Old 03-25-2015, 12:01 AM   #1
MR2 MK1 to FRS Newbie
Drives: 2014 FRS, 1985 MR2, 2008 Yaris
Brake Ducting CHEAP!
While browsing brake upgrades, I became interested in some ones very reasonable ducting DIY guide. I also read this not too long ago and am impressed. We may be working too hard? After reading, I looked under the FRS and our 2008 Yaris. Surprise...the same set up exists on both cars. I have not tested the system, but am curious if this is well known and any before and after stories exist. Very interesting! All inputs welcome!
<www.tuneruniversity.com/blog/2011/06/ingenious-designs-oem-brake-ducts>
MR2 MK1 to FRS Newbie is offline   Reply With Quote
Old 03-25-2015, 10:49 AM   #2
Pat
Pat's Avatar
Drives: 2023 BRZ
Effective brake ducting directs a large amount of airflow to a very small, precise area of the rotor where the veins begin. From there, the air is drawn outward to cool the rotor. It does not send air to the caliper area in general.
Regardless, brake ducting is something only beneficial on a racetrack. Regardless of how hard one drives a twin on the streets, one can avoid overheating the brakes and therefore brake fade and fluid boil with proper pad selection and maintenance.
DIY: Custom Brake ducting mod w/ fog light delete, cheaper alternative(~$80 vs $650) glamcem DIY (Do-It-Yourself) Guides 13 05-13-2018 05:49 PM
BRZ Premium custom brake ducting ATL BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 02-17-2015 09:01 PM
Brake Ducting/Hose Routing? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 01-13-2014 03:20 PM
Cheap, easy brake mod! CBR600RR Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2012 07:39 PM
Custom Brake Ducting. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-09-2012 08:50 PM
