Old 06-26-2013, 01:47 AM   #1
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Wheel Directory: OZ Formula HLT 17x8.0 +48 / 17x9.0 +42
As posted in another topic...
Originally Posted by tom@kartboy View Post
Picked up some new wheels for the car yesterday. OZ Formula HLT in gold
Fronts are 17X8 with 235 Direzza ZII
Rears are 17X9 with 245's
The Following User Says Thank You to DarrenDriven For This Useful Post:
NWFRS (07-06-2016)
Old 06-26-2013, 02:01 AM   #2
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
+48 front +42 rear I think
I tom@kartboy a few weeks ago about this and he stated he ordered the tirerack guarantied fit.
headlikeahole is offline   Reply With Quote
The Following User Says Thank You to headlikeahole For This Useful Post:
DarrenDriven (07-08-2013)
Old 07-06-2013, 10:26 PM   #3
dokterdewe
dokterdewe's Avatar
Drives: an automatic lightning red 86
Send a message via Yahoo to dokterdewe
I think i will put them in my red 86.. probably the same gold... what do you think?
dokterdewe is offline   Reply With Quote
Old 07-08-2013, 01:08 PM   #4
DarrenDriven
NW Region Moderator
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 03-27-2014, 09:56 PM   #5
oaroyale
Drives: Black BRZ
just found these on sale on tirerack for $189 a piece. gold or matte grey. 17x9 +42
oaroyale is offline   Reply With Quote
Old 06-21-2014, 11:31 PM   #6
phatfil
Drives: 13 FR-S Asphalt
17x9 +42
I will be getting a set by next week. Will post pics.
phatfil is offline   Reply With Quote
Old 06-23-2014, 02:34 PM   #7
ModBargains
ModBargains's Avatar
Drives: FRS, M3
That looks good guys
ModBargains is offline   Reply With Quote
Old 08-19-2014, 02:07 PM   #8
phatfil
Goldz
17x9 +42 all around @21lbs. Hankook R-S3 245/40-17. Showing the two different caps that come with them in the first pic. Note there is only one set of the OZ logo center pieces so once you install them (sticker card)on the desired center cap you can't really reuse them. I don't use them. I also have ARP extended studs and the length is perfect for this wheel. Enjoy!
It is real tight on the inside but I have not had any clearance issues. On stock suspension.
Old 07-06-2016, 09:41 PM   #9
Kinexus
Drives: 2013 FR-S MT Ultramarine
[dropped images for unnecessarily large quote size]
I am interested in seeing how much clearance there is on the inside at full lock. I have the same size/offset and have heard there's a clearance issue with the sway. I have tires on the way, so I cannot check the fit quite yet.
UPDATE:
I did a quick check last night with just the wheel, and I feel I would be more worried rubbing against the seat that the spring sits in, it is much closer than anything else. The sway seems to be tucked away enough, but I cant be sure until I get the tires mounted on the wheels. I'd really like to do these without a spacer if possible, but I dunno if thats gonna be possible up front.
Kinexus is offline   Reply With Quote
OZ Formula HLT 17x9 +42? Gunman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 06-09-2013 07:39 PM
WTT Enkei 17x8 for 17x9 5x100 subaruferrucci Wheels and Tires 3 04-30-2013 01:28 PM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 04:58 PM
TE37SL - 17x8.5 / 17x9.5 / 18x9.0 5x100 Pre Order Available Now ! RavSpec Wheels and Tires 2 07-14-2012 11:37 PM
