Drives: 2017 Subaru BRZ
Oil Cooler Ducting
Hey all,
I was just wondering how you guys are getting air to your oil coolers? Seems like it's pretty sealed off behind the fog light on my 2017. Trying to find a clean looking solution. I don't want to just pop out my fog light, but I will if that's the best way to go about it. Thanks! Ps not my car but you get the point
ProCrastinationConsultant
i would replace the fake vent with a mesh vent.
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Maybe drill holes in the fake vent. Probably only matters for autox or track.
Is your oil cooler mounted directly behind there? If you haven't purchased one yet you can opt for one that mounts in front of the radiator. Temporary solution if you don't plan on going FI in the near future.
AVO Stage 2 Turbo Build Thread
https://wheelwell.com/tyler-nguyen-1...014-scion-fr-s |
Dismember
Drives: 2013 Red Scion FR-S
Yeah, weird placement for a radiator, with body blocking it. I just put mine in front of the radiator. Works great.
That area has low airflow.
| The Following User Says Thank You to CSG Mike For This Useful Post: | Ultramaroon (08-10-2019) |
Wheels for Brains
Oil cooler kits that mount in that area sometimes have their own shrouding designed to pull air from the front (e.g. Blitz, Greddy).
The HKS kit for 13-16 FRS/BRZ, which mounts in that location, actually tells you to cut holes in the bezel trim Last edited by EndlessAzure; 08-10-2019 at 06:24 AM. |
Drives: Toyota 86
http://www.ft86club.com/forums/showp...&postcount=210
You may want something similar. And air exit passage is also required.
Drives: 2005 Toyota Camry
most of the pre-assembled cooler kits will mount the radiator in front of your actual radiator.
some will have ducting, like the Blitz unit. https://www.ft86club.com/forums/showthread.php?t=99441 |
#10 |
I perfer that position myself, ducting is easy, whether is home made or comes with the kit, stacking coolers takes its toll.
Home made or AVO >
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#11 |
Drives: 2015 BRZ CWP
![]() Cut out the fog light to get the oil cooler direct air. Sent from my iPhone using Tapatalk |
| Radiator ducting | Hawk77FT | Engine, Exhaust, Transmission | 19 | 03-29-2022 09:28 AM |
| Full Air Ducting | thejevans | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 02-13-2021 02:47 PM |
| Brake Ducting CHEAP! | MR2 MK1 to FRS Newbie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 03-25-2015 11:49 AM |
| Brake Ducting/Hose Routing? | swift996 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-13-2014 04:20 PM |
| Custom Brake Ducting. | Asterisked Accolade | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 07-09-2012 09:50 PM |
