDED 5/14/14 / MFG LINK
OZ Superleggera 17x7.0 +48
OZ Superleggera 18x8.0 +35
OZ Superleggera 18x8.0 +51
WEIGHT UNKNOWN / ADDED 9/2/12
OZ Superturismo 17x7.5 +48
OZ Ultraleggera 17x8.0 +35
17.8 LBS / ADDED 5/14/14 / MFG LINK
OZ Ultraleggera 17x8.0 +48
17.8 LBS / ADDED 6/27/12 / MFG LINK
OZ Ultraleggera 18x8.0 +48
18.6 LBS / ADDED 7/15/12 / MFG LINK
Phat Fux______________________
Phat Fux Ballzy 18x9.0 +35
(WedsSport TC105N Replica)
PIAA__________________________
PIAA Eco Premium S-12 17x7.0 +42
Privat__________________________
Privat Akzent 18x9.5 +30
Privat Kup 18x9.5 +30
ProDrive______________________
ProDrive GC-05F 18x8.0 +46
ProDrive GC-07J 17x7.5 +48
WEIGHT UNKNOWN / ADDED 7/28/12 / MFG LINK
ProDrive GC-07J 18x8.5 +45
ProDrive GC-010E 18x7.5 +48
ProDrive GC-012L 18x8.0 +45
ProDrive GC-012L 18x8.5 +48
WEIGHT UNKNOWN / ADDED 7/3/12 / MFG LINK
ProDrive GC-012L 20x8.5 +50
ProDrive GC-014i 18x?.? +??
ProDrive GT1 18x7.5 +48
Pur Design____________________
Pur Design 4our 19x?.? +?? / 19x?.? +??
Quantum 44____________________
Quantum 44 S1 18x8.0 +37 / 18x9.0 +40
end of section 2 H-Q wd3
Choco (01-21-2015), chrisp1992 (03-23-2014), dubbrand (08-21-2014), MmmHamSandwich (08-10-2013), mwjcyber (08-31-2014), onabulletride (01-03-2014), spookyz (12-26-2013), SStratos (01-19-2014), Staf00 (08-27-2013), SUB-ZERO (03-02-2014), whataboutbob (04-11-2018), Yamaha_R6 (02-03-2014)
Old 06-06-2012, 02:39 AM   #7
DarrenDriven
NW Region Moderator
Racing Hart____________________
Racing Hart CP-035 16x7.0 +45
11.0 LBS / ADDED 5/14/14
Racing Hart CP-035 17x7.5 +48
Racing Hart CP-F 18x8.5 +45
Racing Hart RS-721 18x8.0 +43
WEIGHT UNKNOWN / ADDED 8/7/12
Raderwerks__________________
Raderwerks M-TEN80 18x8.0 +35 / 18x9.0 +35
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 1/4/13 / MFG LINK
Rays Homura__________________
Rays Homura 2X86GT 18x8.0 +36
Rohana________________________
Rohana RC10 19x8.5 +35 / 19x9.5 +40
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 3/17/14 / MFG LINK
Rota__________________________
Rota D-Force 18x8.5 +44 / 18x9.5 +40
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 3/14/13 / MFG LINK
Rota D-Force 18x8.5 +48
WEIGHT UNKNOWN / ADDED 7/9/12 / MFG LINK
Rota D-Force 18x8.5 +48 / 18x9.5 +40
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 10/26/12 / MFG LINK
Rota DPT 17x9.0 +35
Rota DPT 17x9.0 +42
WEIGHT UNKNOWN / ADDED 6/3/12
Rota DPT 18x8.5 +44
Rota G-Force 18x8.5 +48 / 18x9.0 +35
(Advan RS Replica)
Rota G-Force 18x9.0 +35
(Advan RS Replica)
WEIGHT UNKNOWN / ADDED 9/2/12 / MFG LINK
Rota G-Force 18x10.0 +35
(Advan RS Replica)
WEIGHT UNKNOWN / ADDED 8/6/12 / MFG LINK
Rota GR-A 18x7.5 +48
Rota Grid 17x8.0 +38
(Volk Racing TE37 Replica)
Rota Grid 17x9.0 +42
Rota Grid 18x8.5 +44
21 LBS / ADDED 12/3/13 / MFG LINK
Rota Grid 18x8.5 +44 / 18x9.5 +38
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 7/1/12 / MFG LINK
Rota Grid 18x9.5 +38
Rota IK-R 18x9.5 +38
Rota MXR 18x8.5 +44/18x9.5 +38
Rota MXR 18x9.5 +38
Rota PWR 18x9.5 +35
Rota RKR 18x8.5 +38 / 18x9.5 +38
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 12/3/13 / MFG LINK
Rota RKR 18x8.5 +44 / 18x9.5 +44
Rota RT5 17x9.0 +30
Rota RT5 18x8.5 +44 / 18x9.5 +44
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 3/13/13 / MFG LINK
Rota RT5 18x9.5 +38
Rota SS10 18x8.5 +45 / 18x9.5 +42
(Volk Racing ZE40 Replica)
20.4 LBS / WEIGHT UNKNOWN / ADDED 5/14/14
Rota T2R 18x9.5 +38
WEIGHT UNKNOWN / ADDED 10/4/12
Rota Titan 17x8.0 +42
~17 LBS / ADDED 5/14/14 / MFG LINK
Rota Titan 17x8.0 +45
~17 LBS / ADDED 1/2/13 / MFG LINK
Rota Titan 17x9.0 +45
17.8 LBS / ADDED 2/3/14 / MFG LINK
Rota Torque 17x7.5 +48
(Work Emotion CR Replica)
Rota Torque 17x8.0 +48
WEIGHT UNKNOWN / ADDED 8/28/12 / MFG LINK
Rota Torque 17x9.0 +30
~19 LBS / ADDED 6/1/12 / MFG LINK
Rota Torque 18x9.5 +35
Rotiform______________________
Rotiform BLQ 19x9.5 +??
Rotiform NUE 18x9.5 +25
Rotiform NUE 18x8.5 +35 / 18x9.5 +35
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 7/24/12 / MFG LINK
Rotiform SNA 19x9.0 +39 / 19x10.0 +39
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 10/2/12 / MFG LINK
Simmons___________________
Simmons FR-18 18x8.5 +41/18x9.5 +45
Speedline Corse_______________
Speedline Corse Turini 18x8.0 +48
Speedy________________________
Speedy Lite 5 17x7.0 +45
Sparco________________________
Sparco Assetto Garra 17x7.5 +48
WEIGHT UNKNOWN / ADDED 6/26/12 / MFG LINK
Sparco Assetto Garra 18x8.0 +48
Sparco Pro Corsa 18x8.0 +45
Sparco Terra 16x7.0 +50
18.2 LBS / ADDED 2/24/14 / MFG LINK
Sprint Hart_____________________________
Sprint Hart CP-R 16x7.0 +??
SSR_____________________________
SSR Formula Mesh 17x8.0 +1? / 17x9.0 +1?
SSR GT F01 18x8.5 +44
17.4 LBS / ADDED 5/14/14 / MFG LINK
SSR Professor GT2 19x8.0 +32
SSR Professor MS1 19x8.5 +43 / 19x9.5 +43
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 8/19/12 / MFG LINK
SSR Professor MS3 18x8.0 +37 / 18x9.0 +37
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 10/16/12 / MFG LINK
SSR Professor SP1 18x9.0 +38
SSR Professor SP1 18x?.? +49 / 18x?.? +47
WEIGHT UNKNOWN / ADDED 9/4/12 / MFG LINK
SSR Professor SP3 18x9.0 +24 / 18x9.0 +20
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 8/30/12 / MFG LINK
SSR Professor SP3 19x8.5 +?? / 19x9.5 +??
SSR Type-C 16x7.5 +35
SSR Type-C 17x8.0 +38
14.3 LBS / ADDED 7/15/12 / MFG LINK
SSR Type-C 18x8.0 +32
SSR Type-C H 19x8.0 +51
SSR Type-C RS 17x7.5 +49
SSR Type-C RS 18x7.5 +42
15.5 LBS / ADDED 6/15/12 / MFG LINK
SSR Type-C RS 18x7.5 +49
15.5 LBS / ADDED 8/29/12 / MFG LINK
SSR Type-C RS 19x8.0 +35
SSR Type-F 18x9.5 +??
18.8 LBS / ADDED 6/7/12 / MFG LINK
Stance_______________________________
Stance SC-5ive 19x8.5 +45 / 19x9.5 +45
STR_______________________________
STR 601 17x7.5 +40
(BBS LM Replica)
STR 601 18x8.0 +40
(BBS LM Replica)
STR 603 18x9.0 +40
Styluz____________________________
Styluz S006 18x7.5 +40
Super Star____________________________
Super Star Leon Hardiritt Orden 18x10.0 +18
Takuma________________________
Takuma RS0 18x8.0 +42
Tanabe________________________
Tanabe SSE Professor MS1 19x8.5 +43 / 19x9.5 +43
Team Dynamics__________________________
Team Dynamics Pro Race 1 17x7.0 +38
Technicraft__________________________
Technicraft T6 17x8.0 +43
13.8 LBS / ADDED 10/26/12
Tenzo__________________________
Tenzo DC-5 17x7.0 +42
WEIGHT UNKNOWN / ADDED 7/4/12
Tenzo Type-M 18x8.0 +37
TIS______________________________
TIS 537 20x8.5 +?? / 20x10.5 +??
Tom's Racing___________________
Tom's Racing EP-2 17x7.0 +47
13.2 LBS / ADDED 7/28/12 / MFG LINK
Tom's Racing TM-03 18x7.5 +50
Traklite Wheels_________________
Traklite Wheels Angle 18x8.0 +35
Traklite Wheels Angle 18x9.0 +40
TRD____________________________
TRD SF2 18x7.5 +46
WEIGHT UNKNOWN / ADDED 7/12/12 / MFG LINK
TRD TF6 18x7.5 +46
WEIGHT UNKNOWN / ADDED 7/13/12 / MFG LINK
TRMotorsports____________________
TRMotorsports C2 18x8.0 +48
TSW___________________________
TSW Interlagos 17x8.0 +35
18.2 LBS / ADDED 6/23/13 / MFG LINK
TSW Interlagos 18x8.0 +35
18.8 LBS / ADDED 7/11/12 / MFG LINK
TSW Jarama 17x8.0 +??
TSW Mirabeau 18x8.0 +35
WEIGHT UNKNOWN / ADDED 5/25/13 / MFG LINK
TSW Nurburgring 17x8.0 +35
TSW Nurburgring 17x8.0 +45
TSW Nurburgring 18x8.0 +35
TSW Nurburgring 18x8.0 +45
18.6 LBS / ADDED 7/27/12 / MFG LINK
TSW Nurburgring 18x8.0 +45 / 18x8.0 +35
18.6 LBS / WEIGHT UNKNOWN / ADDED 3/14/13 / MFG LINK
TSW Nurburgring 19x8.0 +35
TSW Panorama 18x8.0 +35
TSW Stowe 18x8.0 +35
TWS__________________________
TWS Exlete 118F Monoblock 18x7.5 +50
TWS T66-F 18x8.0 +45 or +46
14.6 LBS / ADDED 7/28/12 / MFG LINK
TWS T66-F 18x8.5 +43 / 18x9.5 +45
TWS T66-F 18x9.5 +45
15.8 LBS / ADDED 3/17/14 / MFG LINK
end of section 3 R-T wd4
The Following 5 Users Say Thank You to DarrenDriven For This Useful Post:
Choco (01-21-2015), dubbrand (08-21-2014), mwjcyber (08-31-2014), whataboutbob (04-11-2018), Yamaha_R6 (06-24-2014)
Old 06-07-2012, 02:18 AM   #8
DarrenDriven
NW Region Moderator
Varrstoen______________________
Varrstoen ES1 18x9.5 +34
Varrstoen ES2 18x8.5 +45
Varrstoen ES2 18x9.5 +34
WEIGHT UNKNOWN / ADDED 3/14/13 MFG LINK
Varrstoen ES221 18x8.5 +45
WEIGHT UNKNOWN / ADDED 3/17/14 MFG LINK
Varrstoen ES2.2.2 19x9.5 +30 / 19x10.5 +30
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 7/10/13 MFG LINK
Varrstoen ES7 18x9.5 +35
Velox__________________________
Velox PG-5S 17x7.0 +42
13.8 LBS / ADDED 12/3/13 / MFG LINK
Velox VX-6R 17x7.0 +42
14.5 LBS / ADDED 6/11/12 / MFG LINK
Vertini________________________
Vertini Dynasty 19x8.5 +30/19x9.5 +35
VIP Modular_____________________
VIP Modular VRC13 19x9.5 +30 / 19x10.5 +30
Volk Racing (Rays)______________
Volk Racing C345 Ultralight 18x?.? +??
Volk Racing CE28 17x7.5 +50
13.8 LBS / ADDED 7/27/12 / MFG LINK
Volk Racing CE28 17x8.0 +38
14.7 LBS / ADDED 6/21/12 / MFG LINK
Volk Racing CE28 17x9.0 +38
Volk Racing CE28 18x7.5 +47
Volk Racing CE28 18x8.5 +44
16.0 LBS / ADDED 6/13/12 / MFG LINK
Volk Racing CE28 18x9.0 +43
Volk Racing G2 18x7.5 +48
Volk Racing G25 18x8.0 +45 / 18x9.0 +45
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 6/21/12 / MFG LINK
Volk Racing G25 19x8.5 +45
Volk Racing G25 19x9.0 +45
Volk Racing GT-C 18x7.5 +43
WEIGHT UNKNOWN / ADDED 6/25/12
Volk Racing GT-M 19x8.0 +??
WEIGHT UNKNOWN / ADDED 6/25/12 / MFG LINK
Volk Racing GT-P 17x8.0 +50
Volk Racing LE37K 17x7.5 +40
14.3 LBS / ADDED 5/14/14
Volk Racing LE37K 18x?.? +??
Volk Racing RE30 17x7.5 +50
Volk Racing RE30 17x8.0 +44
Volk Racing RE30 18x7.5 +50
15.8 LBS / ADDED 6/7/12 / MFG LINK
Volk Racing RE30 18x8.5 +44
Volk Racing SE37 17x8.0 +38
Volk Racing SE37 18x7.5 +48
Volk Racing TE37 16x7.0 +46
Volk Racing TE37 17x7.5 +48
Volk Racing TE37 17x8.0 +36 / 17x9.0 +36
16.0 LBS / WEIGHT UNKNOWN / ADDED 3/12/13 / MFG LINK
Volk Racing TE37 17x8.0 +38
16.0 LBS / ADDED 8/28/12 / MFG LINK
Volk Racing TE37 17x8.0 +44
15.5 LBS / ADDED 9/8/12 / MFG LINK
Volk Racing TE37 17x9.0 +36
17.2 LBS / ADDED 3/12/13 / MFG LINK
Volk Racing TE37 17x9.5 +40
WEIGHT UNKNOWN / ADDED 1/26/14 / MFG LINK
Volk Racing TE37 17x9.5 +40 / 18x10.0 +44
Volk Racing TE37 18x7.5 +48
Volk Racing TE37 18x8.5 +35
WEIGHT UNKNOWN / ADDED 6/25/13 / MFG LINK
Volk Racing TE37 18x8.5 +36 / 18x9.5 +40
Volk Racing TE37 18x8.5 +38 / 18x9.5 +40
Volk Racing TE37 18x8.5 +45 / 18x9.5 +45
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 7/25/12 / MFG LINK
Volk Racing TE37 18x9.0 +45
Volk Racing TE37 18x9.0 +45 / 18x9.5 +40
Volk Racing TE37 18x9.0 +45 / 18x9.5 +45
Volk Racing TE37 18x9.5 +40
18.2 LBS / ADDED 9/24/12 / MFG LINK
Volk Racing TE37 18x9.5 +45
WEIGHT UNKNOWN / ADDED 12/13/12 / MFG LINK
Volk Racing TE37 18x10.0 +44
Volk Racing Triniti V 19x8.0 +45
Volk Racing ZE40 18x9.5 +45
Vossen_________________________
Vossen CV3 19x8.5 +32 / 19x10.0 +36
Vossen CVT 19x8.5 +45 / 19x10.0 +50
Voxx_________________________
Voxx Torino 17x7.0 +40
19.3 LBS / ADDED 3/14/13 / MFG LINK
Watanabe______________________
Watanabe F8 17x7.0 +48
WEIGHT UNKNOWN / ADDED 6/19/12 / MFG LINK
WedsSport_____________________
WedsSport Bvillens TV-X 19x8.0 +??
WedsSport Kranze Bazreia 18x10.5 +6
WedsSport Maverick 210S 18x8.0 +?? / 18x8.5 + ??
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 9/4/12 / MFG LINK
WedsSport Maverick 508S 19x?.? +?? / 19x?.? +??
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 1/2/13 / MFG LINK
WedsSport SA-10R 18x9.5 +45
20.8 LBS / ADDED 5/14/14 / MFG LINK
WedsSport SA-15R 18x8.5 +48
WedsSport SA-15R 18x8.5 +48 / 18x9.5 +48
WedsSport SA-15R 18x9.5 +48
WedsSport SA-60 17x7.5 +48
WedsSport SA-60 17x8.0 +45
WedsSport SA-60 18x8.0 +45
WedsSport SA-67R 18x9.0 +36
WedsSport SA-70 17x7.5 +42
WedsSport SA-70 18x8.0 +42
WedsSport SA-90 16x7.0 +33
WEIGHT UNKNOWN / ADDED 7/15/12
WedsSport TC105N 17x8.0 +42
14.9 LBS / ADDED 8/15/12 / MFG LINK
WedsSport TC105N 17x8.0 +42 / 17x9.0 +35
14.9 LBS / 15.8 LBS / ADDED 1/7/13 / MFG LINK
WedsSport TC105N 17x9.0 +35
15.8 LBS / ADDED 9/12/12 / MFG LINK
WedsSport TC105N 18x8.0 +42
WedsSport TC105N 18x8.5 +43
17.0 LBS / ADDED 3/13/13 / MFG LINK
WedsSport TC105N 18x8.5 +43 / 18x9.5 +35
17.0 LBS / 18.1 LBS / ADDED 1/7/13 / MFG LINK
WedsSport TC105N 18x9.5 +35
18.1 LBS / ADDED 3/14/13 / MFG LINK
Work___________________________
Work Durandal DD5.2 19x?.? +??
Work Emotion 11R 18x7.5 +?? / 18x8.5 +??
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 9/5/12 / MFG LINK
Work Emotion 11R 18x8.5 +45 / 18x9.5 +38
Work Emotion 11R 18x9.5 +30
Work Emotion CR Kai 17x8.0 +42
UNKNOWN WEIGHT / ADDED 1/7/13 / MFG LINK
Work Emotion CR Ultimate "Kiwami" 17x9.0 +38
Work Emotion CR Ultimate "Kiwami" 18x7.5 +47
UNKNOWN WEIGHT / ADDED 8/15/12 / MFG LINK
Work Emotion CR Ultimate "Kiwami" 18x7.5 +48
UNKNOWN WEIGHT / ADDED 12/3/12 / MFG LINK
Work Emotion CR Ultimate "Kiwami" 18x8.5 +38
21.9 LBS / ADDED 8/27/12 / MFG LINK
Work Emotion CR Ultimate "Kiwami" 18x8.5 +38 / 18x9.5 +38
21.9 LBS / 22.8 LBS / ADDED 7/10/13 / MFG LINK
Work Emotion CR Ultimate "Kiwami" 18x8.5 +47
21.9 LBS / ADDED 7/10/13 / MFG LINK
Work Emotion CR Ultimate "Kiwami" 18x8.5 +47 / 18x9.5 +38
21.9 LBS / 22.8 LBS / ADDED 7/2/12 / MFG LINK
Work Emotion CR Ultimate "Kiwami" 18x9.5 +30
22.8 LBS / ADDED 5/30/12 / MFG LINK
Work Emotion CR Ultimate "Kiwami" 18x9.5 +38
22.8 LBS / ADDED 3/13/13 / MFG LINK
Work Emotion CR Ultimate "Kiwami" 19x9.5 +38
Work Emotion CR Ultimate "Kiwami" 19x10.5 +32
Work Emotion XC8 18x?.? +??
Work Emotion XD9 18x9.0 +38 / 18x10.0 +18
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 6/16/12 / MFG LINK
Work Emotion XD9 18x9.0 +38 / 18x10.0 +38
Work Emotion XD9 18x10.0 +38
Work Emotion XT7 18x7.5 +48 / 18x7.5 +42
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 7/31/12 / MFG LINK
Work Gnosis GS2 20x8.0 +?? / 20x9.0 +??
WEIGHT UNKNOWN / WEIGHT UNKNOWN / ADDED 9/12/12 / MFG LINK
Work Gnosis GS4 19x8.0 +??
Work Gnosis HS202 20x8.5 +33 / 20x9.5 +30
Work Meister M1R 18x8.5 +?? / 18x9.5 +??
Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24
Work Meister S1R 18x9.0 +35
21.9 LBS / ADDED 12/3/12 / MFG LINK
Work Meister S1R 18x9.5 +25
Work Meister S1R 18x9.5 +30/18x10 +30
Work Meister S1R 18x10.0 +12 / 18x10.5 +17
Work Schwert SC2 19x8.0 +??
Work Schwert SC2 18x8.0 +45
Work Variana T1S 18x?.? +??
Work VS-XX 18x8.0 +38
Work VS-XX 18x8.5 +32 / 18x9.5 +39
Work VS-XX 18x9.0 +33 / 18x10.0 +33
Work VS-XX 18x9.0 +34 / 18x9.5 +39
XXR____________________________
XXR 527/530 gallery: ft86club.com/forums/showthread.php?t=18661
XXR 521 17x7.0 +38
XXR 521 18x8.5 +35
XXR 522 17x8.0 +48
XXR 527 17x8.25 +35
~18 LBS / ADDED 10/2/12 / MFG LINK
XXR 527 18x8.75 +35
XXR 527 18x9.75 +20
XXR 530 18x8.75 +20
XXR 530 18x8.75 +33
XXR 530 18x8.75 +35
XXR 530 18x9.75 +20
XXR 531 17x9.0 +35
XXR 531 18x8.5 +35 / 18x9.5 +35
XXR 531 18x9.5 +35
XXR 535 17x8.25 +35
XXR 535 18x7.5 +38
Yoshihara Design________________
Yoshihara Design Champion 18x8.0 +30 / 18x9.0 +35
Yoshihara Design Champion 18x9.0 +35
Yoshihara Design DY-12C 18x9.0 +40
Yoshihara Design DY-37C 18x8.0 +30/18x9.0 +35
Yoshihara Design DY-37C 18x9.0 +25
Yoshihara Design DY-37C 18x9.0 +35
Yoshihara Design DY-D5C 18x9.0 +35
end of section 4 V-Z wd5
The Following 4 Users Say Thank You to DarrenDriven For This Useful Post:
bentleyboii (06-14-2017), Busybee (07-08-2018), SuperTom (10-12-2018), whataboutbob (04-11-2018)
Old 06-08-2012, 01:54 PM   #9
DarrenDriven
NW Region Moderator
reserved for expansion
The Following User Says Thank You to DarrenDriven For This Useful Post:
Fly Guy (06-08-2012)
Old 06-09-2012, 02:42 AM   #10
DarrenDriven
NW Region Moderator
Old 06-11-2012, 12:02 PM   #11
DarrenDriven
NW Region Moderator
Old 06-12-2012, 02:52 PM   #12
DarrenDriven
NW Region Moderator
Old 06-13-2012, 03:45 PM   #13
DarrenDriven
NW Region Moderator
The Following 2 Users Say Thank You to DarrenDriven For This Useful Post:
civicdrivr (06-13-2012), Verge (09-07-2012)
Old 06-13-2012, 04:56 PM   #14
DarrenDriven
NW Region Moderator
brz aftermarket wheels, brz wheels, fr-s aftermarket wheels, frs aftermarket wheels, scion fr-s wheels, scion frs wheels, subaru brz wheels
BRZ/FR-S Wheel Fitment Photo Topic DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-12-2012 05:16 AM
BRZ/FR-S/86 Wheel Fitment Simulators JDMSushi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-05-2012 11:49 PM
Stock Suspension and Wheel Fitment bneale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-29-2012 08:42 PM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 01:34 PM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 07:33 PM
