Old 05-24-2018, 10:15 PM   #1
jayliu.jiayu@gamil.com
jayliu.jiayu@gamil.com's Avatar
Drives: 2017_86 2016_frs 2007_335i
header overpiper front piper need help
i am thinking to buy a equal catted header
i need the hp and torque increase in the higher rev around 4000-7000
i need some quick acceleration after 180 corner
my goal is with intake and full exhaust without tuning get 20-40 on hp and torque
had mxp rs ti tip catback on my 2017 Toyota 86 !
currently prefer
JDL Catted Equal Length Header - 2013+ FR-S / BRZ / 86
Motiv High Flow Cat Front Pipe & Overpipe
AFE POWER TAKEDA INTAKE SYSTEM (DRY) - 2013+ FR-S / BRZ
anyone has this setup ? and dyno info?
thx
jayliu.jiayu@gamil.com is offline   Reply With Quote
Old 05-25-2018, 08:11 AM   #2
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
If you dont tune you arent going to get anything. Well except a lean cel maybe
Breadman is offline   Reply With Quote
The Following 4 Users Say Thank You to Breadman For This Useful Post:
cjd (05-25-2018), jayliu.jiayu@gamil.com (05-26-2018), weederr33 (05-25-2018), wparsons (05-25-2018)
Old 05-25-2018, 08:40 AM   #3
cjd
cjd's Avatar
Drives: 2017 BRZ
That intake badly needs a tune, as does any header.
You your gains goal is only achievable with the very best setup (including a cat less header), tuning, and e85.
The Following 2 Users Say Thank You to cjd For This Useful Post:
jayliu.jiayu@gamil.com (05-26-2018), ssidd (06-19-2018)
Old 05-25-2018, 09:19 AM   #4
wparsons
wparsons's Avatar
Forget the intake, just get a drop in panel filter and save yourself a pile of money.
If your goal is max power, get the ACE 350 or clubsport header.
Like it's already been said, you're going to need a proper tune (tuned for the header you get) with any good header to really maximize the gains.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 05-25-2018, 04:21 PM   #5
86TOYO2k17
Drives: 2017 toyota 86
More max gains from 4-7k ace header is the way to go the 250 has a little more in that range, 350 has more below 4K and thus is most people’s choice. If you really want catted header for some reason JDL EL is a good choice, however ditch the cat in frontpipe, catted frontpipe is only to reduce smell/noise in catless header otherwise no point.
As far as intake goes drop in is best bang for buck, grimmspeed intake is pretty solid if you really want an intake.
If you can’t run E85 for whatever reason and don’t plan on going FI anytime soon Crawford billet blocks could be another option. (Doesn’t run well with FI or E85) but on NA pump gas it basically adds 5hp 5-6500k and loses 3hp 6500-redline. Overall an increase though.
Whatever setup you go a tune is almost 100% necessary, best bang for buck for HP gains. And makes your car drive better and more reliable.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Old 05-28-2018, 08:15 PM   #6
any recommend for tuning?
what r the step for tuning?
Old 05-28-2018, 08:34 PM   #7
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
James @ HRI does a fantastic job.
Tonrogs is offline   Reply With Quote
The Following User Says Thank You to Tonrogs For This Useful Post:
wparsons (05-28-2018)
Old 05-28-2018, 08:44 PM   #8
86TOYO2k17
If you have any local places that can do custom dyno tune with ecutek that would be ideal. Other wise check out delicious tuning and counter space garage. They have some good options / bundles with some quality ots tunes and can custom e-tune.
Old 05-28-2018, 09:23 PM   #9
86TOYO2k17
Here I’ll make it super easy for you. Go to counter space garage. Look for there DT ace header package. Under additional options add CSG mxp touring86 exhaust, ecutek license+cable, and ace Frontpipe. All for 3600$, can grab a flex fuel kit for another 595$ if u plan on going E85. This will net you the greatest NA gains and actually probably best bang for buck, quality, sound, customer service etc.
Old 05-29-2018, 03:13 AM   #10
thx will go for e tune
after i go my set up done
Old 05-31-2018, 03:24 AM   #11
FunnyGopher
Drives: 2015 BRZ Limited
I totally agree with this! (My opinion is in no way biased )
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 05-31-2018, 05:54 AM   #12
86TOYO2k17
Nice setup, curious if you have any before/after 0-60 or 1/4mile after the grams throttle body?
Old 06-01-2018, 03:38 AM   #13
still on the research stage
will post some info after i confirm my set up!
Old 06-01-2018, 06:52 PM   #14
tyler_win_photo
tyler_win_photo's Avatar
You're going to need to go catless to reach at least 20hp gain after a tune.
tyler_win_photo is offline   Reply With Quote
Piper Cam Selection bju90 Engine, Exhaust, Transmission 33 09-22-2020 10:47 PM
Piper Camshafts brn12345 Engine, Exhaust, Transmission 107 10-02-2017 10:28 AM
Piper Camshaft.. Walla Walla Engine, Exhaust, Transmission 5 05-12-2017 08:46 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
does it make a difference at all in hp from an invida over piper compared to motiv Anthony7515 Engine, Exhaust, Transmission 3 04-07-2014 10:26 PM
