| Software Tuning Discuss all software tuning topics. |
Drives: Halo 2016 Scion FR-S, 6MT
MAF Scaling for OFT F00C US/MT 2016
Since I can't data log using MAFv or IAM, is it possible for me to adjust MAF Scaling with the other parameters like AFR, LTFT, etc...? I recently installed a Perrin 3" intake with my setup as shown below and it obviously needs to be scaled.
@Wayno @steve99
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI Open Flash Unequal Length Header Invidia N1 CatBack InstaGram: 49RJ Last edited by EffaressNOOB; 08-11-2016 at 07:40 PM. |
#2 |
Drives: FT86
hmmm its going to be painfull without maf V working. If you know someone with ecutek cable or brzedit they could log it for you
| The Following User Says Thank You to steve99 For This Useful Post: | EffaressNOOB (08-11-2016) |
#3 | |
+1 for ecutek C'mon @shiv I'm rooting for you!
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI Open Flash Unequal Length Header Invidia N1 CatBack InstaGram: 49RJ |
#4 |
http://datazap.me/u/taylorshift/oft-...l?log=0&data=1
@steve99 The link above is my data log for a few 3rd gear pulls at WOT and a 2-3 pull at WOT. Since I can't log my mafV or IAM, can you tell me if my car is safe enough to run on my setup or should I replace my Perrin 3" and go back to my stock air box. Seems to me that I'm running a little lean, but my LTFT even at CL never dips below -10% For some reason, RomRaider keeps freezing every time I try to download my Close Loop data log.
#5 | |
Drives: FT86
I would not run with that setup without rescaling maf or putting stock intake back on |
| The Following User Says Thank You to steve99 For This Useful Post: | EffaressNOOB (08-13-2016) |
#6 |
Can I rescale with the datalog information I have?
#7 |
Drives: Toyota 86 GTS
Your best option is to use the stock intake, and use a maf scale that works without modification. Don't believe everything vendors tell you. You will go in circles for months scaling an intake with a large diameter maf housing.
| The Following User Says Thank You to Wayno For This Useful Post: | EffaressNOOB (08-13-2016) |
#8 |
#9 |
Reinstalled my stock airbox (k&n drop in), modded my air duct and have a Perrin inlet hose. Reflashed to OFT Stage 2 UEL E85. Below are datalogs for CL and 2 OL runs after some light driving. What do y'all think? @steve99 @Wayno
http://www.datazap.me/u/taylorshift/...data=1&mark=89
#10 | |
Drives: FT86
fuel trims look ok need a couple of full throttle runs |
#11 | |
#12 | |
Drives: FT86
Yep looks ok for an off the shelf tune on E85 http://www.datazap.me/u/taylorshift/...zoom=2024-2394 |
| The Following User Says Thank You to steve99 For This Useful Post: | EffaressNOOB (08-15-2016) |
| MAF scaling, showing you what i cam up with | trdric | Software Tuning | 24 | 06-29-2017 01:10 PM |
| 3 BAR Map Sensor Scaling | tonytduc | Forced Induction | 9 | 06-24-2016 03:24 PM |
| OFT: Launch control and Flat-Foot Shift for F00C ROMs ready to test | Shiv@Openflash | Software Tuning | 17 | 03-23-2016 12:27 PM |
| OpenFlash Tablet: OTS v2.069 released (FFS/LC for F00C roms) | Shiv@Openflash | Software Tuning | 9 | 12-29-2015 06:51 AM |
| What MAF scaling says about your intake | BuBlake | Software Tuning | 27 | 12-09-2014 06:01 AM |
