Is my logging broken or is something seriously wrong (really high FLKC and IAM)
Have a look at this:
https://datazap.me/u/whiskerz/86-gts...&data=1-2-6-11 Running stage 1 OTS from OFT. In Australia using 98 RON. I don't know much about logging/tuning but I have not seen anyone else with FLKC and IAM numbers so high. Whats going on? Also look to be running a little rich, right? |
Looks OK Logging doesn't work on some newer ROM's, what is your Calid(e.g. A01G, D00G)? Your IAM is 0 indicating your log isn't working, you must be looking at ignition adv thinking that is IAM You AFR and command AFR are pretty good Lots of help on here if you need it, just ask Bonza |
Logging is broken, and it's running lean. Update the template for the tablet or whatever else is the fix these days.
My work around is running an A01G as a D00G thanks to Wayno and Steve99, so all logging works now. And FFS and launch control! You will need to scale your MAF to get the fuel trims good(e.g. not lean) I had a break from fine tuning mine and just ran E85 which has no knock and solid 1 IAM always, and more power! Follow Steve99 's links in his signature and all will be revealed! |
I think your only fix will be to run an A01G rom altered to look like D00G the logging on D00G is still not working
So from what I've read the easiest way to achieve this would be to buy one of Wayno's ROMs? From what I can tell it looks like a better tune and I get logging and can follow his tips to dial it in.
Also looks like if I wanted I could unmarry and sell my OFT and buy a tactrix cable and use that to flash Wayno's ROMs, which would be a cheaper option. And then I can just flash a A01G ROM and it will work with tactrix? Can anyone confirm that this is how it works and if its a good idea? |
you can flash those roms with OFT or tactrix. |
I think I've decided to go the tactrix way with Wayno's roms, seems like I can make some money selling the OFT, buy the cheaper tactrix and end up with a better flashing/logging system and a better tune by the looks of it. |
| All times are GMT -4. The time now is 05:26 PM. |
User Alert System provided by
