Old 09-04-2017, 04:51 AM   #1
D4FD
D4FD's Avatar
Drives: 2015 RS 1.0(Totaled) 2017-BRZHaSNoW
Help! Tank full of E85 2017 Stock BRZ what OFT tune to use?
Hello everyone,
I have a small emergency. I filled up my gas tank with E85 without knowing what OFT tune to use (Like an idiot). My car is stock aside from a catback. Shiv sent me the tunes as I was shipped an older OFT not updated with the 2017 tunes. He sent me 4 tune files. None of the info mentioned anything about UEL vs EL headers and only one tune file has E85 in the name. Hopefully someone here received the same tunes as me and knows what I should be running?
Stage 1 v3.01 K00C.bin = he said is for stock header (not sure if ok with E85, what my car is currently flashed with)
Stage 2 v3.01 K00C.bin = he said is for catted
Stage 2+ E85 v3.01 K00C.bin = he said is for catless (also reads E85 in file name)
Stage 2+ v3.01 K00C.bin = he said is for catless (I'm guessing 91-93 gas)
D4FD is offline   Reply With Quote
Old 09-04-2017, 05:24 AM   #2
Tor
Tor's Avatar
Drives: Toyota GT86
The one that says E85.
The other ones are for gasoline. He probably only sent you tunes of your header type (EL/UEL. Assume you are stock?).
The other tunes you are not running, are probaly for:
1) Stage 2 (probably a typo if he wrote catted) catless.
2) Stage 2+ catless and for better gas.
You need stg 2+ E85.
Tor is offline   Reply With Quote
Old 09-04-2017, 05:54 AM   #3
D4FD
D4FD's Avatar
Here is his email notes...they seem incomplete.
"Tune files attached. For a car with a stock header, please; use the Stage 1 tune. For a catted header, the Stage 2 tune and for a catless header, the Stage 2+ tune "
Missing info about UEL & EL and what gas to run aside from one file name with E85 but that's only for catless not stock catted
Yes I'm stock.
Old 09-04-2017, 07:35 AM   #4
Tor
Tor's Avatar
Drives: Toyota GT86
Yes I'm stock.
If you run E85 the engine won't knock, so it doesn't matter if you use the E85 tune with stock or aftermarket catted or non catted header (except for performance differences).
Old 09-04-2017, 11:51 AM   #5
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
There is no UEL or EL tunes on the V3.0 tunes. They are one in the same now. The only differences would have been subtle before anyways.
You would need what is now the Stage 2 E85 tune. Stage 2 = catted aftermarket header(will work for stock too). Stage 2+ = catless aftermarket header.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 09-04-2017, 05:09 PM   #6
D4FD
D4FD's Avatar
Update = So I went with the Stage 2+ E85 tune even though it's for catless, need to go to work so short on options.
So problem is idle is not very stable as I've driven ove 20mils now (my commute is 26miles)
I followed the basics and have been keeping it under 3500 rpm for the 20+mile trip but the LTFT at idle is still 36.XX% is this something to be concerned with? What I've read is that LTFT should be around 10% idle?
Please advise all knowing forum gods ^_^
Old 09-04-2017, 10:35 PM   #7
Turdinator
Señor Member
Turdinator's Avatar
As per your other thread, it sounds like you are still on a petrol tune. If you go into the tuning section of your OFT as if you were about to re-flash the car, to the point where you choose which tune to flash it will have an asterisk next to the currently flashed tune.
1974 TA22 Celica
2013 86 GT
Old 09-04-2017, 10:38 PM   #8
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
The differences in AVCS between EL and UEL were substantial.
Old 09-04-2017, 11:15 PM   #9
D4FD
D4FD's Avatar
Yup, double checked and definitely on the Stage 2+ E85 tune. Also now having ECL pop up. I've been just clearing with the OFT but I will get the ECL code next time it pops up as it's gone off 3 times in about 30 miles of driving
Old 09-04-2017, 11:31 PM   #10
D4FD
D4FD's Avatar
ECL is the dreaded P0171 code, so I'm running Lean, whatever that means? Might be late in the notification but I'm a complete noob, so all help is much appreciated
Old 09-05-2017, 12:09 AM   #11
Wayno
Wayno's Avatar
E85 requires 35-40% more fuel than E0, the stock rom can only scale fuel about 30% before it throws too lean. It's 99.9% likely the fuel tables in the rom haven't been scaled in the MY17 rom. You will need to post the rom here for us to check.
Old 09-05-2017, 12:16 AM   #12
D4FD
D4FD's Avatar
Rom? Do you mean the .bin tune file? Sorry I'm still learning things.
Old 09-05-2017, 12:19 AM   #13
D4FD
D4FD's Avatar
If yes, here ya go from my drive: https://drive.google.com/open?id=0B4...lhvRm9VWmFTMGc
Old 09-05-2017, 12:55 AM   #14
Wayno
Wayno's Avatar
Yep, there's minimal changes in that file compared to stock. I'm guessing shiv probably overwrote the E85 file with one of the petrol files by mistake, which is easy to do. Can you post one of the Stg2 petrol files to compare?
I should also mention it includes a stupid change he makes to stock to reduce the max LTFT at WOT from 40% to 4%.
So do not drive the car on this file, it will never not run super lean at WOT.
OpenFlash Headers in 2017 &a Tune -- success & no tune yet gskv Software Tuning 151 03-29-2018 08:10 PM
SARD Surge Tank Kit w/ ITB from TAS 2017 mav1178 Engine, Exhaust, Transmission 50 05-12-2017 10:50 PM
Anyone in Ga? and actually have a full tank RichardsFRS Scion FR-S / Toyota 86 GT86 General Forum 25 09-23-2016 05:47 AM
Whats your average MPG now in the winteRnHow far are you going on a full tank of gas? NickFRS Northwest 17 12-21-2012 11:59 PM
340 miles and one full tank later... gunmetal5 Scion FR-S / Toyota 86 GT86 General Forum 28 11-14-2012 09:32 PM
