Drives: GTS 86
Radiator ducting
All,
I am interested in getting some ducting for the radiator. Is there anyone out there that makes something like that by any chance? |
#2 | |
Imo ducting will have minimal gains over a full setup. Fan shroud kit, fans and, a radiator is what you should get. http://counterspacegarage.com/products/cooling.html |
#3 | |
Drives: GTS 86
thanks for the link
The custom ones I've seen is only a block off plate/shield on the sides to direct air towards the center instead of the sides. But that may take air away from your oil cooler depending on where it is mounted. Also look into hood scoop/extractor options to extract air.
Drives: Track preped NA FRS
Hood vents, what you need are hood vents.
Drives: 2013 Ultramarine FR-S
Hood vents are definitely a must. If you are still overheating after that, something else is wrong. Ducting would only be a bandaid. That being said. No one has a kit as they will mostly be custom as every car is set-up slightly different. They are decently ducted from the factory.
Drives: 2014 GT86
Isn't ecu tune governing engaging & rpms of fan? (IIRC there was a way to tune them in OFT). If so, i guess without modding any hardware one can get much more from very same rad, w/o any ducts, without any hood/fender vents.
There is nothing tune can do with oil overheating (except cutting power down), so that's the area you should care about/improve upon. One can improve capability of rad (not bottleneck) via ducting or hood vents .. but what's a point, if ecu tune just will engage fan later/for shorter time interval/at lesser speeds to compensate? :/ |
#8 | |
#10 | |
Drives: GTS 86
#11 | |
If you don't encounter and freezing temps drain some coolant and add distilled water. Increase the radiator cap to 1.3 bar To prevent slower driving speed heating up you can have the cooling fans run constant off a switch.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#12 |
Señor Member
OP never said he had over heating issues with coolant or oil. I am not sure why you are all mentioning oil coolers and hood vents etc.
Similar to the Ace solution, HKS Kansai do them as part of an intake setup. LINK Seems like an expensive way to go tho. I don't think it would be too hard to fab up your own out of aluminium sheet if you were keen.
1974 TA22 Celica
2013 86 GT Last edited by Turdinator; 08-02-2017 at 02:41 AM. Reason: Speeling |
#13 | |
OP what do you need ducting to accomplish?
#14 |
Drives: GTS 86
Best air flow through the radiator, and with the help of Velox bonnet vents placed in the low pressure area, achieve the best heat exhaust. Secondary benefit will be the increase in the down force. On the track or spirited driving it would be very good to get these two nailed with minimal modifications!
I had a look at the Kansai ones as well! |
| Full Air Ducting | thejevans | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 02-13-2021 01:47 PM |
| Brake Ducting CHEAP! | MR2 MK1 to FRS Newbie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 03-25-2015 10:49 AM |
| BRZ Premium custom brake ducting | ATL BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 54 | 02-17-2015 09:01 PM |
| Brake Ducting/Hose Routing? | swift996 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 01-13-2014 03:20 PM |
| Custom Brake Ducting. | Asterisked Accolade | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 07-09-2012 08:50 PM |
