Drives: '12 Toyota 86 (RED) MT
Wheel Directory: Gram Lights 57FXX 18x8.0 +45
![]() After 6 months of waiting (and almost swapping my order to the Enkei RS05RR), my Ray's 57FXX wheels are finally here. Had it installed earlier this morning and I'm just glad with how it looks. Conversative offset and width but I'm quite happy with how it turned out. Will be installing some lowering springs soon and on top of that, a brand new 4-pot Brembo BBK. No rubbing issues at all. Specs: Ray's Gramlights 57FXX (Black Machining) - 18" x 8J Offset +45mm Weight: 9.2kg = Approx 20.3lb (0.2lb or 0.1kg heavier than stock) Rubber: Yokohama Advan Neova AD08R 225/40/18 Sits surprisingly well at ride height - might be due to the TRD bodykit making the fender gap seem quite even. I have a set of TRD Sportivo springs which would lower it by 10mm once I install them. Why not lower it more? Unfortunately, our roads are terrible and I have already scraped my front bumper countless times due to potholes. To top that off, I have broken my exhaust diffuser hanger TWICE (and re-welded) due to ridiculous road bumps. Side view: Quite even and the black blends in very well. The red Ray's cap is a bit ricey but honestly I like it. Gives the car a bit of character imo. Back wheels could use a lower offset but I wanted a square setup no matter what. I'm quite happy with this actually. Front fender. Given the conservative offset, this sits rather well. Last edited by DarrenDriven; 03-17-2014 at 01:52 PM. |
Looks really good. With a mild drop It will look even better. Congrats and enjoy the car now.
Drives: 2013 MT Asphalt FRS
Wicked
Drives: 2013 frs
Holy crap 6 months but it was worth the wait it looks good
Sent from my SM-N900W8 using Tapatalk |
Drives: Asphalt FRS
Looks great...minus the "off" red center caps!
Drives: GR86 / Supra MK5 MT / MR-S / Z4
I like it. Fits the car very well. As others have said, a mild drop and it will be perfect
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
Thanks for your generous words and feedback!
I am going to lower this by 10mm (0.4") soon enough - and perhaps even more when I actually get some new coilovers along with 235/40/18 tires in the future. |
Just a dude
Drives: Scion FR-S 2013
Just note when you do lower it an inch say, you'll need spacers at that offset unless you don't mind them being well tucked in..
Drives: Series 10 FR-S
Still waiting on my 18x9.5 +38 to come in with the max concave face 2.
#10 | |
![]() On another note, I have given my new wheels & rubber a bit of pushing and I'm finding it rather interesting. These new AD08Rs are crazy sticky and I've been pushing it on the local touge roads and have yet to even come close to breaking the grip limits. Barely any chirping even at very hard cornering - braking has definitely improved and I'm holding much more speed throughout. The speedo is definitely slightly off but no biggie there. These are probably the most confidence-inspiring tires I've tried yet. Love them! |
#11 |
Drives: White 2013 FRS
Looks beautiful
Sent from my SGH-I747M using Tapatalk |
#12 |
Just an update after installing the wheels:
I've recently had the Brembo GT BBK for FR-S (4-pot front) installed and it clears beautifully. Even the tightest spot had around 7-8mm of clearance so no issues at all. I was a little afraid of fitment initially and almost ordered some spacers for that. Unfortunately due to the new size I wasn't able to get a BBK template (from Ray's) for the 18" 57FXX. Have installed the black Ray's lug nuts as well. All is good! |
#13 |
Hella Flush
Drives: 2013 SWP BRZ
Wheel and brake setup looks good, lower 1.5" and should be good
#14 | |
Undercover Batman
![]() "He who shall be last, shall be sideways and smiling." - Jeremy Clarkson |
| Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40 | WorkoArt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 02-18-2017 06:46 PM |
| Wheel Directory: Gram Lights 57FXX 18x8.5 +45 | r4m3n | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 03-17-2014 02:22 PM |
| Gram Lights 57FXX | TRD-X | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 47 | 03-08-2014 05:07 AM |
| Wheel Directory: Gram Lights 57Maximum 18x8.5 +45 | jimbobrand | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 12-22-2013 08:38 PM |
| Wheel Directory: Gram Lights 57DR 18x8.5 +38 | JoeBoxer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 33 | 06-26-2013 12:44 AM |
