Drives: 2015 BRZ Series.Blue, ('00 S2000)
High negative FLKC values on the highway
My motor and tune is stock, but I use the OFT to monitor IAM, FLKC, etc. It's about 50 degrees F tonight, and I'm getting negative FLKC values up to ~1.2 when moderately accelerating on the highway (throttle about half way). My IAM will stay at 0.70 and try to climb back up if I go WOT at high RPMs, but once it gets to ~0.90, negative FLKC kicks it back down.
I'm not sure if the gas I'm using isn't really 93 octane, or if there's something else wrong. I just had the front cover replaced because it was leaking oil, so they had to "re-silicone" it. I'm not sure if it's even related. The oil temps were around 212 F and coolant around 200 F. I wasn't able to log it as the traffic was really hectic, and I was in a hurry. I'm paranoid, guys. I'd be grateful for any insight. I'm about to use the stage 2 tune after I put on my headerback exhaust, but I'm afraid to do it if there's anything wrong internally. I don't wanna fight with Subaru. |
Drives: Toyota 86 GTS
Working as intended.
Drives: JAWS
Well you COULD try some different 93 octane near you, but you're fine either way.
When you load the stage 2 tune, load the 93 octane tune, and if it's knocking in high RPM, you can try the 91 octane tune. The only difference is more timing in the upper rpms. |
Drives: FR-S Whiteout
Have you done any modification to the exhaust? Does this show up upon throttle tip in?
Intent > Content
cowardice is the mother of cruelty. |
| Question About Negative Camber: More Negative Camber == More Grip at Corner? | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 38 | 03-10-2019 02:08 PM |
| BRZ Values | Apex_BRZ | BRZ First-Gen (2012+) — General Topics | 20 | 10-16-2014 05:38 PM |
| OpenFlash Manager v1.08.3 now available for download (FLKC) | Shiv@Openflash | Software Tuning | 120 | 06-22-2014 07:34 PM |
| OpenFlash Tablet: Multi-Gauge Function and FLKC logging | Shiv@Openflash | Software Tuning | 52 | 05-08-2014 08:30 PM |
| Safe values? | mike_ekim1024 | Software Tuning | 12 | 11-05-2013 01:19 PM |
