Old 07-11-2020, 11:05 PM   #393
FunnyGopher
Drives: 2015 BRZ Limited
Originally Posted by FunnyGopher View Post
Hiya everybody!
I recently ordered this from CSG, and I love it! However, I got to one of the last steps where I install the airbox back into the car. I ran into a problem where the AN fitting that's welded to the top of the radiator, when looking at it straight down from the front of the car, is angled about 20 degrees to the left. It's preventing the OEM airbox from sitting where it needs to to install it back in the car. If it had been welded perpendicular to the radiator, I believe there'd be enough clearance for the box to fit right. I don't know if this fitting is just welded incorrectly, or if I'm missing something. What does this fitting look like on other's radiators?
Leaving an update on this situation. JR has sent me a new radiator, claiming the pipe must have bent during shipping. I will be installing the radiator tomorrow and will take some comparison pictures. I'll update here again when I know more.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
FunnyGopher is offline   Reply With Quote
Old 07-11-2020, 11:20 PM   #394
jflogerzi
jflogerzi's Avatar
That's great customer service by JR. Qudos to them. For a heavy street or light track duty this thing works very well
2013 Series 10 FRS #553
Old 07-13-2020, 10:26 PM   #395
FunnyGopher
Yeah, I'm very impressed with it so far. Installed it last night, drove home at 2:30am (still in 100 degree heat, thanks AZ), and my oil temps were chillin' at a nice 203F. Before it was have stabilized around 225F. Works wonderfully.
Side note, this isn't mentioned anywhere, nor could I find any instructions or forum posts about it, but I tried to find if the coolant capacity was greater for this tank. The OEM tank is 1 gallon, the JR radiator takes like, ~1.5 gallons.
The Following User Says Thank You to FunnyGopher For This Useful Post:
jflogerzi (07-13-2020)
Old 07-13-2020, 10:37 PM   #396
jflogerzi
jflogerzi's Avatar
Mental note added. Thanks for sharing that.
Old 07-14-2020, 01:31 AM   #397
ls1ac
ls1ac's Avatar
Did you take any pictures during the install?
Old 07-18-2020, 12:32 PM   #398
deca
Drives: Halo 860
Just ran my first event with this installed and I am really impressed with its performance! Previously at Waterford Hills I would hit 255-260 after two hot laps and have to cool down for another lap and a half or so to get it under 240. Yesterday was around 90F ambient and I think the highest temp I actually confirmed was 233. It was sitting at 230 almost every time I looked at it and dropped from there much quicker as soon as I would back off. I was able to get so much more out of my track time running flat out for my entire heats.
I do have one question involving my installation however. I seem to be getting some minor rubbing/melting on the back of my air box against the closer AN fitting. I compared my positioning to a friend at the track who had also just installed the cooler and while the clearance looked to be the same they weren't getting any contact. I'm going to try to reposition the adapter plate and fitting for a little more clearance but I'm not sure how much more I can really get.
deca is offline   Reply With Quote
Old 07-18-2020, 02:20 PM   #399
new2subaru
Weight Weenie
Drives: 15 FR-S
If it's just touching the small plastic "reinforcing tabs" you can grind them down a bit.
Old 07-18-2020, 02:44 PM   #400
new2subaru
Weight Weenie
Drives: 15 FR-S
Pic. looks like it could use more work
Old 07-18-2020, 02:58 PM   #401
deca
Drives: Halo 860
My clearance is very tight down there, but that's not actually what I was referring to. The contact I'm seeing is at the top of air box against the AN fittings coming off of the sandwich plate.
Old 07-18-2020, 03:38 PM   #402
new2subaru
Weight Weenie
Drives: 15 FR-S
You should be able to turn it a bit
Old 07-18-2020, 03:49 PM   #403
new2subaru
Weight Weenie
Drives: 15 FR-S
You can see the gap here
Old 07-18-2020, 06:33 PM   #404
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
Just move your upper bracket forward
Simply move your 2 upper radiator brackets forward for an extra half inch of clearance. You will end up putting 1 bolt in each bracket. Move the bracket forward and align the rear bracket hole with the front hole in the support.
I did this to create a little extra room with my turbo setup and the Jackson dual radiator. Here is a crappy pic I just took showing it moved forward and utilizing just 1 bolt.
For some dumb reason the pic is showing upside down.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
The Following User Says Thank You to Tonrogs For This Useful Post:
new2subaru (07-18-2020)
Old 07-18-2020, 09:23 PM   #405
deca
Drives: Halo 860
Ah, I have a 2017 car with the new airbox, it's considerably larger than the older ones and doesn't have that little angle on the corner near the oil filter and cap.
Oh interesting! I hadn't considered this at all, I'll have to look at it.
Old 07-18-2020, 10:16 PM   #406
FunnyGopher
My update! The new radiator let the airbox fit much better. I'll attach a couple pics of both of them from fairly the same angle. The one installed in the car is the bad one. A good point of reference for the pictures is the fan shroud bolt.
I did not take any pictures. I was focused on getting it done before the next morning!
The Following 2 Users Say Thank You to FunnyGopher For This Useful Post:
ls1ac (07-18-2020), new2subaru (07-18-2020)
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 05:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 11:26 AM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 02:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 11:04 AM
