Old 07-27-2019, 09:23 PM   #1
Opie
Opie's Avatar
Drives: 2000 Subaru Legacy B4 RSK (JDM)
P0453 - Anyone
Have a 2013 BRZ was a turbo car running E85, returned the car to stock and now get an immediate P0453 code. Evaporative Emission System Sensor Pressure to High. Code won't clear. Any ideas?
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 07-28-2019, 03:39 AM   #2
humfrz
You might try disconnecting the battery for a few minutes, then see if the code will clear.
humfrz
Old 07-28-2019, 09:13 AM   #3
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
Was your evap solenoid disconnected for a boost controller previously? Check to be sure you reconnected everything for it.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
The Following User Says Thank You to Tonrogs For This Useful Post:
Grady (07-28-2019)
Old 07-28-2019, 10:35 AM   #4
Grady
Grady's Avatar
That is what I was thinking.
Old 07-28-2019, 11:34 AM   #5
Opie
Opie's Avatar
Where is this located? I will check that.
Old 07-28-2019, 11:57 AM   #6
Tonrogs
take a look here....
http://www.ft86club.com/forums/showp...3&postcount=13
Old 07-28-2019, 02:27 PM   #7
Opie
Opie's Avatar
OK, checked that and all is connected properly. Had a spare evap solenoid so I swapped that and same code. Went through everything under the hood, vacuum lines, connectors, etc. everything is connected where it should be...I'm stumped.
Old 07-29-2019, 06:55 AM   #8
Boomerang
86
Boomerang's Avatar
Stupid question but did you change the tune back to stock?
Old 07-29-2019, 07:49 AM   #9
Opie
Opie's Avatar
Yes, Ecutek stock ROM
Old 07-29-2019, 11:00 PM   #10
Opie
Opie's Avatar
Looks like the ELCM is bad...have one on the way. Looks fun to change...since it's above the rear subframe...
Old 08-02-2019, 11:26 PM   #11
Opie
Opie's Avatar
Fixed it, it wasn't the ELCM, found a wire to the ECM that had been tapped for some reason by the previous owner and had a bad connection, repaired it and the CEL went off. So not an actual part failure, a wiring issue.
The Following User Says Thank You to Opie For This Useful Post:
humfrz (08-02-2019)
