Drives: Looking to buy
Magnetic drain plug in both transmission and rear differential?
I recently bought my BRZ and began learning how to drive manual on it. Let’s just say I have stalled out about 50 times within a week... I want to perform preventative maintenance for the transmission and saw that you can install a magnetic drain plug to collect all the metal shavings I’ve been creating... I want to know if you can install the same size magnetic drain plug in the rear differential as well. Wondering if someone did it before.
not playing cards
Subaru's got your back, bro. Standard equipment on the BRZ.
ThisGuyLoves86's
Drives: 2013 Scion FRS
The stock Subaru magnetic drain plug is sufficient. If you're worried, change your fluid and clean off the drain plug.
2013 Scion FRS (current car)
1991 Mazda Miata MX5 (current car) 2003 Nissan Pathfinder (R50) (current car) 2018 Lexus GX460 (current car) 2023 GR86 Neptune M6 Premium (Leased) |
#5 | |
not playing cards
If you never do anything with your trans and diff fluid, it's ok. Even when serviced, only fluid level inspection is specified. People go apeshit over transmission fluid. Meh.
#6 | |
I am just paranoid of all the metal shavings I have created since this is my first learner car. I just don’t want the magnet to be filled with shavings and not take it out and clean it. I think for the peace of mind, I’m going to switch out the fluids and put in brand new everything. Sent from my iPhone using Tapatalk |
Drives: '13 Whiteout
Seeing how the FRS and BRZ share engines is it safe to say the FRS also has the magnetic plug?
Other than some gizmos and gadgets the cars are identical and share all the same mechanicals.
Rust bucket enthusiast
#10 |
Benz Tech
Drives: 2017 BRZ Premium
Just to note, magnetic drain plug isn't going to help your clutch one bit.
Stalling has nothing to do with the inside of your transmission. Grinding gears does, but that isn't stalling. |
#11 | |
Agreed. But since this is my first manual car, the stalling and grinding gears unfortunately is what I did the first couple of days learning to drive stick... Sent from my iPhone using Tapatalk |
#12 |
not playing cards
~sigh~ Why do I even bother?
It's normal. That's what the magnet is for. Leave it alone.
#13 |
Drives: Black BRZ
#14 |
No it is real. Started yesterday. Everyday can be like April 1 on here.
| Transmission and rear differential drain plugs: Are they magnetic? | Seanzky | Engine, Exhaust, Transmission | 22 | 07-25-2018 07:55 AM |
| Magnetic Drain Plugs come stock for Transmission/Differential? | razahuss | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 07-03-2018 08:42 AM |
| Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? | tracerit | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 20 | 01-04-2016 07:36 PM |
| Best magnetic drain plug? | FR-Sizzle | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 09-28-2015 01:07 PM |
| Magnetic oil drain plug, effective? | BRZPDX | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 7 | 02-16-2013 11:59 PM |
