Old 07-15-2013, 08:56 PM   #1
orod35
orod35's Avatar
Drives: silver 2013 scion frs
Wheel Directory: OZ Superleggera 18x8.0 +35
i just picked up a set of powdercoated 18x8 et35 oz racing superleggera rims. today i got them mounted and balanced on 245 35 18 dunlop tires just to get me started. now im a little worried to lower the car because i think it is too close to the out side of the fender... let me know what you guys think. imterested in the eibach sportlines just so you guys know what im planning
orod35 is offline   Reply With Quote
Old 07-15-2013, 09:14 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Looks good.
Old 07-15-2013, 09:15 PM   #3
Drftfan
Drives: Argento FR-S
As soon as you lower it you will have enough camber where it won't matter
This is your first performance car?
Drftfan is offline   Reply With Quote
The Following User Says Thank You to Drftfan For This Useful Post:
dori. (07-16-2013)
Old 07-15-2013, 09:18 PM   #4
charged86
charged86's Avatar
a classy look!
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 07-15-2013, 10:50 PM   #5
orod35
orod35's Avatar
thanks. i found these for 200 bucks. so wait how will i have camber once i lower it? i thought you needed coilovers for camber?
Old 07-15-2013, 11:39 PM   #6
Drftfan
No you don't need coilovers for camber. As soon as you add springs depending on the drop you will have what people refer to now as "natural camber". Your wheels will tilt up top as soon as you change the suspension geometry.
Old 07-16-2013, 01:31 AM   #7
wheelhaus
wheelhaus's Avatar
The geometry of the suspension will cause the top of the tire to tilt inward as it's compressed through it's range (adds negative camber). It's typical, as the body leans in a fast turn, the added camber helps keep the contact patch more square instead of rolling onto the tire's shoulder. In other words, the wheel's path doesn't travel straight up and down, it's a slight inward arc.
I'm not a huge slammed suspension guru, but it doesn't seem like you'd have any real issues if you lowered moderately. The wheel will still follow the same arc when you hit a bump or dip. Worst case you might need to roll the fender. Personally I wouldn't slam it, maybe an inch or so, but that's preference.
BTW nice tire in the front seat, lol...
wheelhaus is offline   Reply With Quote
Old 07-16-2013, 01:32 AM   #8
orod35
orod35's Avatar
[QUOTE=Drftfan;1072148]No you don't need coilovers for camber. As soon as you add springs depending on the drop you will have what people refer to now as "natural camber". Your wheels will tilt up top as soon as you change the suspension
Good to know thanks. Ill be looking into the eibach springs and the megan racing (they say the springs drop the car 1.75 inches.)
Old 07-16-2013, 01:34 AM   #9
orod35
orod35's Avatar
yeah im not looking to slam it. Im moving back to ny in a few months and the roads wont be to king to my car. Based on how it looks now I might just do an inch and leave it at that for now.
And yeah i had just gotten back from the tire shop haha those are the stock ones inside. Needless to say I need to vacuum the interior now. I gots treadmarks in my car
Old 11-24-2013, 02:30 PM   #10
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Wheel Directory: BBS RG-R 18x8.5 +35 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 04-11-2015 05:03 PM
Wheel Directory: BBS CH-R 18x8.0 +38 Racecomp Engineering Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 81 10-01-2014 03:12 AM
Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 JRoldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-07-2014 09:10 AM
Wheel Directory: BBS LM 18x8.0 +50 stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 07-08-2013 08:55 PM
Wheel Directory: BBS RE 18x8.0 +50 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-25-2013 09:49 PM
