Drives: 37J
Is it safe to flash to non FF tune with 18% E in tank?
Not sure if the tune is just Non FF or non E85 tune, but I need to flash back and go to the tune so I can plug my o2 sensor back in for emissions.
Let’s assume that it is non E85: E18 would be fine right? Sent from my iPhone using Tapatalk |
#2 |
Just go for a long drive and burn off some more. Should be OK with 18 anyway really.
| The Following User Says Thank You to Tcoat For This Useful Post: | why? (01-30-2020) |
#3 |
Drives: FT86
Anythong under about 30% ethanol will be fine thier is a lot of fueling adjustment and more E means more knock resistance and if you on a petrol tune it will jave low ignition advance compared to an ethanol tune
#4 |
Drives: 2013 FRS
lol, just out of curiosity, how did you figure it's 18%?
#5 |
Most fuel has 10-15e content already in it. So that would do much. Watch your fuel trims and keep from going wot till your FTs stabilize
2013 Series 10 FRS #553
#6 |
Drives: 2013 frs red
Maybe he has a gauge?
#7 |
Not likely if he is using oft. Maybe test strips
#8 |
Drives: 37J
#9 |
Do you have a flex fuel tune? If so this whole thread was for not lol
![]() Sent from my GM1915 using Tapatalk
#10 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
He had flex fuel. Needs stock tune for emissions
#11 |
Ahhh okay that makes sense.
#12 |
I've driven for about 10 miles on e85 with the stock tune when I had some issues flashing the e85 tune. Was fine. Fuel trims jumped to 20-25 percent, but I just kept the rpms low and tried to stay off the throttle. No problems, not even a CEL.
2022 BRZ Build 2013 FR-S Build |
#13 |
Drives: 2013 FR-S Argento
Just don't romp on it, keep it in closed loop and ecu should be able to compensate fine based on o2 sensor feedback.
Sent from my SM-G965U using Tapatalk |
#14 |
Drives: '14
| Safe to flash/unmarry OFT without intake manifold? | sqd | Software Tuning | 1 | 05-11-2019 02:40 PM |
| Safe to run a catted front pipe + CAI with no tune? | Quicksilverfrs | Engine, Exhaust, Transmission | 6 | 11-06-2017 01:40 PM |
| Help! Tank full of E85 2017 Stock BRZ what OFT tune to use? | D4FD | Software Tuning | 41 | 10-30-2017 04:06 PM |
| Are these e flash tunes safe? | Astroboy | Software Tuning | 14 | 07-09-2017 02:14 PM |
| Open Flash Tablet + E85 = Safe for a STOCK CAR?? | ScionFrsFan | Engine, Exhaust, Transmission | 55 | 03-13-2015 12:25 PM |
