Old 11-03-2016, 01:24 PM   #1
Texas2016Frs
Bottled FRS
Drives: 2016 manual frs
-5 degrees flkc on oft stage 2 uel
Flkc constantly stays at -5.00 degrees. Is this a logging issue or is my car knocking like hell? On stage 2 uel with OFH.
EDIT: When looking at the data log it does change from -5.xx to -5.xx
Texas2016Frs is offline   Reply With Quote
Old 11-03-2016, 01:53 PM   #2
renfield90
The Stig's German cousin
What's IAM look like? Post logs with all parameters you're currently logging.
Old 11-03-2016, 03:07 PM   #3
Kodename47
Kodename47's Avatar
Drives: UK GT86
If its all the time with no change, wrong logging address for the ROM type.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-03-2016, 04:33 PM   #4
Synkopy
Dragon King of Jupiter
Drives: 2016 BRZ Hyperblue
If it stays on -5 constantly. It's not even really logging it. Mine was the same way until I updated the oft template. Email them and get the new template file. Easy to update using openflash manager
Synkopy is offline   Reply With Quote
Old 11-03-2016, 04:57 PM   #5
Texas2016Frs
Bottled FRS
http://datazap.me/u/texas2016frs/sta...?log=0&data=11
Old 11-03-2016, 08:25 PM   #6
phrosty
Yea something definitely off, make sure you upgrade your template file.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 11-03-2016, 09:09 PM   #7
renfield90
Yup, pretty sure you're logging the wrong RAM addresses somehow.
Old 11-04-2016, 05:00 AM   #8
aagun
Drives: 86
i think u have air leak . check STFT
aagun is offline   Reply With Quote
Old 11-04-2016, 01:50 PM   #9
Texas2016Frs
Bottled FRS
STFT was logged during the log I posted
Old 11-04-2016, 02:42 PM   #10
wparsons
wparsons's Avatar
What gas are you running? It's logging knock pretty consistently anytime there's some timing advance.
The original post was misleading, it's staying at -5 or worse, but is changing.
flickr
Old 11-04-2016, 02:56 PM   #11
Texas2016Frs
Bottled FRS
Sorry during the real time data logging it was pinned at 5.00 but After taking the log it is clear that it is monitoring something. I still think it's the wrong parameter though
I'm running 93 octane from shell
Old 11-04-2016, 04:27 PM   #12
wparsons
wparsons's Avatar
IAM is stuck at 0, and the knock definitely increases when you're into the throttle.
It's either logging the wrong channels, or it's picking up false knock events when you're on the gas, or it really is knocking that much.
What's a full list of mods done to the engine (including intake, pulleys, etc)?
flickr
Old 11-04-2016, 05:03 PM   #13
Texas2016Frs
Bottled FRS
Only mods done to the engine are open flash headers and open flash tablet stage 2uel tune. Even on stage one with no other engine mods I had logging issues with IAM can't recall if it was also with flkc.
@steve99 @Wayno could either of y'all chime in on this
Old 11-04-2016, 06:59 PM   #14
phrosty
Can you verify that your OFT template is 100% up to date?
flkc, oft, tuning
Positive FLKC? BFIFE22 Software Tuning 7 09-26-2016 04:25 PM
College Degrees? MrFisty Off-Topic Lounge [WARNING: NO POLITICS] 281 06-21-2016 12:53 AM
2 degrees of camber up front? Scuba86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 01-14-2016 02:20 PM
Rubbing noise at ~70 degrees steering both ways 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 06-30-2015 08:13 PM
29 degrees F in Texas--near sea level elevation dave77 Scion FR-S / Toyota 86 GT86 General Forum 28 01-06-2014 12:57 PM
