Old 11-06-2017, 04:37 AM   #1
Quicksilverfrs
Drives: 2014 Firestorm FRS
Safe to run a catted front pipe + CAI with no tune?
Forgive my ignorance as I’m brand new to the mod scene. I recently installed a JDL high flow front pipe and a TRD Intake on my 2014 FRS. Is it safe to run my car without a tune? I was told the car might run too lean and could cause long term damage to the engine. Is that true? Thanks!
Quicksilverfrs is offline   Reply With Quote
Old 11-06-2017, 08:39 AM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
What header? Stock, I think you'll be fine, it's the bottleneck.
CAI depends. Most do all sorts of weird, some even hurting power, without a custom bit of tune work.
The Following User Says Thank You to cjd For This Useful Post:
Quicksilverfrs (11-06-2017)
Old 11-06-2017, 10:53 AM   #3
Quicksilverfrs
Thanks. I’m on stock headers and over pipe with a TRD catback exhaust. �� So I’m ok at the moment but if I get headers and over pipe this summer I definitely need a tune right?
Old 11-06-2017, 10:57 AM   #4
StraightOuttaCanadaEh
Wes
Oh for sure. If I were you, I'd get a tune right now just to optimize things. You might be missing out on a good bit of power. Probably be able to squeeze out 10-15 hp out of those.
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 11-06-2017, 11:58 AM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
TRD intake is made for the car at stock, it doesn't have to be scaled even.
You replaced the stock catted FP with an aftermarket catted FP. Dont sweat it, you don't need a tune you're fjne
The Following User Says Thank You to guybo For This Useful Post:
Old 11-06-2017, 12:28 PM   #6
DAEMANO
Time Traveller
Agreed with @guybo you won't need a tune. Also, you won't get any extra power.
Stop with the exhaust mods and get a tune (OpenFlash or ECUTek). With your current mods either will do. Importantly a tune will give you improved responsiveness a little extra power you're probably looking for. With OFT, you can run e85 on your current mods which will give you extra power and kill the torque dip.
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 11-06-2017, 01:40 PM   #7
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
Unless you are talking about passing emissions or not getting a CEL you can run any exhaust mod you want without a tune just fine. You won't get the gains of a tune with the mods but even a full header back catless system will not cause problems on the twins with the stock tune.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
The Following User Says Thank You to Detroiter For This Useful Post:
WTT Invidia catless front pipe for a resonated/catted front pipe nickmerronesucks Want-To-Buy Requests 3 05-10-2016 02:25 PM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
Catted header or catted front pipe? wilfredwong Engine, Exhaust, Transmission 5 02-09-2015 06:11 PM
Gains from aftermarket catted front pipe vs stock front pipe? Vmax911 Engine, Exhaust, Transmission 4 01-20-2014 01:42 PM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 12:29 PM
