Old 08-09-2012, 08:27 AM   #1
pr086
Drives: fast
the rev dipping issue
has this been found to be normal? i took a test drive last night, AC was on the whole trip. after about 10-15 min got to a red light and was stopped and the revs were fluctuating. this was a mauel transmission.
this car had supposedly just come in, but already had 50 miles on it (i was third in line for a test drive) so its possible i guess. so they're still coming out of the factory with this issue.
pr086 is offline   Reply With Quote
Old 08-09-2012, 08:30 AM   #2
Opposed
Drives: 2013 Asphalt FR-S
Yes it is. Some have had bigger issues later on that caused a CEL and found out the cam position sensor was faulty if I remember correctly. Otherwise, the only way to get rid of it is with a tune. Look up the Visconti tune with Ecutek software. So far the people testing it said the idle is smooth now.
Opposed is offline   Reply With Quote
Old 08-09-2012, 09:36 AM   #3
pr086
Drives: fast
is this something they will be fixing in the assembly line? it's not very reassuring to see your revs drop like that. never happens in my SI
Old 08-09-2012, 09:54 AM   #4
Hotlava86
Hotlava86's Avatar
Drives: 2013 Hot lava Fr-s, 2007 Mazda 3
My FR-S will do this....I have no engine light yet but i do notice it drop down to around 400Rpm's and i can hear the engine knocking like its going to stall. Is this a NOTED issue that toyota will instantly be like "oh yeah if your having this issue we need to fix it NOW" or is it something to where they won't do anything without seeing and engine light first?
Hotlava86 is offline   Reply With Quote
Old 08-09-2012, 10:51 AM   #5
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
As of right now, there is no known official fix for this. They are working on this issue as well as the crickets and AC chirp.
Old 08-09-2012, 10:54 AM   #6
Hotlava86
Hotlava86's Avatar
please keep me informed of the progress on this because my dealership blew me off because of it.
Old 08-09-2012, 11:20 AM   #7
empower-auto
Kouki-Monster
empower-auto's Avatar
Scion is releasing a TSB with a reflash pretty soon.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-09-2012, 11:41 AM   #8
pr086
Drives: fast
where did u hear this and when will the cars from the factory have the reflash already done?
Old 08-09-2012, 11:48 AM   #9
empower-auto
Kouki-Monster
This was directly from the Scion "Champion" (they have crazy titles in Canada haha) here. Great guy, same guy I bought my car from. He doesn't have a date or anything but it is definitely in the pipeline.
Rich Anderson
EMPOWER AUTO
Old 08-09-2012, 04:25 PM   #10
pr086
Drives: fast
so a flash is confirmed to be a fix for the dipping revs? i'd really like to pull the trigger on one of these things, but i keep hearing about issues. i know if i wait they will be fixed, but its hard!
Old 08-09-2012, 05:43 PM   #11
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
The issue is an ECU tuning problem (overcompensation). People that are stalling out from it typically have other problems (CELs) from a crankshaft position sensor which may be faulty. It could also be that the problem has times where it fails to compensate (also from tuning) and it stalls but those seem to be very rare.
I have the 600-1000 blip at idle. Ironically, it has stopped doing it now that I am waiting for it with my ScanGauge showing engine load, ignition timing, intake air temp, and rpm. May change load for MAF/MAP instead. Either way, it's being shy!
eriktherod is offline   Reply With Quote
Old 08-09-2012, 06:21 PM   #12
oldnumber7
Drives: fr-s
it could be changing from port to direct injection or vice versa
oldnumber7 is offline   Reply With Quote
Old 08-10-2012, 11:28 AM   #13
Hotlava86
Hotlava86's Avatar
Regardless of WHAT it's doing a brand new car should never be stalling out randomly MAYBE they will also address the torque dip issue slightly with this flash. I honestly will be calling my service writer every week in hopes of it coming out soon.
Raising the bar one step at a time!
Kansas City FR-S/BRZ Facebook group. https://www.facebook.com/groups/452909128083343/
Hotlava86's Build thread!http://www.ft86club.com/forums/showthread.php?t=14152
Old 05-04-2016, 01:00 PM   #14
Mwillywag
Drives: 2015 silver Scion FRS
Engine idle problem
I realize this is a very old thread, but I have a 2015 Scion - FRS (13,000 mi.) and am experiencing an idle problem. If I drive the car on the freeway (60 - 65 mph) for around 30 miles, when I come to a stop, the engine idle drops to around 500 rpm, jumps back to around 900 rpm, then slowly drops and repeats the cycle about every 30 seconds or so. No engine light. It does not always happen and it occurs in the summer and the MN winter, does not matter the outside temperature or raining/snowing/or dry. I did notice that if I shut the engine off and wait at least 10 seconds, start the engine back up, the idle returns to normal.
I will be going to the dealer today for a key interlock recall and oil change and will mention it to them to see what they say. I took a video of the issue to show them. I read that a re-flash of the ECU was recommended, but reading posts indicated this could have been resolved already.
Wish me luck.
Mwillywag is offline   Reply With Quote
iPod issue? Mr.Jay Electronics | Audio | NAV | Infotainment 12 02-10-2013 02:41 AM
Idle issue scioneric CANADA 23 08-24-2012 01:40 AM
Question about Plasti-Dipping. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 18 08-12-2012 12:38 AM
The weight issue mickey177 Scion FR-S / Toyota 86 GT86 General Forum 24 07-27-2012 08:47 AM
Opticoat issue dav0777x Cosmetic Modification (Interior/Exterior/Lighting) 3 06-24-2012 05:42 PM
