Old 01-25-2013, 05:39 PM   #1
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
Wheel Directory: Mach V Awesome 17x9.0 +42 / 18x9.5 +42
In this other thread I gave some results from fitting up 265/35R18 on our 18x9.5" +42 Wicked Awesome wheels all around. (Cliff notes: Front too big.) We do also have our 17x9" Awesome wheel, so as a follow up we fit a set of the 17x9" front wheels with 255/40R17, and the same 18x9.5" with 265/35R18 in back.
Careful observers will note that the 17x9" Awesome is a ten-hole wheel -- it was designed to fit any Subaru car, including ones with 5x114 bolt patterns. The 18x9.5 is drilled with only one bolt pattern, although it does have little holes between the bolt holes, so it's not as different-looking as it might be.
Both wheels are 56.1mm hub bore, so they didn't need hubcentric rings.
Here's how the car looks...
Blurry. Sorry.
I like the look. Makes me think of serious performance cars that have (or had) staggered wheels. NSX, C6 Corvette, Mercedes SL63 AMG...The smaller front wheel diameter helps to accentuate the car's trim front, while the bigger wheel in the back fits with the larger flank of the car.
Obviously a square setup is a lot more practical in terms of being able to rotate tires for maximum life, and handling balance may be better with a square setup, too. But especially for cars that are going to have much more horsepower than stock, a big rear tire is going to be helpful for keeping the back end attached to the road.
Anyway, I hope this is thought provoking, or at least adds to the general knowledge about wheel/tire fitment on these cars.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
The Following 4 Users Say Thank You to Mach V Dan For This Useful Post:
DAEMANO (03-01-2014), JoeBoxer (01-25-2013), RYU (05-03-2013), usptwins (01-25-2013)
Old 01-25-2013, 06:54 PM   #2
miodculae
FRS Adept
miodculae's Avatar
Drives: Firestorm FRS
do these rims now come with decals/stickers ? possibly laser etched ?
miodculae is offline   Reply With Quote
Old 01-25-2013, 09:22 PM   #3
Mach V Dan
The decals are available separately.
--Dan
Mach V
Old 03-12-2013, 03:09 PM   #4
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Can you please confirm offsets for each size?
Added to the Wheel Directory
http://tinyurl.com/86wheels
Old 05-02-2013, 07:13 PM   #5
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
I'm understanding that the wicked awesomes are not going to clear the stock spring perch in the front with much comfort. Would they clear with a set of coil overs & 245/35 rubber? If so, will I be able to get any camber?
Will be running the RCE Tarmac II's
OjiGeorge is offline   Reply With Quote
Old 05-02-2013, 10:24 PM   #6
Mach V Dan
Originally Posted by DarrenDriven View Post
Can you please confirm offsets for each size?[B]
Both +42.
The wheels clear. The 265 tire did not.
Probably.
If you use the strut top to do it, sure. If you're trying to do it with bolts at the knuckle, that depends how much you're trying to get.
--Dan
Mach V
The Following User Says Thank You to Mach V Dan For This Useful Post:
Old 05-03-2013, 03:40 AM   #7
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
man I wish these came in 17x8
dori. is offline   Reply With Quote
Old 05-03-2013, 02:37 PM   #8
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Dan,
Going back to the 18x9.5s, square.
Ultimately may be looking to run that wheel w/ a 285/30 Hoosier. I have coilovers w/ a significantly smaller perch in front & running approx -2.5/-1.8 camber front/rear.
Is this a laughable proposition w/ a 11.5" section-width tire? Where would the clearance issues be? SCCA car...
Thx
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 05-03-2013, 06:26 PM   #9
Mach V Dan
Element Tuning ran that tire on their FR-S. That was on an 18x10 +35 wheel with a 5mm spacer in front, so effectively +30. You'd need a 12mm spacer to get our wheel to +30. (15mm is more common...that would do.)
--Dan
Mach V
GTB/ZR-1 (05-09-2013)
Old 05-04-2013, 11:21 PM   #10
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Love it. 17/18 stagger looks so good on these cars. I know I'll eventually end up going to 17/18 stagger.
TylerLieberman is offline   Reply With Quote
Wheel Directory: Mach V Wicked Awesome 18x9.5 +42 Mach V Dan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 11-21-2013 11:36 PM
TSW Wheels 17" 18" Nurburing + Interlagos and More (Wheel+Tire Package Available) MIKE@MRTIRESOLUTIONS Wheels and Tires 0 12-20-2012 06:12 PM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 05:52 AM
FT-86 test mule spotted in germany near "the ring" again zigzagz94 Scion FR-S / Toyota 86 GT86 General Forum 5 10-27-2010 07:02 AM
