Drives: GT86 Nur spec
spark plugssss quick question
after a long track day today, I figured out that my OEM sparkplugs were ready to be replaced.
My question is, I was willing to replace them with HKS m45hl spark plugs! so would I need to tune my car or it's fine and will work perfectly? |
Drives: '14
Why not just stick with OEM? Even twins with 400hp+ uses OEM.
| The Following User Says Thank You to kev0 For This Useful Post: | wparsons (07-26-2019) |
Drives: brz 2017 hksv2
do not change from oem if you aren t FI
and even if you are FI, do not change them if you aren t tracking it really hard |
How many miles on your original plugs?
How do you figure they need replaced? humfrz |
Drives: 2014 BRZ Limited, Satin White Pearl
Stick with OEM.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Thanks for the response guys i think ill stick with oem until i put on my turbo kit.
#7 | |
Stick with OEM until your engine builder and/or tuner tells you to run something different. Just because you're adding a turbo doesn't mean you need different plugs.
exactly. I just put in a built motor with turbo. OEM plugs.
Drives: 2017 PP BRZ
I am running HKS! I would get them.
#10 |
ProCrastinationConsultant
sparkplugs are a voodoo art. unless you're on a very custom tune, and inspecting plugs after every run, it's better to stick with stock.
when i was a teenager, i knew better on how to maintain my chrysler lebaron than my grandfather, who was a chrysler service manager for 40 years, the last 10 years of which were when the lebaron existed. so despite everything he said, i installed splitfires for MORE POWAH. the car barely ran, tried everything for 2 days trying to get it to stay idling. changed for the oem-spec champion plugs and it ran fine ever after. don't deviate on plugs unless you know what you're doing, especially on these cars because the plugs are so hard to get to!
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | humfrz (07-28-2019), Lantanafrs2 (07-27-2019) |
#11 |
Drives: 2015 BRZ Limited
This is no joke. I spent $86 (ha!) on new OEM plugs to replace my current ones after 60k miles. I've done all the other work to my car myself, so I wasn't about to change my ways with the spark plugs. I knew what I was getting into, especially knowing I wasn't in a position to lift the engine out of the car far enough, but I didn't know the extent. Took me ~11 hours overall. Now I was in no rush by any means, but the first plug took me nine hours, and the other three plugs took the remaining two hours. The combination of socket extensions that had to be used in a very specific order to get the plugs on and off because of the lack of room, holy carp.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
| The Following User Says Thank You to FunnyGopher For This Useful Post: | soundman98 (07-27-2019) |
#12 |
Drives: 2013 frs red
Aren't you glad they chose the balance of an underpowered flat four?
#13 | |
#14 | |
![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | sato (07-28-2019), soundman98 (07-28-2019) |
| Alignment Shop in SD and quick question question | JohnTran619 | Southern California | 5 | 11-21-2018 01:40 PM |
| Question about spark plugs, oil, and super charger | VeganGirl | Forced Induction | 15 | 11-09-2016 11:01 PM |
| Quick Question | trsiidno | Forced Induction | 7 | 01-09-2015 09:48 AM |
| Spark plug question | Wilsonk227 | BRZ First-Gen (2012+) — General Topics | 19 | 07-03-2013 12:57 AM |
| New guy with a quick question | Bullnettles | Engine, Exhaust, Transmission | 28 | 05-09-2013 12:03 AM |
