Old 06-10-2019, 09:15 PM   #1
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
Valve spring compressor
Anyone have a recommended valve spring compressor for the fa20?
Im going to replace my valve stem seals. Currently have Ferrea 6000 +1mm valves. I've done them before on other engines, just need a good recommendation for a tool that works well on the fa20.
Thanks!
Tonrogs is offline   Reply With Quote
Old 06-10-2019, 11:00 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
I'd get the tools they use for the recall. They're pretty sweet.
Old 06-10-2019, 11:48 PM   #3
Lantanafrs2
Drives: 2013 frs red
Are the heads coming off? If not, the factory tool, as ultramaroon says, is nice.
Old 06-11-2019, 12:22 AM   #4
Ultramaroon
not playing cards
I figure head goes face down with a little piece of cardboard under the dome. Still better than those vice-grip things.
Old 06-11-2019, 07:40 AM   #5
Tonrogs
yes, heads are coming off.
The Following User Says Thank You to Tonrogs For This Useful Post:
Lantanafrs2 (06-11-2019)
Old 06-11-2019, 09:17 AM   #6
Lantanafrs2
That gives you options. Old "c"clamp style will work in that case also.
Old 06-11-2019, 09:55 AM   #7
maslin
Benz Tech
Drives: 2017 BRZ Premium
The c clamps are a pain. My favorite tool to use was a GM special tool, 2 towers with a bar across and a lever to press down. 5 minutes and they’re all off.
Can’t find a picture of the actual tool, the towers were really nice milled aluminum. Plenty of aftermarket sets out there that look the same.
maslin is offline   Reply With Quote
The Following 4 Users Say Thank You to maslin For This Useful Post:
fika84 (06-12-2019), Lantanafrs2 (06-11-2019), Tonrogs (06-11-2019), Ultramaroon (06-11-2019)
Old 06-11-2019, 06:23 PM   #8
Tonrogs
I just ordered one just like this. Thanks!
A simpler spring/strut install DIY -- no compressor needed jeebus DIY (Do-It-Yourself) Guides 120 01-17-2023 10:28 AM
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 04:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
