Old 07-06-2017, 09:27 PM   #1
Astroboy
Astroboy's Avatar
Drives: None
Are these e flash tunes safe?
I am debating on whether i should get a dyno tune, or an e tune. Ever since i took off the turbo, I felt that lack of power and was considering an NA tune. Only mods still on the car are the headerback exhaust, the panel filter, and exedy stg 2 clutch but they feel like nothing without a tune. I was leaning towards an e85 tune from ft86speefactory mostly because of the price. I would like to know who is running one and how reliable it is for an e tune. If not that great, I know of this shop that does pretty good tunes on these cars but for like 300 more than the e tune
Sent from my LG-H820 using Tapatalk
Astroboy is offline   Reply With Quote
Old 07-06-2017, 09:30 PM   #2
elitegunslinger
elitegunslinger's Avatar
Drives: 2014 BRZ Limited
The fastest and safest tune is on a dyno; you could probably feel the power if you put that turbo back where it should be.
elitegunslinger is offline   Reply With Quote
Old 07-06-2017, 09:32 PM   #3
Astroboy
Astroboy's Avatar
Drives: None
Lol it blew my previous motor tho
Old 07-06-2017, 10:04 PM   #4
elitegunslinger
Why not go for a built motor?
Old 07-06-2017, 10:36 PM   #5
Astroboy
Astroboy's Avatar
Drives: None
We were going to do that where i work but I decided to put my money back in school. Did you e tune yours?
Old 07-06-2017, 11:28 PM   #6
elitegunslinger
I'm using OTS Stage 2 OFT currently; I had an E-Tune but my my supercharger failed before I was done. Kind of wished I had dyno tuned it in an hour and been done with it.
Old 07-07-2017, 08:53 AM   #7
Astroboy
Astroboy's Avatar
Drives: None
Are you running the stock headers? Also, is it an e85 tune
Old 07-07-2017, 08:54 AM   #8
Astroboy
Astroboy's Avatar
Drives: None
Sorry about the supercharger
Old 07-07-2017, 11:23 AM   #9
steve99
do you still have your ecutek cable and ecutek licience in ecu ??
still have flex fuel kit ??
Old 07-07-2017, 12:41 PM   #10
Astroboy
Astroboy's Avatar
Drives: None
Still have everything but flex fuel because i never went e85. Will the flex fuel be the route to take?
Old 07-07-2017, 12:59 PM   #11
phrosty
For NA the difference in power between your typical one-day dyno tune and an e-tune will be too small to notice. A waste of time and money.
Dyno only makes sense for NA if you're really going to dial it in over several sessions -- these are the vendors posting "200whp with just a header".
And yes, e-tune are safe . Probably safer than most dyno tunes, because they are naturally a little conservative.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 07-07-2017, 01:15 PM   #12
steve99
Were lucky on Oz as our E85 is actually 85% ethanol.
In USA it can apparently vary from pump to pump from 50% to 90% that's a little outside the range of what an E85 tune without a flex kit can cope with.
If your in an area where the ethanol percent stays between 60-90 then you generally ok with an NA car without a full flex fuel system.
but you probably still ant to be able to switch between petrol and E85 without reflashing.
The moto East guys do a 4 map switch tune that has maps for 91/93 petrol and E40-E50/E70-E85 ethanol fuels.
they are 299
http://www.moto-east.com/store/subar...oecu-tune.html
configure here
http://www.moto-east.com/store/subar...figurator.html
probably the way to go if you already have ecutek cable and licience.
full flex kit better but going to cost considerably more.
Old 07-07-2017, 01:29 PM   #13
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Get an OFT tune and you are done. I don't think there is any shop that has tested their dyno-tune so much.
Old 07-09-2017, 02:03 PM   #14
Astroboy
Astroboy's Avatar
Drives: None
Might get one from ft86speedfactory then. Does a stage 2 require aftermarket headers? I am still running the stock exhaust manifold but am running an exhaust system 2.5 in. all the way back. I also have a kn filter.
Delicious Flash & GO Tunes for ALL FORCED INDUCTION Applications - Q&A DeliciousTuning Forced Induction 748 06-18-2025 09:42 PM
Open Flash Tablet + E85 = Safe for a STOCK CAR?? ScionFrsFan Engine, Exhaust, Transmission 55 03-13-2015 12:25 PM
Custom tunes safe for track usage? Sleepless Software Tuning 21 12-23-2014 08:54 PM
CMS =FAST-FLASH= E-Tunes - Low Introductory Pricing LAST DAY! Circuit Motorsports Announcements, Contests, Giveaways 45 10-31-2014 01:24 PM
Custom tunes safe for track usage? Sleepless Tracking / Autocross / HPDE / Drifting 46 10-29-2014 08:52 PM
