Old 06-14-2016, 09:44 PM   #1
tonytduc
tonytduc's Avatar
3 BAR Map Sensor Scaling
Can anyone can tell me step by step how to scale in a 3 bar map sensor? I can't find any on how to do it. Thanks
tonytduc is offline   Reply With Quote
Old 06-15-2016, 10:39 AM   #2
Ross
Drives: 85 corolla gts
I assume you are using something other then ecutek? As in the help files with ecutek there is a walk through for rescaling a map sensor.
Ross is offline   Reply With Quote
The Following User Says Thank You to Ross For This Useful Post:
tonytduc (06-15-2016)
Old 06-15-2016, 10:53 PM   #3
tonytduc
tonytduc's Avatar
I am using ecutek. Did not know about the walk through. thanks
Old 06-16-2016, 08:52 AM   #4
Ross
If this is your first time using the software I would recommend reading all the info they provide in terms to this application. It will make life much easier for you.
tonytduc (06-16-2016)
Old 06-17-2016, 12:28 PM   #5
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
Anyone know off hand?
Anyone know the omni 3 bar map scaling for V/PSI, versus bar?
I've done the calculation of what it should be, just want to make sure it's right.
Jaden
Jaden is offline   Reply With Quote
Old 06-17-2016, 12:53 PM   #6
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
For Google / future searches.
Omni 3 bar:
Multiplier 0.617 / Offset 0.03
Omni 4 bar:
Multiplier 0.825 / Offset 0.031
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following User Says Thank You to BRZoomTX For This Useful Post:
tonytduc (06-20-2016)
Old 06-19-2016, 01:22 PM   #7
Jaden
Road-hole
that is for bar...
Omni 3 bar:
Omni 4 bar:
that is bar/V. I'm looking for psi/V...
I've done a manual conversion, just making sure that that is correct...
Jaden
Old 06-20-2016, 07:44 PM   #8
tonytduc
tonytduc's Avatar
Omni 3 bar:
Omni 4 bar:
Got it working thanks
The Following User Says Thank You to tonytduc For This Useful Post:
BRZoomTX (06-24-2016)
Old 06-24-2016, 02:10 PM   #9
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Jaden
This was in reply to OP. The values I posted are what is required to enter in to Ecutek regarding aftermarket MAP sensor scaling.
As for your question, I'd recommend making a new topic since its not related to OP's question at all.
Old 06-24-2016, 02:24 PM   #10
Jaden
Road-hole
Are you serious?
It's a thread for omni 3 bar map scaling. I can just use the manually converted figures, but someone saying yeah here's what they are in psi/V does not necesitate starting another thread...
Do you know them? If you do that was ridiculous because you could've more easily just posted them than your stupid request that I start a new thread requesting the SAME thing in a slightly different format.
Jaden
Omni 2.5Bar MAP sensor scaling luckykevin Software Tuning 9 11-05-2020 11:51 AM
Front O2 Denso Planar sensor scaling ztan Software Tuning 21 05-17-2017 02:32 AM
3 bar omni map sensor scaling Hachiroku.86 Software Tuning 3 04-30-2016 01:51 AM
OMNI 2.5Bar MAP sensor scaling luckykevin Forced Induction 0 04-02-2016 10:56 AM
Scaling for vortech 2.5 bar map sensor? Frs32907 Software Tuning 2 11-08-2015 05:41 PM
