follow ft86club on our
blog
twitter
or
facebook
User Name
Remember Me?
Password
Register
Garages
Help
Community
Calendar
Today's Posts
Search
Search Forums
Search Results
Community Links
Members List
User Tagging Statistics
iTrader
Search Forums
Show Threads
Show Posts
Tag Search
Go to Page...
Sign Up
Showing results 1 to 29 of 29
Search took
0.01
seconds.
Search:
Posts Made By:
Tonrogs
Forum:
Forced Induction
04-01-2021, 04:21 PM
18
Tuner says wastegate spring is too tight..help please!
4,137
Posted By
Tonrogs
Just noticed you are looking at atmospheric...
Just noticed you are looking at atmospheric pressure.
Talk with your tuner. They can show you which value you should be looking at.
Forum:
Engine, Exhaust, Transmission
02-02-2021, 07:21 PM
29
Perrin 3" Resonated - Going Turbo
6,850
Posted By
Tonrogs
this.
this.
Forum:
07-18-2020, 07:33 PM
439
Jackson Racing Dual Radiator/Oil Cooler
206,796
Posted By
Tonrogs
Just move your upper bracket forward
Simply move your 2 upper radiator brackets forward for an extra half inch of clearance. You will end up putting 1 bolt in each bracket. Move the bracket forward and align the rear bracket hole with...
Forum:
DIY (Do-It-Yourself) Guides
04-29-2020, 07:02 PM
35
Putting back the transmission. Please help
5,712
Posted By
Tonrogs
if you heard a "ting" that could be one of your...
if you heard a "ting" that could be one of your tob clips. Definitely pull it apart and take a peek.
I also recommend to zip tie the fork to a bolt outside the trans when putting the trans back in....
Forum:
04-26-2020, 10:07 AM
35
5,712
Posted By
Tonrogs
Double check your new clutch disk is correct for...
Double check your new clutch disk is correct for the spline on the transmission. You will have to remove the clutch to do that. See if it slips on.
Did you replace the pilot bearing? Did you double...
Forum:
Forced Induction
03-17-2020, 08:13 PM
59
(TURBO) What makes/supports 500-550HP reliably for our cars?
17,254
Posted By
Tonrogs
E85, yes. Running about 17-18psi before storing...
E85, yes.
Running about 17-18psi before storing over winter. Working on getting the cd009 swap in currently. Any higher on boost(19-20psi) and my tires just spun recklessly. So i turned it back down...
Forum:
Forced Induction
03-16-2020, 09:11 PM
59
17,254
Posted By
Tonrogs
Lower the compression to either 9/9.5/10/10.5 to...
Lower the compression to either 9/9.5/10/10.5 to 1
Get a stronger transmission if you plan to actually use the power.
You will just spin... With those tires, no grip, the power is useless. Grippier...
Forum:
Issues | Warranty | Recalls / TSB
02-02-2020, 06:48 PM
87
VVT Not Enabled
25,011
Posted By
Tonrogs
Assuming everything works properly on startup,...
Assuming everything works properly on startup, vvt should enable within 5 seconds. Typically right away.
Id start with techstream to narrow the possibilities.
Forum:
02-01-2020, 01:28 PM
87
VVT Not Enabled
25,011
Posted By
Tonrogs
I had the same issue and it was a bad cam angle...
I had the same issue and it was a bad cam angle sensor. Not the solenoid, but the actual sensor.
Forum:
08-29-2019, 08:49 PM
22
Loose bolt in engine/transmission assembly?
6,834
Posted By
Tonrogs
That bolt definitely should not be sticking out...
That bolt definitely should not be sticking out like that. 14mm, tighten it up or bring it somewhere. Have whomever check all are torqued down correctly.
That bolt is helping to hold the...
Forum:
08-29-2019, 07:27 PM
1
Where do you guys apply heat tape?
712
Posted By
Tonrogs
I have spal fans and applied the gold tape to the...
I have spal fans and applied the gold tape to the cover plates on those. Also applied it to bottom of maf sensor. Only other place it is going is on the tunnel above the trans as my tunnel gets hot...
Forum:
08-15-2019, 08:01 PM
42
Thoughts on this built engine for my Turbo FRS
11,849
Posted By
Tonrogs
yes it would warrant it. Go 10.5:1 or 10:1 and...
yes it would warrant it. Go 10.5:1 or 10:1 and have fun knowing you have more head room for more boost.
Forum:
08-15-2019, 07:52 PM
42
11,849
Posted By
Tonrogs
You should seriously consider at least part of my...
You should seriously consider at least part of my offer. Take a ride in my 9:1 engine BRZ. You could also just pull the engine and have FBM build it utilizing your existing case halves and crank.
As...
Forum:
07-28-2019, 09:13 AM
10
P0453 - Anyone
2,566
Posted By
Tonrogs
Was your evap solenoid disconnected for a boost...
Was your evap solenoid disconnected for a boost controller previously? Check to be sure you reconnected everything for it.
Forum:
07-26-2019, 06:11 PM
21
spark plugssss quick question
5,059
Posted By
Tonrogs
exactly. I just put in a built motor with turbo....
exactly. I just put in a built motor with turbo. OEM plugs.
Forum:
07-23-2019, 11:43 PM
21
5,059
Posted By
Tonrogs
Stick with OEM.
Stick with OEM.
Forum:
Forced Induction
07-21-2019, 12:06 PM
1,352
JDL turbo kit owners thread
547,462
Posted By
Tonrogs
did you check the aos to see if it also was full...
did you check the aos to see if it also was full of oil? If so, then the aos could be the cause, but I would still pull the charge pipe off the turbo to check for oil there. Its only 2 clamps.......
Forum:
06-27-2019, 07:08 PM
98
2013 FR-S Misfire and Rough Idle
24,295
Posted By
Tonrogs
I've stripped my motor apart and reassembled a...
I've stripped my motor apart and reassembled a couple times now. The biggest thing you need to worry about is cleaning the mating surface and also the inside edge surface well. That way the squeeze...
Forum:
Forced Induction
06-25-2019, 12:25 AM
37
Car revs to 4K and holds RPM -FBM
7,034
Posted By
Tonrogs
I would start by checking the ground cables. Make...
I would start by checking the ground cables. Make sure everything is connected as it should be. One below on each side of the heads. Another at the starter. Then the battery to the chassis. Check all...
Forum:
06-11-2019, 07:40 AM
7
Valve spring compressor
2,834
Posted By
Tonrogs
yes, heads are coming off.
Forum:
06-01-2019, 04:03 PM
32
I snapped bolt for Ignition Coil No. 1 - stupidity!!
4,639
Posted By
Tonrogs
I think the easiest way is what you already...
I think the easiest way is what you already figured out. Remove the valve cover and work it from there.
Forum:
04-21-2019, 02:50 PM
13
What is this part?
4,559
Posted By
Tonrogs
Part Number: 10921AA231 Vvt control...
Vvt control solenoid. It's not a sensor.
Forum:
03-03-2019, 11:47 AM
31
Jacking up car by tow hook - thoughts?
9,216
Posted By
Tonrogs
The bumper to which it attaches to has no...
The bumper to which it attaches to has no capability to hold a vertical load. You will crumple the soft areas which are meant to give under impact and bend your bumper upwards. I would not even...
Forum:
Forced Induction
02-19-2019, 08:26 AM
2
help installing MAC 3port electronic boost controler
680
Posted By
Tonrogs
Connects to the evap plug. Drivers side under...
Connects to the evap plug. Drivers side under intake manifold. Polarity doesn't matter. That is if you have ecutek or oft.
If you have a stand alone controller, then it connects to that.
Forum:
Engine, Exhaust, Bolt-Ons
01-12-2019, 04:45 PM
6
FS: FBM catch can, fuel pump, stock map, boost controllers
1,515
Posted By
Tonrogs
oh yeah! I'll get that updated shortly ...
DONE
Forum:
08-25-2018, 11:43 PM
3
Jackson Racing Dual Radiator/Oil Cooler + SS Lines
1,900
Posted By
Tonrogs
Pm'd
Pm'd
Forum:
Exterior Parts (Aero, Lighting, Etc.)
08-12-2018, 05:41 PM
12
K1X paint, 2016 BRZ white pearl, OEM shark fin antenna
3,481
Posted By
Tonrogs
Seller messaged not to send just as money was...
Seller messaged not to send just as money was sent. They refunded me along with my fees i paid to send the money. Honest seller! Hope other buyer enjoys the antenna!
Forum:
05-28-2018, 09:34 PM
19
header overpiper front piper need help
3,848
Posted By
Tonrogs
James @ HRI does a fantastic job.
Forum:
05-10-2018, 06:44 PM
7
Carbon driveshaft from DSS
3,450
Posted By
Tonrogs
TOSH86 is for manual trans TOSH87 is for auto...
TOSH87 is for auto trans
So you have the correct part number for a manual. I would definitely check with DSS and see what they say the length should be.
User Control Panel
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
2nd Gens: GR86 and BRZ
GR86 General Topics (2nd Gen 2022+ Toyota 86)
BRZ Second-Gen (2022+) — General Topics
1st Gens: Scion FR-S / Toyota 86 / Subaru BRZ
Scion FR-S / Toyota 86 GT86 General Forum
BRZ First-Gen (2012+) — General Topics
FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum
BRZ Photos, Videos, Wallpapers, Gallery Forum
Subaru BRZ
FT86CLUB Shared Forum
Member's Car Journals
FR-S / BRZ vs....
Regional Forums
Southern California
Northern California
NY / NJ / CT / PA
Mid-Atlantic
Southeast
New England
Southwest
Arizona
Northwest
Great Lakes
Rocky Mountains / Great Plains
Hawaii
CANADA
Canada Classifieds
EUROPE
AUSTRALIA
Australia Classifieds
Australian Meets & Events
NEW ZEALAND
SOUTH AMERICA / CARRIBEANS
ASIA
MIDDLE EAST
AFRICA
Technical Topics
Engine Swaps
Forced Induction
Software Tuning
Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack
Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Cosmetic Modification (Interior/Exterior/Lighting)
Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs)
Electronics | Audio | NAV | Infotainment
Tracking / Autocross / HPDE / Drifting
Marketplace
Commercial Classifieds
Official FT86CLUB Sponsors List
Announcements, Contests, Giveaways
Groupbuys
Forced Induction
Engine Swap
Transmission and Driveline
Wheels and Tires
Brakes, Suspension, Chassis
Exterior Parts - The Rest
Coating and Customization Services
Exterior Parts - Lighting
Interior Parts (Incl. Lighting)
Audio/Visual, Electronics, Infotainment, NAV
Cleaning and Detailing
Mechanical Maintenance and Tools
Dealer Cars
Miscellaneous
CANADIAN Sales
Members Classifieds
Wheels and Tires
Cars for Sale/Trade
Miscellaneous
FT86CLUB Items
Want-To-Buy Requests
User/Vendor/Sponsor Reviews, Feedback, Comments
Off-Topic Discussions
Other Vehicles & General Automotive Discussions
Off-Topic Lounge [WARNING: NO POLITICS]
Site Announcements / Questions / Issues
03:37 PM
Contact Us
Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB
Archive
Privacy Statement
Terms of Service/DMCA Policy
Top
User Alert System provided by
Advanced User Tagging v3.3.0 (Lite)
vBulletin Mods & Addons
Copyright © 2025 DragonByte Technologies Ltd.
vBulletin Plugins
by Drive Thru Online, Inc.
