Old 09-25-2016, 10:21 PM   #1
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
Positive FLKC?
While driving the other day with my OFT on, I noticed there were a couple points where the FLKC value was in the positive between .35 and .65 and at a brief point it went past 1. IAM was at 1.00 the whole time, so it wasn't the ECU trying to recover the IAM back to 1.00 after pulling some timing due to knock.
Is there any reason why the car would randomly advance timing like that? Or has the timing been pulled too much in that load/rpm area by the tune and the car is just compensating?
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
Old 09-25-2016, 11:28 PM   #2
makinen
makinen's Avatar
Drives: Toyota 86
The latter.
Those cellls could have benefit by advancing the amount of FLKC values.
makinen is offline   Reply With Quote
Old 09-25-2016, 11:35 PM   #3
phrosty
I've never seen positive FLKC with an IAM of 1.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 09-25-2016, 11:36 PM   #4
steve99
Sounds weird that iam=1 and getting positive flkc
maybe logging issue.
what is rom calid ?
can you post log to www.datazap.me
not really possible unless you have done something really weird like changing the flkc correction retard value to positive value in tune instead of negative. this will make ecu ADD timing on knock detections instead of retarding timing
Old 09-26-2016, 02:57 AM   #5
fibble
Drives: 2015 86 GTS
I'm with Steve.
Sounds fishy...... I also suspect logging issue.
How did you know that IAM was 1 at that time?
fibble is offline   Reply With Quote
Old 09-26-2016, 05:42 AM   #6
BFIFE22
BFIFE22's Avatar
Originally Posted by fibble View Post
I'm with Steve.
I use the display where you have 3 parameters displayed in large numbers, and have FLKC, IAM, and Oil Temp displayed. Once OFT made the alert sound I glanced at it and IAM was 1.00 the whole time it said I had positive FLKC
I've never seen it do this before, and I have had this tune on my car for months, so maybe it is a logging/display issue.
If I notice it again I'll try to repeat the result and record it on the OFT
Old 09-26-2016, 08:29 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
I think the FBKC and FLKC retard value settings are absolute and therefore doesn't matter if positive or negative. I know there are some values to do with ignition retard that are like this.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-26-2016, 04:25 PM   #8
steve99
Mr Merchgod reckons its possible, was in subbie legacy ecu but I suspect logic similar to ours.
http://legacygt.com/forums/showthrea...html?p=2457316
http://legacygt.com/forums/showpost....0&postcount=24
Negative FLKC but IAM stays at 1 Tectoniic Software Tuning 6 01-10-2016 04:33 AM
High negative FLKC values on the highway RIP.S2000 Software Tuning 4 12-18-2015 10:36 PM
FS: Whiteline bushings KDT926 (Positive shift kit) & KDT922 (Positive traction kit) Tim_Asphalt_FRS Transmission and Driveline 3 09-26-2014 11:41 AM
OpenFlash Manager v1.08.3 now available for download (FLKC) Shiv@Openflash Software Tuning 120 06-22-2014 07:34 PM
OpenFlash Tablet: Multi-Gauge Function and FLKC logging Shiv@Openflash Software Tuning 52 05-08-2014 08:30 PM
