Old 05-20-2013, 02:37 PM   #1
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
Full Air Ducting
Has anyone done radiator inlet and exit ducting for ours cars? Would the aerodynamic/cooling benefits be noticeable? I understand most turbo setups may make this difficult, but could it also be used to cool the turbo better? Just thoughts.
example:
http://www.dsmtuners.com/forums/cust...ad-racing.html
1994 Plymouth Acclaim - Engine died and went to cash for clunkers
2001 Dodge Neon R/T- Hydro-locked engine and parted out
2003 Nissan Sentra SE-R Spec-V - Traded for next car
2013 Scion FR-S - Got taken out by a distracted driver while I was sleeping. Total loss.
1997 Mazda Miata - Current
thejevans is offline   Reply With Quote
Old 02-08-2021, 11:57 PM   #2
thpark93
Drives: 2016 Asphalt FR-S
Would be nice if there was more data on this. Effect in coolant temps, cooling overall, how it plays into stacked radiators (oil cooler, forced induction)...
Wondering if anyone bought this:
https://aceheader.com/86-STOCK-RADIA...OOP-p133843655
thpark93 is offline   Reply With Quote
Old 02-13-2021, 01:47 PM   #3
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Holy Necro.
Ducting does work, but this specific one will only work on a factory setup. Adding anything in front will require custom work to this, most likely changing everything about it. Better off doing custom ducting.
Data can be found all over the place for a number of cars. You aren't likely to find much change in a street driven car though, unless you have a very inefficient setup to begin with.
DustinS is offline   Reply With Quote
Full Active With Widebands? Skippman Electronics | Audio | NAV | Infotainment 47 04-22-2020 09:42 PM
BRZ Premium custom brake ducting ATL BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 02-17-2015 09:01 PM
Went full on obnoxious trippinbillies40 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 34 01-26-2014 12:35 AM
FS: GT to GTS sat nav gps upgrade full kit crimespree Australia Classifieds 8 11-05-2012 03:47 PM
Custom Brake Ducting. Asterisked Accolade Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 07-09-2012 08:50 PM
