Old 10-20-2014, 03:51 PM   #1
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
melting stock cats?
Do the stock cats have a tendency to melt under extreme use I've never really seen anything about it but the last two cars i had were bad about wiping out cats in track conditions.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 10-20-2014, 04:30 PM   #2
CSG David
CSG David's Avatar
It should not on new OEM stock tunes (before the reflashes and changes, we were the first to blow out cats on completely stock everything). We have clients with tuned setups melt cats but the logs revealed that the tuning parameters were the ones to blame. Proper tuning should not melt cats.
Old 10-21-2014, 09:07 AM   #3
Roadcone
StreetKart
well, there goes one reason to justify a catless header to myself... i guess because racecar is now the reason...
Old 10-21-2014, 09:30 AM   #4
Model Citizen
Lacking brains
Drives: frz
hi
in fairness the car is boosted and probably was running a bit rich.
<40k miles, 7 track days, 200+ autox runs.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 10-21-2014, 09:16 PM   #5
CSG David
CSG David's Avatar
I recommend catless setups if you're planning to track. For one, you don't have to worry about replacing expensive factory cats you blew out just before smogging your car. All you need to do is just bolt the factory cats back on and boom, you're ready to go.
Old 10-28-2014, 01:37 PM   #6
Roadcone
StreetKart
smogging? inspection? these things dont happen in race car country south carolina
seriously, we have cars running around with 88 and 91mm turbos with thru the fender exhaust on the street here lol
Gutting out the stock cats diss7 Engine, Exhaust, Transmission 90 04-02-2018 12:57 AM
Just replacing the stock cats? brillo Engine, Exhaust, Transmission 4 07-08-2015 11:12 AM
High-flow cats? phrosty Engine, Exhaust, Transmission 36 07-24-2014 09:37 PM
OEM cats only ? 350matt Engine, Exhaust, Transmission 7 11-26-2013 07:30 PM
I giggled... Cats have it made seven Off-Topic Lounge [WARNING: NO POLITICS] 51 12-21-2012 03:46 PM
