Old 06-01-2019, 01:39 PM   #1
Open Loop
2013 FR-S Whiteout / SSC
I snapped bolt for Ignition Coil No. 1 - stupidity!!
So this morning I was rushing to change ignition coil no. 1 (front passenger side) and when I went to put the ignition coil bolt in, I grabbed one of the three bolts used to hold the ECU on the side of the engine, and of course it is longer than the ignition coil bolt, and long story short, I snapped off the bolt.
My question is this: One way to handle this would be to pick up the engine a few inches so I can drill a small hole in the broken bolt and use an EZ-Out to get it out. Another way, I suppose, would be to remove the valve cover and then deal with the broken bolt. I am interested in your thoughts as to how I should go about fixing this.
Open Loop is offline   Reply With Quote
Old 06-01-2019, 01:59 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Time for a V8.
Old 06-01-2019, 02:01 PM   #3
Grady
Grady's Avatar
I do not see how vegetable juice will help the situation?
Old 06-01-2019, 02:30 PM   #4
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
So you snapped the bolt from the ecu bracket and not ignition coil? If that's the case then it's fine. Keep 1 bolt at the bottom and 1 at top for balance
Dr. BRZ is offline   Reply With Quote
Old 06-01-2019, 02:30 PM   #5
Open Loop
I am a bit thirsty AND hungry. But I still want to get the bolt out.
Old 06-01-2019, 02:33 PM   #6
Open Loop
I snapped an ecu bolt in the bolt hole for the coil. I'm not concerned with re-bolting the ecu. I am concerned with not being able to hold the coil down with a bolt, because the coil bolt hole is currently filled with a broken bolt.
Old 06-01-2019, 02:48 PM   #7
humfrz
You might try JB Weld and a prayer -
humfrz
Old 06-01-2019, 02:54 PM   #8
Lantanafrs2
Drives: 2013 frs red
Does the coil snap onto the plug?
Old 06-01-2019, 03:03 PM   #9
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
I think the easiest way is what you already figured out. Remove the valve cover and work it from there.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
Old 06-01-2019, 03:57 PM   #10
Open Loop
Friction is holding it in place for now, but i'd like a real fix.
That is what I am leaning toward. Thank you.
Old 06-01-2019, 05:11 PM   #11
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
If you want to go some drastic, you can use a 1" hole saw, cut horizontal on the fender the. You'll have enough room to use a drill out.
That's my guess anyway.
Old 06-01-2019, 05:55 PM   #12
soundman98
ProCrastinationConsultant
soundman98's Avatar
It's torqued to the bottom of the hole, an ez-out is going to neither ez or get it out.
Your only option is to drill the majority of the bolt out to remove the tension and chase the threads.
Old 06-01-2019, 06:33 PM   #13
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Are you sure the engine will even run? The ECU bolts don't just hold the ECU in place. Pretty sure one is a ground. Just saying you will want to get a new bolt soon for that of the correct size.
Old 06-01-2019, 06:45 PM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
It's torqued to the bottom of the hole, an ez-out is going to neither ez nor get it out.
fifm
OP, remove the valve cover no matter what. Take it to a machinist who will have much better luck with it.
Broken ignition coil bolt UNCC_BRZ Engine, Exhaust, Transmission 9 03-19-2019 10:19 PM
Ignition Coil A CEL Whats that smell? Issues | Warranty | Recalls / TSB 12 10-10-2016 01:09 PM
So I snapped the OEM camber bolt. Rifle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 03-09-2016 08:18 PM
strut brace bolt snapped frs10 Issues | Warranty | Recalls / TSB 19 10-31-2013 02:37 PM
strut brace bolt snapped-need help frs10 Issues | Warranty | Recalls / TSB 9 10-20-2013 01:29 AM
