Old 01-29-2020, 08:57 PM   #1
haute
Drives: 37J
Is it safe to flash to non FF tune with 18% E in tank?
Not sure if the tune is just Non FF or non E85 tune, but I need to flash back and go to the tune so I can plug my o2 sensor back in for emissions.
Let’s assume that it is non E85: E18 would be fine right?
haute is offline   Reply With Quote
Old 01-29-2020, 09:19 PM   #2
Just go for a long drive and burn off some more. Should be OK with 18 anyway really.
why? (01-30-2020)
Old 01-29-2020, 10:36 PM   #3
steve99
Anythong under about 30% ethanol will be fine thier is a lot of fueling adjustment and more E means more knock resistance and if you on a petrol tune it will jave low ignition advance compared to an ethanol tune
Old 01-30-2020, 02:08 PM   #4
Stomachbuzz
Drives: 2013 FRS
lol, just out of curiosity, how did you figure it's 18%?
Stomachbuzz is offline   Reply With Quote
Old 01-30-2020, 04:16 PM   #5
jflogerzi
jflogerzi's Avatar
Most fuel has 10-15e content already in it. So that would do much. Watch your fuel trims and keep from going wot till your FTs stabilize
2013 Series 10 FRS #553
Old 01-30-2020, 05:31 PM   #6
Lantanafrs2
Drives: 2013 frs red
Maybe he has a gauge?
Old 01-30-2020, 05:42 PM   #7
jflogerzi
jflogerzi's Avatar
Not likely if he is using oft. Maybe test strips
Old 01-30-2020, 08:03 PM   #8
haute
Drives: 37J
I have EcuTek
I have a gauge from DT.
Old 01-30-2020, 08:06 PM   #9
jflogerzi
jflogerzi's Avatar
I have EcuTek
Do you have a flex fuel tune? If so this whole thread was for not lol
Old 01-30-2020, 08:08 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
He had flex fuel. Needs stock tune for emissions
Old 01-30-2020, 08:14 PM   #11
jflogerzi
jflogerzi's Avatar
Ahhh okay that makes sense.
Old 01-30-2020, 08:32 PM   #12
DarkSunrise
DarkSunrise's Avatar
I've driven for about 10 miles on e85 with the stock tune when I had some issues flashing the e85 tune. Was fine. Fuel trims jumped to 20-25 percent, but I just kept the rpms low and tried to stay off the throttle. No problems, not even a CEL.
2022 BRZ Build
2013 FR-S Build
Old 01-30-2020, 11:04 PM   #13
bfrank1972
Drives: 2013 FR-S Argento
Just don't romp on it, keep it in closed loop and ecu should be able to compensate fine based on o2 sensor feedback.
Sent from my SM-G965U using Tapatalk
bfrank1972 is offline   Reply With Quote
Old 01-30-2020, 11:48 PM   #14
kev0
Drives: '14
What do you mean by keep it in closed loop? Sorry.
kev0 is offline   Reply With Quote
Safe to flash/unmarry OFT without intake manifold? sqd Software Tuning 1 05-11-2019 03:40 PM
Safe to run a catted front pipe + CAI with no tune? Quicksilverfrs Engine, Exhaust, Transmission 6 11-06-2017 02:40 PM
Help! Tank full of E85 2017 Stock BRZ what OFT tune to use? D4FD Software Tuning 41 10-30-2017 05:06 PM
Are these e flash tunes safe? Astroboy Software Tuning 14 07-09-2017 03:14 PM
Open Flash Tablet + E85 = Safe for a STOCK CAR?? ScionFrsFan Engine, Exhaust, Transmission 55 03-13-2015 01:25 PM
