Old 09-14-2015, 12:43 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile OFT: Launch control and Flat-Foot Shift for F00C ROMs ready to test
Hi guys,
Any OFT user with the new F00C calibration ID want to test Launch Control and Flat-Foot Shift? If so, please email me at shiv@openflashperformance.com and I can send you a tune file to test
Cheers,
shiv
Old 09-14-2015, 07:45 PM   #2
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I can get D00G guys to test also. Haven't had time to try to patch it over from D00C.
Old 09-15-2015, 04:13 PM   #3
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
What do you recommend the FFS delta be set to?
cameronjones239 is offline   Reply With Quote
Old 09-16-2015, 06:31 AM   #4
slowest86
Drives: slow frs
I put mine at 7000 rpm's, it works great.
slowest86 is offline   Reply With Quote
Old 09-16-2015, 10:42 AM   #5
steve99
If you set delta to 7000 then FFS would activate at 600rpm ??
Try FFS delta of about 2000
LC delta say 3600
Adjusting/Activating Launch control and Flat Foot (no lift) Shift parameters
http://www.ft86club.com/forums/showt...launch+control (Only for Manual vehicles)Note : OFT ROM's have a special patch for these functions use the definition files from the www.openflashtablet.com website downloads page
Launch Control -LC
Basically a second RPM limiter that is active when the vehicle speed is below the threshold speed set regardless of clutch in/out.
Launch control Disable speed = speed at which Launch RPM is disabled (ie you revert to normal red-line RPM limit 7600) default = 6mph (aprox 10KmH)
Launch Control RPM Delta = Amount to subtract from your Red-line RPM to get you Launch RPM e.g. if LC RPM Delta = 3600 your Launch RPM will be 7600-3600 = 4000 RPM
To disable Launch Control set LC RPM Delta = 0
Flat Foot (no lift) Shift -FFS
Is Another RPM limit activated when the Clutch is depressed (it does not monitor that the throttle is flat or 100%) for this reason it can activate on downshift.
Flat Foot Shift RPM Delta = Amount to subtract from your Normal Red-line RPM to get FFS RPM limit eg if you set FFS Delta = 2000 your FFS RPM limit will be 7600-2000= 5600 RPM so when up-shifting with foot on accelerator RPM will be limited to 5600 RPM as soon as you depress clutch even though your foot is on accelerator. Note its does not need the accelerator/throttle to be 100% or flat to activate its activated of Clutch switch only. This can sometimes cause issues on downshifts if you set the RPM to low for Flat foot shift.
To disable FFS set Delta to 0 (zero) in the table FFS RPM Delta using Romraider
cameronjones239 (09-16-2015)
Old 09-16-2015, 12:13 PM   #6
slowest86
Drives: slow frs
I said 7000 rpm's not 7000. FFS is at 500. It works great for me.
The Following User Says Thank You to slowest86 For This Useful Post:
steve99 (09-17-2015)
Old 09-16-2015, 03:17 PM   #7
D_Thissen
D_Thissen's Avatar
I think the LC Delta that I set up is around 3400-3600.
The Following User Says Thank You to D_Thissen For This Useful Post:
Bimble Bamble (09-23-2017)
Old 09-16-2015, 04:10 PM   #8
elBarto
elBarto's Avatar
Drives: Toyota GT86
Launch Control -LC[/B]
What happens if you set the speed at a much higher amount?
Will it use a 4000 rpm redline until you reach the specific speed?
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 09-16-2015, 09:49 PM   #9
steve99
Yes the LC rpm limit will be active till the LC disable speed is exceeded so if you set LC disable speed to 20mph the car wont rev over the LC rpm limit till vehicle speed exceeded 20 mph
Old 09-20-2015, 09:05 PM   #10
iJeff
iJeff's Avatar
Drives: 2016 Raven FR-S
I'm guessing this is why my OFT won't work with my 2016 Z12JF00C car! Tune files aren't released yet!
iJeff is offline   Reply With Quote
The Following User Says Thank You to iJeff For This Useful Post:
SlammedSilly (09-21-2015)
Old 01-04-2016, 09:55 PM   #11
PMok
Codename: Stitch
PMok's Avatar
Any sense of when tune file/definitions will be available for new 2016 F40C calibration ID? @Shiv@Openflash
Old 01-05-2016, 07:22 AM   #12
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
If somebody sends me the rom, I'll define it.
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
PMok (01-05-2016)
Old 01-16-2016, 09:14 AM   #13
Td-d
Definitions are done - up on Romraider and I've sent through to Shiv as well (and ported LC / FFS)
http://www.romraider.com/forum/viewt...p?f=34&t=12467
The Following 2 Users Say Thank You to Td-d For This Useful Post:
PMok (01-16-2016), steve99 (01-17-2016)
Old 01-17-2016, 05:20 AM   #14
steve99
If you could send me the new stock roms ill add them to the tactrix post
OpenFlash Tablet: RomRaider parameters for Launch Control and Flat-foot Shift Shiv@Openflash Software Tuning 118 06-04-2017 04:26 AM
racerom flat foot shifting ft86me Engine, Exhaust, Transmission 10 07-25-2013 03:02 PM
Ecutek Launch Control test video NoFear99 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-25-2013 08:53 PM
EcuTek RaceRom Flat Foot Shifting ! Visconti Engine, Exhaust, Transmission 79 11-14-2012 09:36 PM
