Old 08-11-2016, 12:09 PM   #1
EffaressNOOB
EffaressNOOB's Avatar
Drives: Halo 2016 Scion FR-S, 6MT
MAF Scaling for OFT F00C US/MT 2016
Since I can't data log using MAFv or IAM, is it possible for me to adjust MAF Scaling with the other parameters like AFR, LTFT, etc...? I recently installed a Perrin 3" intake with my setup as shown below and it obviously needs to be scaled.
@Wayno @steve99
Enkei TFR (Copper) 17x9+45 | Hankook Ventus V12 Evo2 245/40 | Tein Flex A
OFT Stage 2, E85 | Kraftwerks Skunk2 CAI
Open Flash Unequal Length Header
Invidia N1 CatBack
InstaGram: 49RJ
EffaressNOOB is offline   Reply With Quote
Old 08-11-2016, 09:27 PM   #2
steve99
Drives: FT86
@Wayno @steve99
hmmm its going to be painfull without maf V working. If you know someone with ecutek cable or brzedit they could log it for you
EffaressNOOB (08-11-2016)
Old 08-11-2016, 09:43 PM   #3
EffaressNOOB
How painful? LOL! I do know someone with an ecutek cable. I can do CL/OL all in 1 log correct? I'm going to use VGI...
+1 for ecutek
C'mon @shiv I'm rooting for you!
Invidia N1 CatBack
InstaGram: 49RJ
Old 08-13-2016, 03:39 PM   #4
EffaressNOOB
http://datazap.me/u/taylorshift/oft-...l?log=0&data=1
@steve99
The link above is my data log for a few 3rd gear pulls at WOT and a 2-3 pull at WOT. Since I can't log my mafV or IAM, can you tell me if my car is safe enough to run on my setup or should I replace my Perrin 3" and go back to my stock air box. Seems to me that I'm running a little lean, but my LTFT even at CL never dips below -10%
For some reason, RomRaider keeps freezing every time I try to download my Close Loop data log.
Invidia N1 CatBack
InstaGram: 49RJ
Old 08-13-2016, 07:13 PM   #5
steve99
Drives: FT86
@steve99
Yes its running quite lean your CL target afr is 12.4 and your afr is 13.8.
I would not run with that setup without rescaling maf
or putting stock intake back on
EffaressNOOB (08-13-2016)
Old 08-13-2016, 08:18 PM   #6
EffaressNOOB
Can I rescale with the datalog information I have?
Invidia N1 CatBack
InstaGram: 49RJ
Old 08-13-2016, 08:40 PM   #7
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Your best option is to use the stock intake, and use a maf scale that works without modification. Don't believe everything vendors tell you. You will go in circles for months scaling an intake with a large diameter maf housing.
The Following User Says Thank You to Wayno For This Useful Post:
Old 08-13-2016, 09:15 PM   #8
EffaressNOOB
Thanks @steve99 and @Wayno
Invidia N1 CatBack
InstaGram: 49RJ
Old 08-14-2016, 06:28 PM   #9
EffaressNOOB
Reinstalled my stock airbox (k&n drop in), modded my air duct and have a Perrin inlet hose. Reflashed to OFT Stage 2 UEL E85. Below are datalogs for CL and 2 OL runs after some light driving. What do y'all think? @steve99 @Wayno
http://www.datazap.me/u/taylorshift/...data=1&mark=89
Invidia N1 CatBack
InstaGram: 49RJ
Old 08-14-2016, 07:28 PM   #10
steve99
Drives: FT86
cannot tell too much from that log as its all light throttle.
fuel trims look ok
need a couple of full throttle runs
Old 08-14-2016, 07:48 PM   #11
EffaressNOOB
fuel trims look ok
@steve99 you'd have to change my log. The first is my closed loop run. OL2.csv and OL3.csv is my open loop wot run on 3rd gear. I attached all 3 datalogs under that one link. Sorry, shoulda mentioned that.
Invidia N1 CatBack
InstaGram: 49RJ
Old 08-15-2016, 01:14 AM   #12
steve99
Drives: FT86
Yep looks ok for an off the shelf tune on E85
http://www.datazap.me/u/taylorshift/...zoom=2024-2394
EffaressNOOB (08-15-2016)
MAF scaling, showing you what i cam up with trdric Software Tuning 24 06-29-2017 12:10 PM
3 BAR Map Sensor Scaling tonytduc Forced Induction 9 06-24-2016 02:24 PM
OFT: Launch control and Flat-Foot Shift for F00C ROMs ready to test Shiv@Openflash Software Tuning 17 03-23-2016 11:27 AM
OpenFlash Tablet: OTS v2.069 released (FFS/LC for F00C roms) Shiv@Openflash Software Tuning 9 12-29-2015 05:51 AM
What MAF scaling says about your intake BuBlake Software Tuning 27 12-09-2014 05:01 AM
