Old 04-07-2014, 10:31 PM   #1
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Wheel Directory: Racing Hart CP-035R 16x7.0 +45
Racing Hart
CP-035R
16x7"
+45 ET
5.0Kg/11lbs
Forged
Alignment on coilovers:
FC: -3*, FT: -0mm
RC: -1.5*, RT: +1mm
Alignment on stock:
FC: -2.4*, FT: -0mm
RC: -1.0*, RT: +1mm
3mm clearance from tire to stock front spring perch.
Fitted with Bridgestone RE002 225/50R16 (10.5Kg)
For comparison:
OEM Enkei 16x6.5" - 7.2kg
OEM Yokohama DB70 205/55R16 - 9kg.
I don't even rate the OEM 17" Subaru wheels, they're an abomination.
OEM Subaru 17x7.0" - 9.4kg
OEM Michelin 215/45R17 - 9kg
Old 04-09-2014, 05:30 PM   #2
GuerillaRacing
GuerillaRacing's Avatar
Drives: Scion FR-S
Very nice 86, is this with any spacers in the rear?
GuerillaRacing is offline   Reply With Quote
Old 04-09-2014, 06:37 PM   #3
myEFispissed
Drives: '13 Asphalt
Where did you find these Wayno? I have some 15s on my EF civic.
myEFispissed is offline   Reply With Quote
Old 04-09-2014, 06:43 PM   #4
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Nice! Tires look meaty for the 7" wide wheels, I think I actually like those more than my TE37s.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-09-2014, 10:48 PM   #5
Wayno
Wayno's Avatar
Spacers are illegal in Australia mate.
Old 04-10-2014, 12:17 PM   #6
GuerillaRacing
Drives: Scion FR-S
Doh!
Old 05-14-2014, 04:44 PM   #7
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Old 08-30-2014, 09:35 PM   #8
Stumpygt86
Drives: Toyota GT86. N/A for life
Originally Posted by Wayno View Post
Racing Hart
CP-035R
16x7"
+45 ET
5.0Kg/11lbs
For comparison:
Hey Wayno, where did you find those wheels? I am currently in the market for either 16x7 or 16x7.5 CP-035R's.
Most I have seen so far are either a 4 stud or a 5x114.
Cheers,
Jeff
Stumpygt86 is offline   Reply With Quote
Old 08-30-2014, 10:01 PM   #9
Wayno
Wayno's Avatar
Second hand, extremely rare like ssr type c. You'll have much more choice with TE37.
Old 10-03-2014, 03:40 AM   #10
Wayno
Wayno's Avatar
Now running about 2.4 deg camber in the front with 3 mm clearance tire to stock spring seat.
Old 10-03-2014, 10:16 AM   #11
Timmy_Jones
Spun
Drives: 23' Supra
Mini - almost RPF1s. Car looks great, nice sidewall there too.
Timmy_Jones is offline   Reply With Quote
Old 10-03-2014, 10:35 AM   #12
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
+1 to that. CP-R's in 16x7.. let alone 5x100 fitment for our cars is like finding a unicorn.
Nice wheel choice.
stevo_12v is offline   Reply With Quote
Old 10-20-2014, 04:32 AM   #13
Wayno
Wayno's Avatar
You mean RPF1 are nearly these because RPF1 are cast :p
Old 10-20-2014, 04:34 AM   #14
Wayno
Wayno's Avatar
Nice wheel choice.
Needs lots of sidewall so they don't fold up when you run over a toothpick like they would if 18".
Wheel Directory: Sparco Terra 16x7.0 +50 phatroksek Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-28-2020 07:56 PM
Wheel Directory: Konig Forward 16x7.0 +40 brzr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-30-2014 12:53 AM
Wheel Directory: MSW Type 14 16x7.0 +38 amram Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-20-2014 11:13 AM
Wheel Directory: Sprint Hart CP-R 16x7.0 +?? jonbatz01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 12-03-2013 10:05 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 12:24 PM
