Old 04-25-2020, 06:25 PM   #1
airrick
Drives: TRD R.S. 1.0 FRS
Putting back the transmission. Please help
Did a clutch change and all that. Hours and hours the transmission will not go back in. No matter how hard we try. Im spinning the driveshalf from the rear of the transmission. And its in 4th gear so still nothing it gets stuck on the studs on the bottom.
Theres no wires. The fork and the TOB seem to be fine. Dont understand
Update:
We got really close but the top had about a 1inch gap from meeting and bottom had about 1/2 gap from meeting.
Dropped the trans back down. Used the alignment tool to check and it only went in about 1 inch. We took out the clutch and noticed marks on the grooves/splines in the clutch. And then noticed fractures. 8 of them to be exact. Ughh
Lesson learned. Gonna use the old one sinche i still got 65% of it still on it.
Gonna give it a go tomorrow morning! ��
Update again: success!!! we finally got the trans in and everything. we pulled the clutch and all that and reinstall with the alignment tool again. thanks for all the help and advice! you guys rock!
airrick is offline   Reply With Quote
Old 04-25-2020, 06:52 PM   #2
ls1ac
ls1ac's Avatar
Did you use the alignment tool?
Old 04-25-2020, 06:59 PM   #3
airrick
Yes
Old 04-25-2020, 07:48 PM   #4
airrick
Someone? Please? For the life of my i cant. 2 days nothing.
Old 04-25-2020, 08:11 PM   #5
Grady
Grady's Avatar
did you use the plastic alignment tool? it will flex. if so loosen up the clutch and raise it a little.
Old 04-25-2020, 08:21 PM   #6
Code Monkey
Drives: Subaru BRZ
Did you jack up the front of the engine?
Code Monkey is offline   Reply With Quote
Old 04-25-2020, 09:15 PM   #7
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
When I did my clutch it was almost flush till half an inch.
I tried everything. What I eventually did was put in the bolts and slowly and evenly tightened them like lug nuts.
Sure enough it sat flush. Zero problems afterwards.
Old 04-25-2020, 09:32 PM   #8
ls1ac
ls1ac's Avatar
What you describe sounds like it is not going into the pilot bearing. You may half to back off the bolts for the clutch and recenter the tool by moving it around and slowly resetting the bolts. The plastic tools are not great.
Old 04-25-2020, 10:05 PM   #9
Kinda bored tbh
Kinda bored tbh's Avatar
Drives: 2016 brz
Hey man pm on here I’ve recently pulled my trans out like 2-3 times I’ll send you my number and can give you some tips on what to do maybe I can catch what ur doing wrong
Kinda bored tbh is offline   Reply With Quote
Old 04-26-2020, 12:30 AM   #10
airrick
Yes. I did.
Old 04-26-2020, 12:46 AM   #11
Ultramaroon
not playing cards
Ultramaroon's Avatar
Both guide pins are in place? If one fell out you'll never get it lined up.
gravitylover (04-27-2020)
Old 04-26-2020, 01:17 AM   #12
airrick
Im supposed to have 2 right? One on the trans and one on the engine side.
Old 04-26-2020, 01:43 AM   #13
airrick
Smile
I used the plastic alignment tool. I had to put back everything since i wanted to double check. Ill look at it again tomorrow
Yea i assumed this was it. Ill try it tomorrow morning. I did try it that. But ill try it again.
Old 04-26-2020, 01:47 AM   #14
Ultramaroon
not playing cards
They should both start out on the engine.
https://demos.starbase7.net/t3Portal...01P1500UX.html
SuperTom (04-26-2020)
FS: 2016 FRS Engine/Transmission 40 k miles Invidia cat back sokol Engine, Exhaust, Bolt-Ons 1 08-28-2019 10:55 PM
HKS full manifold-back exhaust for Automatic transmission? UNREAL Engine, Exhaust, Transmission 14 08-15-2019 11:37 PM
Thinking of putting back stock exhaust frsqc Engine, Exhaust, Transmission 31 07-31-2018 08:55 PM
Putting stock FP back on. Heat shield? Tysoncrosby21 Engine, Exhaust, Transmission 4 01-02-2017 04:02 PM
Can't get rid of TPMS light after putting OEM wheels back on customfab87 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 10-23-2016 04:54 PM
