Old 07-02-2012, 03:48 AM   #1
FML
Drives: Raven FRS
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x8.5 +47 / 18x9.5 +38
18x8.5 +47 225/40/18 Toyo T1R
18x9.5 +38 245/35/18 Toyo T1R
1 Inch drop
Back poking out about 1/2 - 1 inch didnt really measure it
+47 in the front is pretty flush. I think +38 will poke out like the rear
Riding on 18s I notice the car seems a bit more sluggish during take off. I was worried about understeer with the staggered fitment but the handling does not seem to have been affected much other than having way more grip. I dont notice any understeer but this is just my daily driver and I'm not a track nut/expert
Hope this helps anyone trying to decide on offsets.
FML is offline   Reply With Quote
Old 07-02-2012, 04:07 AM   #2
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
Looks very nice. well done I'm not an expert but I think that you would have to push it to the limit to notice understeer. Someone will correct me if I'm wrong lol.
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 07-02-2012, 04:14 AM   #3
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Good to see they stick out a bit... Personally I like the rim edge sticking out more.. Then peel a tyre over it and setting some camber to avoid rub... Looks great nonetheless and cheers for posting...
I'm going to try to run 8.5 front 9.5 rear but use similar to the stock size tyres.. Well try anyway. Bit aggressive but I like it like that..
FT-86GOD is offline   Reply With Quote
Old 07-02-2012, 04:29 AM   #4
jurjurson
Drives: 2013 c63 & 2012 370z Sport/Navi
Looks really good!
jurjurson is offline   Reply With Quote
Old 07-02-2012, 01:30 PM   #5
Norcalscionchamp
Norcalscionchamp's Avatar
Drives: Whiteout 6MT Scion FR-S
Glad to see some bronze on black action....looks great!!!
Norcalscionchamp is offline   Reply With Quote
Old 07-02-2012, 01:31 PM   #6
poormans_LFA
FT86Club.com O.G.
poormans_LFA's Avatar
Drives: Gunmetal Gundam Wing Zero Custom
must post more pics!!!
poormans_LFA is offline   Reply With Quote
Old 07-02-2012, 01:33 PM   #7
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
You should do an autocross and see how it pushes during hard turn in. I really consider going staggered with pretty much those exact wheels. I think I would try different offsets though.
Ranatsu is offline   Reply With Quote
Old 07-02-2012, 02:30 PM   #8
oldskule
oldskule's Avatar
Drives: Mazda
Looks pretty good! But the rear tires are a bit too low profile for my taste. Also needs moar low!
oldskule is offline   Reply With Quote
Old 07-02-2012, 03:13 PM   #9
kidgogeta
Drives: FRS
if you don't mind how much did those rims and tires cost you? I want to go the same route as that
kidgogeta is offline   Reply With Quote
Old 07-02-2012, 09:39 PM   #10
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Arrgghhhh, works fire wall is stripping the photos....this is my first choice for set up. have to wait until home before viewing.....arrrggh.
Sigh.....patience is a virtue.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 07-02-2012, 09:59 PM   #11
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Wait a minute that means that 18x 9.5 +35 will stick out further than the +38?
Memphis is offline   Reply With Quote
Old 07-02-2012, 10:07 PM   #12
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
That looks very nice but I think it'll rub once the springs are installed. Do you plan on rolling the fenders and cambering the rear?
How do the 35's feel on the rear?
Old 07-02-2012, 10:33 PM   #13
FML
Drives: Raven FRS
the fenders are pre-rolled from the factory and I'm only going to drop it about an inch. I was told the rear will camber in slightly once I lower it so I dont think it will rub.. The 35s feel fine. ride quality has not suffered at all
Old 07-02-2012, 10:35 PM   #14
FML
Drives: Raven FRS
yes but I cant imagine +3 making that much of a difference.
Wheel Directory: Work Emotion CR-Kiwami 18x8.5 +38 Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 03-21-2018 05:18 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +38 kimchangil424 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 01-03-2017 06:00 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 18x9.5 +30 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 179 11-20-2015 12:12 AM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x9.5 +38 Killerbee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 03-08-2014 04:49 PM
Wheel Directory: Work Emotion CR Ultimate "Kiwami" 19x10.5 +32 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 02-25-2014 06:00 AM
