Old 02-20-2015, 10:08 PM   #29
Diode Dynamics
Diode Dynamics's Avatar
Originally Posted by Vincenttam View Post
I would like to get the bulb out first before an exchange
That was clearly a reply to the other member. We won't need your bulbs back.
If you were in St. Louis, we'd be happy to fix it for you, but unfortunately, we can't. You will need to remove the bulbs. Again, please attempt heating them to remove, either by using a hair dryer, or putting the light in an oven for about 12-15 minutes at 230F or lower.
John C.
Diode Dynamics
Old 02-20-2015, 10:41 PM   #30
kevin.nguyen
Drives: Ultramarine FRS
Originally Posted by Diode Dynamics View Post
Please contact us for exchange- we made some recent revisions to the base connector on this specific bulb which addressed this issue. New bases fit perfectly and securely.
Will contact you back at your business hours. Thanks for the reply.
kevin.nguyen is offline   Reply With Quote
Old 02-21-2015, 09:37 AM   #31
ethn
ethn's Avatar
Drives: 2014 Subaru BRZ
Have you even attempted to use a blow dryer and heat them? You're acting fairly bratty. Obviously you need to heat the housing first before removing, and you're just ripping them out. They already fix the bulb it self for you, and apologized. It's kind of ridiculous to just expect them to buy a whole new housing just because you don't know how to use a heat gun and remove them yourself.
ethn is offline   Reply With Quote
The Following 2 Users Say Thank You to ethn For This Useful Post:
Cole (04-21-2015), Lonewolf (02-22-2015)
Old 02-21-2015, 03:56 PM   #32
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Never expected them to buy me a new housing but am new and inexperienced with a heat gun. Am I supposed to fest it from the back or what.
ig:Vinshiin
Vincenttam is offline   Reply With Quote
Old 02-24-2015, 12:06 AM   #33
Lateral G
Drives: 2017 Series.Yellow + Perf Package
Originally Posted by kevin.nguyen View Post
Does anyone have a problem with switchbacks repeatedly falling out of the connection. Every week I have been having to connect them back in. Seems like they do not plug in all the way.
My switchbacks fit great, however, my rear turn (now reverse lights) don't stay seated unless I tape them in. I like the tails as turns mod but am worried the reverse lights are going to fall into the housing and it will be hell getting them out.
Lateral G is offline   Reply With Quote
The Following User Says Thank You to Lateral G For This Useful Post:
Ornelas66 (04-21-2015)
Old 02-24-2015, 01:30 AM   #34
cdo221
Drives: 2013 Ultramarine FR-S, 2015 RS 1.0
I actually dropped a bulb inside the turn signal once haha . I ended up just taking off the whole tail light and tilting/rolling the light around until I could grab it through the hole... the trick was to not let the bulb fall into the Red Brake Light section of the tail light (there's an opening between the turn signal section and brake light section of the housing)
cdo221 is offline   Reply With Quote
Old 02-24-2015, 01:41 AM   #35
veck
veck's Avatar
I think vacuum might work if it falls?
veck is offline   Reply With Quote
Old 03-02-2015, 11:54 AM   #36
ethn
ethn's Avatar
Well, I didn't mean to come off as a douche, I'm sorry. I would recommend removing the housing, and throwing it in the oven. I might be wrong, but you can use a similar temperature setting as if you're trying to open up the casing of a headlight. That would be your best bet, but others can correct me if I am wrong in this.
Old 03-03-2015, 11:51 PM   #37
Vincenttam
WtsTofu
Vincenttam's Avatar
It's fine, i found someone that does custom lighting so i'm just going to have some custom work done on my headlights soon. Get it blacked out to fix the chrome chip with some amber drls At the end of the day theres no such thing as a perfect business, you win some you lose some. I'm not going to hold a vendetta against @Diode Dynamics.
ig:Vinshiin
The Following User Says Thank You to Vincenttam For This Useful Post:
Diode Dynamics (03-04-2015)
Old 03-04-2015, 01:22 AM   #38
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Damn right it's fine. There's no such thing as a perfect customer either, and you sure as hell wasn't one. You need to act like an adult and chill out, these guys did the best they could and then some to provide excellent customer support.
Instagram: stimson
The Following User Says Thank You to Turbo95eg6 For This Useful Post:
ethn (03-04-2015)
Old 03-04-2015, 04:05 PM   #39
Diode Dynamics
@Vincenttam, please let us know if you need help finding a professional installer in your area
Thanks,
Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
Annahra (03-04-2015)
Old 03-04-2015, 05:06 PM   #40
Vincenttam
WtsTofu
Vincenttam's Avatar
ig:Vinshiin
Old 03-04-2015, 05:28 PM   #41
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Dude. I love Diode Dynamics, and I've never had issues with any of their products, but I think your comment here is way off base.
If this issue had happened to ne, I'd have been damned pissed if I had to remove my headlights and bake them and take them apart in order to resolve the issue, thereby voiding the warranty on the headlight assemblies, and risking damaging them in the process. It sucks for any company when a part you sell fails, but it WAS a failure due to a DEFECT of the part. This is not the customer's fault. When he bought the part, all he needed to do was swap a bulb. Now suddenly he is expected to remove the headlight housings and deconstruct them in order to resolve a problem - something he might not even be comfortable doing.
Don't be a **** and tell him to calm down and act like an adult. Everyone here loves Diode Dynamics, but there is no need to belittle someone (unnecessarily) because they had an issue.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
DashRipRock (04-21-2015), Vincenttam (03-08-2015)
Old 03-08-2015, 08:06 AM   #42
Vincenttam
WtsTofu
Vincenttam's Avatar
Exactly what i wanted to say. Unfortunately if i would of said it like that everyone would of thought i just wanted @Diode Dynamics to buy me new headlights.
ig:Vinshiin
I got some diode dynamic lighting for my car!! Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 35 03-27-2015 01:58 PM
melting stock cats? Roadcone Engine, Exhaust, Transmission 5 10-28-2014 01:37 PM
Diode Dynamic LED blow $400 fuse... balla_08 Cosmetic Modification (Interior/Exterior/Lighting) 12 04-18-2014 08:33 PM
Anyone use diode dynamic fog lights with HiD? KamakazeProject Cosmetic Modification (Interior/Exterior/Lighting) 7 01-24-2014 03:41 AM
Difference Between $3 DRLS and $40 DRLS? FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 14 12-31-2012 05:05 AM
