Old 10-23-2012, 11:35 PM   #1
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Wheel Directory: Rota D 18x8.5 +48 / 18x9.5 +40
I'm always on the lookout for OEM wheels and tires that I can repurpose for other uses. If it's an OEM item, it's available in large quantities and at lower prices than the market would usually allow.
I happen to own a BMW 335i, and we sell parts for them. The OEM tire setup for sport package 3-series cars 2006 to 2011 was a 225/40R18 front, and a 255/35R18 rear. You're saying, "Yeah? So?"
The BMWs don't come with spare tires. Instead, they come with runflat tires from the factory. Time was, these tires were terrible, with moderate grip and downright harsh ride. Things have improved a lot in the past few years, though, and the difference in ride and handling compared to non-runflats is much less.
Because lots of BMW owners mod their cars, you can find many sets of these tires on the used market, for reasonable prices.
The tire sizes I mentioned above are 1.9% taller than the stock 215/45R17 tires. That's just within my rule of thumb of staying withing 2% of the factory tire diameter.
I bought a slightly used set of take-off wheels and tires (Michelin Pilot Sport ZP) from a local 335i owner, assembled a staggered set (18x8.5" +48 front, 18x9.5" +40 rear) of Rota D wheels, and bolted it all together. It fits fine, and looks pretty good. (I did use a 5mm spacer in front, more for appearance than any other reason.)
You're probably wondering about handling balance. All other things being equal, widening the rear tire by 40mm while only adding 10mm to the front will increase understeer. HOWEVER, there's the bonus that I can chuck the spare wheel and tire -- all 25 pounds of it -- to the curb, and that weight comes off the back of the car. I figure that will help some to bring back the rear-end friskiness. If that still doesn't do the trick, I'll work some with aftermarket sway bars to restore things. (I haven't got the chance to fling the car around much yet, so I don't have any subjective feedback to offer at this point.)
The new wheels and tires are a little heavier than the old ones. The stock wheel/tire was 41.4 pounds. My new front 18x8.5" Rota D with attached 225/40R18 is 44.6. I didn't weigh the rears yet, but they're probably five pounds more. But again, I've left the 25-pound spare in the closet back at home.
That rear Pilot Sport retails for well over $400 each! I paid less than the price of two new tires for an entire set of four, plus I've got wheels I can sell or keep to use on the Bimmer...
Summary: Good used BMW tires can be had for relatively cheap, and they'll fit on your FR-S or BRZ. They may not be the perfect handling setup, but if you're looking for a staggered front-to-back look, these work nicely.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
The Following User Says Thank You to Mach V Dan For This Useful Post:
ftc~brz (10-24-2012)
Old 10-24-2012, 01:33 AM   #2
gmookher
wow. we couldnt wait to get rid of our rft's...
gmookher is offline   Reply With Quote
Old 10-24-2012, 09:35 AM   #3
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
Not bad...what rims are those, if you don't mind me asking
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 10-24-2012, 09:46 AM   #4
chutrain
chutrain's Avatar
Drives: WRB BRZ
Exactly. Everyone hated the rfts. If the tires were shot, rfts never back on. Price and harsh ride were usually the issue.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 10-24-2012, 10:33 AM   #5
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Runflats are heavy too and add weight at the worse possible spot, i'd rather keep the spare...
JoeBoxer is offline   Reply With Quote
Old 10-24-2012, 10:38 AM   #6
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by Mach V Dan View Post
...assembled a staggered set (18x8.5" +48 front, 18x9.5" +40 rear) of Rota D wheels
Old 10-24-2012, 12:49 PM   #7
enjoi23
enjoi23's Avatar
Drives: FRS
Originally Posted by Foobar View Post
Oh, sorry i didn't see that. I'm an idiot
Old 10-24-2012, 12:53 PM   #8
TheSt|G
TheSt|G's Avatar
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
I can't imagine intentionally going to run flats.
TheSt|G is offline   Reply With Quote
Old 10-24-2012, 12:54 PM   #9
D1cker
Drives: B9 S4/ND2
The Michelin Pilot Sport ZP's are pretty good, but the Bridgestone RE050 RFT's suck.
D1cker is offline   Reply With Quote
Old 10-24-2012, 01:10 PM   #10
jeebus
Drives: 2015 Mustang GT (on order)
What in the...why? I'd rather add 100lbs to the trunk than 25 to the wheels. I took my RFTs off my BMW ASAP because they blow.
jeebus is offline   Reply With Quote
Old 10-24-2012, 01:30 PM   #11
TheSt|G
TheSt|G's Avatar
RFT actually aren't that much heavier these days, but there are plenty of other reasons why they completely suck.
Old 10-24-2012, 02:24 PM   #12
Mach V Dan
I also had a set of the RE050, and found them terrible. The Michelins are a big leap forward.
--Dan
Mach V
Old 10-24-2012, 05:25 PM   #13
tawheed
Drives: '13 Sport Tech
Runflats are awful.. It's basically the first thing people want to take off their car, even if they have no miles on them.
tawheed is offline   Reply With Quote
Old 10-24-2012, 05:34 PM   #14
empower-auto
Kouki-Monster
empower-auto's Avatar
wheels look good
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Swift Springs Fitting - SoCal Only schtebie Southern California 16 11-29-2012 04:29 PM
fitting 17x9's with 255s, and fitting brake pads Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-29-2012 12:08 PM
Anyone worried about not fitting in the car? budakajana AUSTRALIA 35 06-27-2012 08:55 AM
