Old 07-06-2013, 05:18 PM   #1
Frs300
Frs300's Avatar
Drives: Pile of junk
Anyone tried hydro dipping before?
has anyone done anything with hyrdo dipping before or had any parts dipped? how well does it hold up?
here is video for those of you who dont know what it is
[ame="http://www.youtube.com/watch?v=QIPDi35ByW8"]Hydrographics - Carbon Fiber - Fastlane - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=ADq96RGRf00"]Hydrographics-Water.Transfer.Printing | HG Arts (www.hgarts.com) - YouTube[/ame]
Frs300 is offline   Reply With Quote
Old 07-06-2013, 05:36 PM   #2
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Interesting. Never seen anything like it. I will be experimenting with other coatings soon.
tech4pdx is offline   Reply With Quote
Old 07-06-2013, 05:37 PM   #3
Frs300
Frs300's Avatar
i want to try it out
Old 07-06-2013, 05:41 PM   #4
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
I've had parts done for customer builds and they hold up pretty well. Some things look cool and some stuff looks pretty cheesy but a unique process for sure.
chadstyle is offline   Reply With Quote
The Following User Says Thank You to chadstyle For This Useful Post:
Frs300 (07-06-2013)
Old 07-06-2013, 05:43 PM   #5
GT 86 Brah
u aware?
GT 86 Brah's Avatar
Drives: it like a turtle.
someone did a DIY awhile back with interior pieces...
GT 86 Brah is offline   Reply With Quote
The Following User Says Thank You to GT 86 Brah For This Useful Post:
Frs300 (07-06-2013)
Old 07-06-2013, 05:48 PM   #6
Frs300
Frs300's Avatar
i looked around didnt see aything
Old 07-06-2013, 05:48 PM   #7
Frs300
Frs300's Avatar
how well does it hold up to heat?
Old 07-06-2013, 05:55 PM   #8
GT 86 Brah
u aware?
GT 86 Brah's Avatar
found it for you
[ame="https://www.youtube.com/watch?v=d8lrrchH5A4"]Car Noob Ep. 3 - Interior removal & Carbon Fiber-ization - YouTube[/ame]
nzer (07-06-2013)
Old 07-06-2013, 06:37 PM   #9
kALMIGHTY
Drives: TRD Ultramarine '13
The only thing I don't like about that video, or I guess the process, is that the "carbon fibre" pattern doesn't line up at the centre of the splitter because they did the first half and then the second half separately. It would be much better if they just had a huge piece of the patter in the water and submerged the entire splitter so the pattern would be continuous across the whole part.
Old 07-06-2013, 07:00 PM   #10
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Never seen this before. Looks cool, especially the activator making the carbon sheet turn to liquid. Thanks @Frs300 and @GT 86 Brah for sharing.
nzer is offline   Reply With Quote
Old 07-06-2013, 07:04 PM   #11
Hardrock4445
Hardrock4445's Avatar
I used to do this for a body shop I worked at. It will hold up long if done properly. We've done gun stocks in camo, car parts in carbon, most of our business for the hydro dip was for other things. Xbox cases, controller cases, phone cases, etc....
Mods: Perrin CAI, JDL EL header, DC sports Catless front pipe, top speed auto pro-1 cat-back, H&R sport line springs, Headlight blackout, "Demon eyes"
Hardrock4445 is offline   Reply With Quote
Old 07-06-2013, 07:12 PM   #12
chadstyle
chadstyle's Avatar
They held up good.. We did some wheel hoops and also some centers and no problems with either even with brake dust covering the parts.
Old 07-06-2013, 08:36 PM   #13
antlers
White Guy
antlers's Avatar
Drives: 2005 Subaru WRX STI
I've done a few pieces in multicam. Its a pain in the ass. You have to paint the base coat in the correct color, (most rattlecans dont work) wait for it to dry, get the water temperature just right, lay the sheet in right, add the right amount of activator and get the sheet covered evenly and then dip the part that also has to be at the correct temperature. The correct temp range is like 95 to 100 degrees. You then have to clear coat the piece if you want any durability. I recommend having it done or seeing if the pattern comes in vinyl.
antlers is offline   Reply With Quote
Old 07-06-2013, 09:27 PM   #14
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
did you see at 4:52/4:53 that the dead center of the camaro lip didnt look that great? the taped middle doesnt look flush... hmmm cool concept tho
mikeg7827 is offline   Reply With Quote
Plasti Dipping the "mustache"? jonghyun Cosmetic Modification (Interior/Exterior/Lighting) 10 10-22-2018 07:36 PM
the rev dipping issue pr086 Issues | Warranty | Recalls / TSB 27 05-05-2016 05:30 PM
Plasti Dipping my FRS soon to Matte Aesthetics Cosmetic Modification (Interior/Exterior/Lighting) 5 06-04-2013 11:29 PM
Silver interior trim removal for plasti-dipping ph0en1xtk Cosmetic Modification (Interior/Exterior/Lighting) 1 10-06-2012 09:54 AM
Question about Plasti-Dipping. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 18 08-12-2012 12:38 AM
