Drives: Raven FRS
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38
![]() Just thought if share photos of my raven on kwv3 with Work Emotion in 18x9.5 +38 offset. It's at factory set height from kw and rides like stock. Tires are Yokohama s-drive in a 245/35/18 squared setup. I'm considering putting on rpf1 instead if anyone is interested in the works. Thanks. Last edited by DarrenDriven; 05-12-2014 at 01:33 AM. |
| The Following User Says Thank You to kimchangil424 For This Useful Post: | Clipdat (02-20-2013) |
More pics this is a clean setup.
Drives: SOLD...
I have these wheels on order in staggered fitment..
How much lower is the car from stock?
WRB MT BRZ Sport Tech Delivered March 21 2013 Its mine now!!
Paid for Mar 2018 and its gone... Sept '18 tho I am sure I will miss it Replaced with 18 50th edition ND ![]() |
Most dope
Drives: Raven Scion FR-S
Looks great! any more pics?
Power Ranger
Drives: 86
let me know if you decide to sell 'em, looks good man
Autofashion | FIVEaxis | Enkei
Drives: Raven FRS
| The Following User Says Thank You to kimchangil424 For This Useful Post: | joshontilt (05-29-2013) |
Drives: Raven FRS
Drives: Raven FRS
Drives: Raven FRS
#10 |
Drives: Raven FRS
#11 |
Drives: Raven FRS
#12 |
Drives: Raven FRS
The car is probably 1.3 inches lower then stock. It rides pretty close to factory except a tad bit firmer. I have no problems clearing driveways at that height and no rubbing at full lock.
#13 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
any issues with that tire size up front? i'm trying to run a 255 all around and wondering how much room there is up front.
alignment specs if you dont mind? |
#14 |
Drives: Raven FRS
There is no clearance issues at full lock either way with the 245/35/18. Alignment spec is set up for daily driving as I will be changing out the rims for track purposes and realigning the car. Toe is within factory specs and camber is just outside of factory specs ( not by much). I had evasive do the alignment. I think some members are running 255 but on a 17 inch rim. I think it's pretty tight to fit a 255 depending on which tire manufacturer you go with and your suspension setup. Maybe some other members could provide input on this.
| Wheel Directory: Work Emotion CR-Kiwami 18x8.5 +38 | Jeff Lange | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 03-21-2018 06:18 PM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 | Killerbee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 20 | 03-08-2014 05:49 PM |
| Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 02-25-2014 07:00 AM |
| WTB: Work Emotion Ultimate Kiwami Wheels Center Caps | hanabie | Want-To-Buy Requests | 0 | 10-25-2013 07:34 PM |
| WORK Emotion CR Ultimate (Kiwami) - 17x9 +38mm 5x100 IN STOCK NOW | RavSpec | Wheels and Tires | 14 | 12-01-2012 01:26 AM |
