Old 03-10-2014, 06:32 PM   #1
balla_08
Drives: Satin Pearl BRZ
Diode Dynamic LED blow $400 fuse...
So I had an issue with the passenger side door courtesy light stays on ALL the time!! This only happened after the LEDs (stage 2) were installed. Ive seen similar threads where it blew a BIU fuse which is $400...
Now what to do?
balla_08 is offline   Reply With Quote
Old 03-10-2014, 06:37 PM   #2
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Wow, that's good to know, I was just about to order the same thing too!
Edit: Did you email/call them? They're really helpful!
leicaboss is offline   Reply With Quote
Old 03-10-2014, 07:46 PM   #3
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
This seems unusual. Many of my friends w BRZs had LED courtesy lights and had no issues. I don't think that this is the cause of the fuse blowing out. Do you even know if the fuse you mentioned controls the accessory lighting?
@Diode Dynamics
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 03-10-2014, 08:03 PM   #4
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
I have the same LED's from Diode Dynamics in my courtesy lights as well and had no issues with them during install or to this day. Before I did mine there seemed to be people having the problem you had, where it blows the BIU.
It was from the voltage difference from the stock lights to the LED's and it trips something in the BIU since the current is different. I also saw people who used something conductive to remove the light (screwdriver) frying the BIU. (I'm no electrical genius but this is what I remember reading before I installed mine)
It has nothing to do with Diode Dynamics specifiacally as I've seen people who purchased LED's from other places that had the same problem.
The only thing you can do to fix it is take it to the dealership and have them replace the BIU. But put your stock lights back in otherwise if they see the LED's they may try to make you pay for it.
Hope this helps and Good luck!
Husker BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to Husker BRZ For This Useful Post:
Ganthrithor (03-10-2014), tr1x5tuh (03-10-2014)
Old 03-10-2014, 08:39 PM   #5
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
This is why I disconnected the lighting harness from the whole courtesy light assembly before using a screwdriver to help remove the bulb...
^GT5 Replay Photo Mode^
The Following User Says Thank You to SirBrass For This Useful Post:
Husker BRZ (03-10-2014)
Old 03-10-2014, 09:26 PM   #6
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Yup, this is exactly what happened to me. Installed everything with the battery disconnected, noticed one light wasn't lit, went to flip the bulb around, couldn't get it out because that connector fits so tightly, grabbed screwdriver blade to lever the bulb out without stopping to think that maybe that wouldn't be a good idea since the entire door marker housing is conductive.
Very annoying, but also definitely my dumb ass's fault. I'm not gonna bother replacing the BIU since a running door marker LED isn't a problem I'm prepared to pay $400 to correct; the LED draws so little power that its essentially a cosmetic issue. I don't know how long it would take to drain your battery, but I'm guessing it's a very, very long time. I know I've left my car parked for days at time with no adverse effects. Maybe it would be different in a seriously cold environment? IDK.
Anyway, yeah, this problem is kind of annoying. I'm more irritated with Subaru for using such shitty connectors than anything else, though: why they thought it would be clever to design housings where it requires like 50lbs of force to remove a bulb for replacement is beyond me. I almost gave up on my trunk light because I couldn't grip the stock bulb hard enough to pull it out and I was worried about breaking it if I tried to use a tool. I finally did manage to extract it, but only after a lot of cursing and sore fingers.
Ganthrithor is offline   Reply With Quote
The Following User Says Thank You to Ganthrithor For This Useful Post:
Old 03-11-2014, 11:28 AM   #7
Diode Dynamics
Diode Dynamics's Avatar
You should remove the housing prior to installing the bulb, and then re-install the assembly once the LED is installed.
That will prevent this from happening, and shouldn't scare anyone away from buying the door light LEDs.
I suggest watching this installation video for more tips: [ame="http://www.youtube.com/watch?v=gIYXMElJLlk"]2007-2011 Toyota Camry LED Installation - YouTube[/ame]
Feel free to call us if you need more information: (314) 205-3033
Nick C.
John C.
Diode Dynamics
The Following 3 Users Say Thank You to Diode Dynamics For This Useful Post:
balla_08 (03-14-2014), Creole (03-11-2014), SirBrass (03-11-2014)
Old 04-18-2014, 05:09 PM   #8
jay_
Drives: 2014 DGM Subaru BRZ limited 6MT
balla, did you try to take the bulb out with a screwdriver? I did that and thats what i blew the biu
jay_ is offline   Reply With Quote
Old 04-18-2014, 05:52 PM   #9
yaguphire
Drives: white-out FR-S
I did not know a single fuse could cost $400.. interesting.
yaguphire is offline   Reply With Quote
Old 04-18-2014, 06:02 PM   #10
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
He said the light was ON...if the light was ON the fuse was NOT blown...he said he saw it blow other peoples fuses...not that his is blown. Think he wants to know why its staying on ALL THE TIME.
Fett4Real is offline   Reply With Quote
Old 04-18-2014, 07:34 PM   #11
zex
zex's Avatar
Drives: Subaru WRB BRZ Limited
He is confusing fuses with the BIU or BUI whatever it is, i was told from the dealer it was like a component that controlled several electrical parts.
And this has happened to me personally.
zex is offline   Reply With Quote
Old 04-18-2014, 07:50 PM   #12
SirBrass
SirBrass's Avatar
Nick C.
I did do that and it still fried the BIU. It's not harming anything so I'm not going to bother fixing it. Now, if it was affecting OTHER things in the car, then I'd consider getting it fixed, but since it isn't, I'm not going to bother.
Old 04-18-2014, 09:33 PM   #13
yaguphire
What is this BUI and where is it located?
courtesy light, diode dynamics, led, passenger door
catch can for blow-through maf jamesm Forced Induction 13 05-25-2017 11:54 AM
I got some diode dynamic lighting for my car!! Vincenttam Cosmetic Modification (Interior/Exterior/Lighting) 35 03-27-2015 02:58 PM
Anyone use diode dynamic fog lights with HiD? KamakazeProject Cosmetic Modification (Interior/Exterior/Lighting) 7 01-24-2014 04:41 AM
Diode Dynamics Fog Kit skyre User/Vendor/Sponsor Reviews, Feedback, Comments 1 12-23-2013 01:29 PM
Does someone try Carbon Dynamic Air box from BMC ? Pascal_TTH Engine, Exhaust, Transmission 4 01-30-2013 05:40 PM
