Old 02-02-2021, 11:22 AM   #1
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
Perrin 3" Resonated - Going Turbo
Hey Guys. I have a few questions. I recently bought a 2020 BRZ PP.
Ordered a JDL Turbo kit (GTX2867R) with EL Manifold. I also plan on going with a full 3" exhaust system (tuner's recommendation). I have also ordered the resonated (single) over/front pipe combo from JDL and finishing it off with a 3" Perrin resonated catback system.
Since the JDL parts are 4 weeks out and the Perrin system was already in. I decided to put the system on and I do not like it. Remember I am currently fully stock.
At idle: the system is very close to stock, not obnoxious at all.
Going up in the revs: the system is deep but definitely has drone.
Going down in the revs: the system has uber high levels of drone.
My question: Will the system sound totally different after the turbo kit and over/front pipe are installed. Is there a chance all the drone is just due to having a 3" system on a stock header & front pipe???
If anyone has a turbo kit and is running the perrin system I would love to hear your feedback. Thank you in advance.
airindia33 is offline   Reply With Quote
The Following User Says Thank You to airindia33 For This Useful Post:
YSoAggressive (07-06-2021)
Old 02-02-2021, 11:49 AM   #2
Vital
Drives: 2015 BRZ
Interesting you might be the only person i know off that is experiencing drone from the Perrin exhaust either that or something is wrong with your install. Make sure everything is tight and check the vband connections.
Yes once you put the turbo it will sound different usually putting on a turbo quiets things down slightly ,but since you're installing an EL header and the OP/FP im sure it will have a good tolerable sound shouldn't be obnoxious. Im not running this setup so take my input with a grain of salt...
Vital is offline   Reply With Quote
The Following 2 Users Say Thank You to Vital For This Useful Post:
airindia33 (02-03-2021), YSoAggressive (07-06-2021)
Old 02-02-2021, 12:27 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
The car will sound different; a turbo is like a muffler. Just be patient and wait to see how it sounds
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Old 02-02-2021, 07:21 PM   #4
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
this.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
The Following 2 Users Say Thank You to Tonrogs For This Useful Post:
Old 02-03-2021, 08:33 AM   #5
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
Install is perfect. I will be patient and see how it sounds after all the other mods are on.
The Following 2 Users Say Thank You to airindia33 For This Useful Post:
Vital (02-03-2021), YSoAggressive (07-06-2021)
Old 02-03-2021, 12:09 PM   #6
Vital
Drives: 2015 BRZ
Yeah just wait and see how it goes. The other option is Invidia Q300 which is also supposed to be a quiet no-drone exhaust.
The Following User Says Thank You to Vital For This Useful Post:
Old 02-03-2021, 02:10 PM   #7
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
I am trying to stay at 3" all the way back based on my tuner's recommendation. I also don't mind moving to something louder as long as there is minimal to no drone.
This isn't my daily driver...
Old 03-26-2021, 10:32 PM   #8
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
Ok so update. Finally got my full JDL kit in last week and installed this week. The install was fairly straight forward and am very happy with the gains. Unfortunately the exhaust still has a horrible drone from 2750-3400...
Any other recommendations of exhaust systems?? Would like to stay 3” or 2.75”. Don’t mind louder as long as there isn’t drone.
Old 03-26-2021, 11:30 PM   #9
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Does the OP/FP have a CAT?
The Following User Says Thank You to x808drifter For This Useful Post:
Old 04-19-2021, 04:30 PM   #10
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
I have the same setup as you except I went with the dual res FP/OP. Personally its just right for me.
I've heard a slightly quieter catback is the CSG one but that does step down to 2.75"
https://www.counterspacegarage.com/c...tition-exhaust
Heres a quick dyno pull with my exhaust
2017 Subaru BRZ PP
FBM Turbo Kit: GTX3076R - HRI FlexFuel Tune - 3" Turboback Exhaust - ID1000cc Injectors - Walbro 485 Fuel Pump - FBM Oil Pan - FBM Oil Cooler - Killer B Oil Pickup - FBM Catch Can - FBM Radiator w/Fan Shroud - Clutch Masters FX400 - Verus Clutch Fork/Pivot - IRP Shifter - Cusco Engine/Trans Mounts - RCE Yellow Springs - PS4S 245/40/17
MotoX16 is offline   Reply With Quote
The Following 2 Users Say Thank You to MotoX16 For This Useful Post:
airindia33 (04-30-2021), YSoAggressive (07-06-2021)
Old 04-19-2021, 04:52 PM   #11
Chuckls
Moutain Runner
I currently have the perrin 3inch on my turbo BRZ. No resonators in my "front pipe"
3400 rpm does have some drone, but it's much better than my Tomei I previously had
Chuckls is offline   Reply With Quote
The Following User Says Thank You to Chuckls For This Useful Post:
Old 04-20-2021, 01:56 AM   #12
jflogerzi
jflogerzi's Avatar
Get the CSG Touring 86 by MXP. The minor step down in size wont restrict till 400WHP.
2013 Series 10 FRS #553
The Following 3 Users Say Thank You to jflogerzi For This Useful Post:
airindia33 (04-30-2021), Plumbus (04-21-2021), YSoAggressive (07-06-2021)
Old 04-20-2021, 07:27 AM   #13
DarkPira7e
DarkPira7e's Avatar
Can you post a video for audio?
The Following User Says Thank You to DarkPira7e For This Useful Post:
Old 06-22-2021, 06:21 PM   #14
SumDizzy
Drives: Silver 2018 Toyota 86 GT
Have you checked out https://www.ft86club.com/forums/showthread.php?t=143514 ? This might fix or at least alleviate the problem, people seem to comment on the fact that this fix removes resonating noises around the 3k RPM mark which is what you're facing.
I also installed the same catback (Perrin 3" Resonated) this weekend and am getting a lot of cabin noise and drone, especially when cruising at those rpms. I can't say for sure this will fix my problem as my front pipe has a blown out cat. Already ordered the hangers and should get a new front pipe soon
SumDizzy is offline   Reply With Quote
The Following User Says Thank You to SumDizzy For This Useful Post:
FS: Perrin 3" Catted Front Pipe + Perrin 3" Resonated Cat Back projek_01 Canada Classifieds 3 01-26-2018 11:32 PM
WTT: Perrin 3" Catted Front Pipe + 3" Perrin Resonated Exhaust for 2.5" Setup projek_01 Canada Classifieds 3 03-03-2016 02:45 PM
TRADE perrin 2.5" non resonated catback for resonated otterpop Southeast 0 01-22-2015 11:14 PM
Looking to trade resonated 3" Perrin CB for resonated 2.5 Perrin CB Sacramento Area Brinks Northern California 4 07-22-2014 11:58 PM
Looking to trade resonated 3" Perrin CB for resonated 2.5 Perrin CB Sacramento Area Brinks Engine, Exhaust, Bolt-Ons 6 07-22-2014 11:58 PM
