Old 02-26-2014, 04:32 PM   #1
Aegrizz
Drives: Frs
Wheel Directory: OEM Nissan Skyline R33 17x9.0 +30
Im trying to run these wheels really soon and im just wondering if i need to roll fenders? I'll be on 15mm spacers conversion and 215/45/17 tires. How much camber should i run in the front and rear?
Aegrizz is offline   Reply With Quote
Old 02-27-2014, 08:02 PM   #2
Aegrizz
Drives: Frs
any suggestions?
Old 02-28-2014, 01:47 AM   #3
Turdinator
Señor Member
Turdinator's Avatar
Why are you running spacers? 30+ should already give you plenty of poke.
1974 TA22 Celica
2013 86 GT
Old 02-28-2014, 02:17 AM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Because R33 GT-R wheels are 5x114.3mm
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Yardjass (11-22-2017)
Old 02-28-2014, 10:30 AM   #5
noob and expert
Drives: None :(
Pics?
For me, there is no glide in pulse and glide :p
??? is offline   Reply With Quote
Old 03-03-2014, 03:16 PM   #6
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Post some photos!
Old 03-04-2014, 03:15 AM   #7
Oh Damn Andrew
Oh Damn Andrew's Avatar
Drives: 2013 Whiteout FRS
To be accurate, these are GTR copies but you'll get the idea
Oh Damn Andrew is offline   Reply With Quote
The Following 3 Users Say Thank You to Oh Damn Andrew For This Useful Post:
Diode Dynamics (03-04-2014), hmong337 (03-18-2014), SLICVIC (03-17-2014)
Old 03-04-2014, 08:20 AM   #8
wparsons
wparsons's Avatar
Are the wheels +30, or are they +45 with a final offset of +30 including the adapters? If the wheels are +30 your final offset is +15 which is huge amounts of poke with a 9" wheel.
Also, 215's on a 9" wheel? Yikes.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
JazzleSAURUS (11-21-2017), Yardjass (11-22-2017)
Old 03-04-2014, 08:36 AM   #9
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
9" et30 is already poking nearly 5mm in the front. Adding another 15mm you'll definitely need some fender work ide think. That 215 tire would be a must imo depending on ride height. Ide just get a hub conversion for the front.
Old 03-04-2014, 11:00 AM   #10
wparsons
wparsons's Avatar
The 5mm poke could easily be fixed with another degree or so of camber, the 15mm more will probably need pretty extreme camber and/or fender pulling to make it fit.
flickr
Old 03-04-2014, 01:52 PM   #11
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
i run a 9 et30 with a 245 all around. fits perfect with a two finger wheel gap and -2* camber all around. et15 will be rough though
Old 03-04-2014, 01:55 PM   #12
mav1178
mav1178's Avatar
R33 GT-R wheels are 17x9" +30 5x114.3mm
-alex
Old 03-04-2014, 06:28 PM   #13
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Here is my thread on my wheels, they are 8.5 +14 front and 9.5 +16 rear. The rear is stock camber while the front are what ever stance gave me.
http://www.ft86club.com/forums/showthread.php?t=38680
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 03-04-2014, 06:45 PM   #14
FunCon5
FunCon5's Avatar
Funny, I just saw a set on craigslist.
http://eugene.craigslist.org/pts/4342408200.html
FunCon5 is offline   Reply With Quote
Wheel Directory : Drag DR-38 17x9.0 +38 smbstyle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 07-21-2019 07:32 PM
Wheel Directory: ESM 004 17x9.0 +38 Scott Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-26-2017 05:54 AM
Wheel Directory: Rota DPT 17x9.0 +35 lightdir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 05-17-2016 04:10 AM
Wheel Directory: Rota RT5 17x9.0 +30 b-25 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 12-03-2013 03:21 PM
Wheel Directory: XXR 531 17x9.0 +35 Drftfan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-19-2013 06:16 PM
