Drives: 2013 FRS
Hi guys,
New OTS map folder has just been released and is now available to download HERE Please read the change log in the included Release Notes file. It says: 9/22/15 v2.069 -Added Flat-foot-Shift (FFS) and Launch Control (LC) functionality to all 6MT F00C ROMs. -Added revised XML file (with FFS and LC defined) for F00C Calibration ID. This means that the ONLY change we made was to add FFS and LC to F00C ROMS and revised the F00C XML file accordingly (courtesy of Td-d). Tuning has not changed. So unless you have a F00C ROM, this update is of no relevance to you Again, be sure to only use the new XML on the new ROMS with the LC/FFS coded added. Do NOT use it with older F00C ROMs. If you try to adjust LC/FFS settings on older F00C ROMs without FFS/LC code, you will brick your ECU. One way to making sure that you are using the correct ROM is to view the default data for Launch Control RPM Delta. It should be set to 2000RPM. If all you see is a black-filled window, STOP RIGHT THERE. You are using the wrong ROM. Cheers, shiv Last edited by Shiv@Openflash; 09-22-2015 at 03:28 PM. |
Drives: 2016 Raven FR-S
Thanks Shiv! Amazing product support as usual for the OFT.
Sent from my LG-H812 using Tapatalk |
Drives: 2015 CWP BRZ Limited
Anyone else currently using these maps? I have a D00C rom, running the stage 1 currently, and I noticed that the idle targets seem to be a little low. Was this intentional? If I recall correctly, some of the older maps had slightly higher idle targets (750 RPM).
just change anything thats 650 to 700,
of if you want to go 750 change anything below 750 to 750 to smooth the idle further you can change the pi\di ratios to use full di at idle see the tune tweaks thread link below or see wayno,s thread on adjusting tunes |
#5 | |
Drives: 2016 Oceanic FR-S
@Shiv@Openflash; When you say the default data for Launch Control RPM Delta, do you mean the original ROM data or just that value in the Off-The-Shelf Tune? I ask because in my original ROM I see a black window, and a white window. Still a little new to all of this. Finally found all the ROMS and the XML for my ecu code. The OFT didn't auto recognize and offer ROMs, but I am pretty certain I found the right folder from the OTS v2.070 download. I got a little mixed up looking in F when I wanted C because of F00C, but once I located the correct folder that was no big deal. I couldn't help but notice that the XML for F00C is tagged RR not OFT, should I just not worry about this? I figure it's just kinda paying credit to RomRaider, but I had to ask. Thanks in advance, I am sure you are busy. I just don't want to do anything without verifying I am doing the right thing. |
#6 | |
Only edit lc\ffs parameters on oft tuned roms which have the patch and boxes in romraider are green. See shiv post first one in this thread and read the Romraider tips link below |
I plan to not use launch control. I was just trying to make certain that I had the right stage 2 ROM.
Edit: To clarify a bit more. I am not trying to edit the OEM ROM to get more power I was just trying to confirm that I was using the right ROM and cross referencing to the stock tune. Last edited by Akya2120; 12-28-2015 at 02:29 PM. |
#8 | |
So it sounds like the ROMs with a matching CALID in the 2.070 file should work and not brick my car? I just have to upload them to the OFT from OFM.
#10 |
| OFT: Launch control and Flat-Foot Shift for F00C ROMs ready to test | Shiv@Openflash | Software Tuning | 17 | 03-23-2016 11:27 AM |
| End of Summer Sale! OpenFlash tablet+OpenFlash Header+OEM Gaskets | Shiv@Openflash | Engine, Exhaust, Bolt-Ons | 2 | 10-01-2015 06:25 PM |
| OpenFlash Tablet: OTS v2.068 released (FFS/LC for D00C roms) | Shiv@Openflash | Software Tuning | 13 | 09-19-2015 06:18 PM |
| FS: New Openflash Tablet, New Openflash Header, New Ducktail Spoiler, NewCrawford BPB | FT86POWER | Engine, Exhaust, Bolt-Ons | 5 | 09-16-2015 03:26 PM |
