#29 |
That was clearly a reply to the other member. We won't need your bulbs back.
If you were in St. Louis, we'd be happy to fix it for you, but unfortunately, we can't. You will need to remove the bulbs. Again, please attempt heating them to remove, either by using a hair dryer, or putting the light in an oven for about 12-15 minutes at 230F or lower.
#30 |
Drives: Ultramarine FRS
#31 |
Drives: 2014 Subaru BRZ
Have you even attempted to use a blow dryer and heat them? You're acting fairly bratty. Obviously you need to heat the housing first before removing, and you're just ripping them out. They already fix the bulb it self for you, and apologized. It's kind of ridiculous to just expect them to buy a whole new housing just because you don't know how to use a heat gun and remove them yourself.
#32 | |
WtsTofu
Drives: Ultramarine fr-s
ig:Vinshiin |
#33 |
Drives: 2017 Series.Yellow + Perf Package
My switchbacks fit great, however, my rear turn (now reverse lights) don't stay seated unless I tape them in. I like the tails as turns mod but am worried the reverse lights are going to fall into the housing and it will be hell getting them out.
#34 | |
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
. I ended up just taking off the whole tail light and tilting/rolling the light around until I could grab it through the hole... the trick was to not let the bulb fall into the Red Brake Light section of the tail light (there's an opening between the turn signal section and brake light section of the housing)
#35 |
I think vacuum might work if it falls?
#36 |
Well, I didn't mean to come off as a douche, I'm sorry. I would recommend removing the housing, and throwing it in the oven. I might be wrong, but you can use a similar temperature setting as if you're trying to open up the casing of a headlight. That would be your best bet, but others can correct me if I am wrong in this.
#37 | |
WtsTofu
ig:Vinshiin |
#38 | |
Drives: 2014 BRZ SWP LTD
Instagram: stimson |
#39 |
@Vincenttam, please let us know if you need help finding a professional installer in your area
Thanks, Nick C.
#40 | |
WtsTofu
ig:Vinshiin |
#41 | |
A.K.A. Starlord
Drives: 2015 Series.Blue
If this issue had happened to ne, I'd have been damned pissed if I had to remove my headlights and bake them and take them apart in order to resolve the issue, thereby voiding the warranty on the headlight assemblies, and risking damaging them in the process. It sucks for any company when a part you sell fails, but it WAS a failure due to a DEFECT of the part. This is not the customer's fault. When he bought the part, all he needed to do was swap a bulb. Now suddenly he is expected to remove the headlight housings and deconstruct them in order to resolve a problem - something he might not even be comfortable doing. Don't be a **** and tell him to calm down and act like an adult. Everyone here loves Diode Dynamics, but there is no need to belittle someone (unnecessarily) because they had an issue. |
#42 | |
WtsTofu
ig:Vinshiin |
| I got some diode dynamic lighting for my car!! | Vincenttam | Cosmetic Modification (Interior/Exterior/Lighting) | 35 | 03-27-2015 01:58 PM |
| melting stock cats? | Roadcone | Engine, Exhaust, Transmission | 5 | 10-28-2014 01:37 PM |
| Diode Dynamic LED blow $400 fuse... | balla_08 | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 04-18-2014 08:33 PM |
| Anyone use diode dynamic fog lights with HiD? | KamakazeProject | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 01-24-2014 03:41 AM |
| Difference Between $3 DRLS and $40 DRLS? | FR-S Matt | Cosmetic Modification (Interior/Exterior/Lighting) | 14 | 12-31-2012 05:05 AM |
