Old 03-02-2019, 10:38 PM   #1
x_hawker
Drives: 2013 FR-S 10-Series
Location: SJ/OC/IE California; Temporarily: Glendale,AZ
Jacking up car by tow hook - thoughts?
Hello everyone,
Does anyone here jack their car up from their tow hook? For example, installing a solid tow hook and using that to jack the car up? A significant number of us did that with the S-chassis and I was wondering if anyone here does it, especially if you can't fit the jack under the front end, jacking it up from the tow hook saves a lot of time. I was thinking one could just install a tow hook (or even the Perrin licence plate relocator) and jacking it up from there.
Looking forward to hearing your thoughts and to see if anyone does do that.
x_hawker is offline   Reply With Quote
Old 03-02-2019, 10:56 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
i don't think that's a good idea. no different than lifting yourself out of bed by your ears every morning.
Old 03-02-2019, 11:07 PM   #3
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
This sounds like a great way to become a Darwin Award recipient.
LimitedSlip is offline   Reply With Quote
Old 03-02-2019, 11:17 PM   #4
soundman98
soundman98's Avatar
i just wouldn't trust a bar of steel, extended off the crumple zone structure-- that is specifically meant to fold when subjected to force, to take 2/3's of the cars weight...
Old 03-02-2019, 11:38 PM   #5
x_hawker
I was thinking the same thing since with the S-chassis, the tow hook was attached to the frame. I agree and don't think it would be a good idea in this case.
Thanks for the replies everyone.
Old 03-03-2019, 01:40 AM   #6
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Try it report back.
I would think it might work once or twice. Then it would just bend at some point.
The tow hook area was meant for horizontal forces, not vertical forces. But eh. Can't say it's proven.
Old 03-03-2019, 09:23 AM   #7
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I had a friend do that on a 240sx bc everywhere else was rusty. It eventually bent sideways. Those cars are so flimsy.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 03-03-2019, 10:06 AM   #8
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Drive onto some 2x6 planks of wood first, then get your jack under the front jacking point.
Old 03-03-2019, 10:47 AM   #9
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
The bumper to which it attaches to has no capability to hold a vertical load. You will crumple the soft areas which are meant to give under impact and bend your bumper upwards. I would not even attempt it. These areas are quite flimsy.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
Old 03-03-2019, 11:01 AM   #10
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Don't be lazy and do it the right way lol.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-24-2019, 12:21 AM   #11
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
you can buy some nice low profile ramps on ebay for under 50 bucks, or just use some 2x6 or 2x8 boards if you're really strapped for cash.
This car isn't a 240sx...don't treat it like one (former 240sx owner speaking here)
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 03-24-2019, 01:33 AM   #12
e1_griego
e1_griego's Avatar
Drives: Many
I use the oem tow hook in front to lift the car enough to get a jack under the front crossmember.
Also been doing it with my 240sx for a number of years with no problems.
e1_griego is offline   Reply With Quote
Old 03-24-2019, 02:18 AM   #13
FirstWinter
Drives: Car
My quick and easy way especially if car is lowered is to jack from the sides under the pinch weld. Otherwise use wooden planks. I would strongly advise against using the tow hook as a jacking point.
FirstWinter is offline   Reply With Quote
Old 03-24-2019, 10:59 PM   #14
ka-t_240
I use the pinch welds most of the time, I buy some hockey pucks and cut them in the center to put between the jack and pinch welds, and they still look like new.
Never used the tow hooks to to jack up an S-Chassis. Didn't know it was a thing, and I have owned 13 of them.
ka-t_240 is offline   Reply With Quote
Jacking points? bleox Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 36 02-19-2016 01:03 AM
Jacking points Qwimby2 BRZ First-Gen (2012+) — General Topics 4 12-08-2015 09:48 PM
Jacking a lowered BRZ/FRS? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 03-19-2013 02:04 AM
Track Tow Hook R&D Thoughts and Comments (Pictures) NON-VTEC Scion FR-S / Toyota 86 GT86 General Forum 24 02-06-2013 10:06 AM
Car Jacking up Points? J-Money Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 01-21-2013 02:55 PM
