Old 02-10-2018, 08:12 PM   #1
Whiskerz
Drives: 2014 86 GTS
Is my logging broken or is something seriously wrong (really high FLKC and IAM)
Have a look at this:
https://datazap.me/u/whiskerz/86-gts...&data=1-2-6-11
Running stage 1 OTS from OFT. In Australia using 98 RON.
I don't know much about logging/tuning but I have not seen anyone else with FLKC and IAM numbers so high. Whats going on?
Also look to be running a little rich, right?
Whiskerz is offline   Reply With Quote
Old 02-10-2018, 09:26 PM   #2
Boomerang
86
Boomerang's Avatar
Looks OK
Logging doesn't work on some newer ROM's, what is your Calid(e.g. A01G, D00G)?
Your IAM is 0 indicating your log isn't working, you must be looking at ignition adv thinking that is IAM
You AFR and command AFR are pretty good
Lots of help on here if you need it, just ask
Bonza
Old 02-10-2018, 10:23 PM   #3
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Logging is broken, and it's running lean. Update the template for the tablet or whatever else is the fix these days.
Old 02-10-2018, 11:11 PM   #4
Whiskerz
Drives: 2014 86 GTS
Originally Posted by Boomerang View Post
Looks OK
Bonza
It's D00G, and yeah I was looking at ignition adv. Thanks
I'll have a look into fixing the tablet. Do you know what would make it run lean, considering its a stock car with a drop in filter and tune? Thanks
Old 02-10-2018, 11:20 PM   #5
Boomerang
86
Boomerang's Avatar
So I have D00G as well.
My work around is running an A01G as a D00G thanks to Wayno and Steve99, so all logging works now. And FFS and launch control!
You will need to scale your MAF to get the fuel trims good(e.g. not lean)
I had a break from fine tuning mine and just ran E85 which has no knock and solid 1 IAM always, and more power!
Follow Steve99 's links in his signature and all will be revealed!
Old 02-11-2018, 03:31 PM   #6
steve99
Drives: FT86
I think your only fix will be to run an A01G rom altered to look like D00G the logging on D00G is still not working
Old 02-11-2018, 06:30 PM   #7
Whiskerz
Drives: 2014 86 GTS
So from what I've read the easiest way to achieve this would be to buy one of Wayno's ROMs? From what I can tell it looks like a better tune and I get logging and can follow his tips to dial it in.
Also looks like if I wanted I could unmarry and sell my OFT and buy a tactrix cable and use that to flash Wayno's ROMs, which would be a cheaper option. And then I can just flash a A01G ROM and it will work with tactrix? Can anyone confirm that this is how it works and if its a good idea?
Old 02-11-2018, 06:56 PM   #8
steve99
Drives: FT86
you can flash those roms with OFT or tactrix.
Old 02-12-2018, 02:29 AM   #9
Whiskerz
Drives: 2014 86 GTS
Okay thanks, I was under the impression that OFT files were different somehow to work with the tablet.
I think I've decided to go the tactrix way with Wayno's roms, seems like I can make some money selling the OFT, buy the cheaper tactrix and end up with a better flashing/logging system and a better tune by the looks of it.
FLKC in high gears (e.g track). What is acceptable? Tor Software Tuning 61 11-02-2017 08:24 AM
-5 degrees flkc on oft stage 2 uel Texas2016Frs Software Tuning 18 11-05-2016 07:09 PM
Positive FLKC? BFIFE22 Software Tuning 7 09-26-2016 04:25 PM
High negative FLKC values on the highway RIP.S2000 Software Tuning 4 12-18-2015 10:36 PM
OpenFlash Tablet: Multi-Gauge Function and FLKC logging Shiv@Openflash Software Tuning 52 05-08-2014 08:30 PM
