Old 03-31-2019, 05:50 PM   #1
jc7993
Drives: Looking to buy
Magnetic drain plug in both transmission and rear differential?
I recently bought my BRZ and began learning how to drive manual on it. Let’s just say I have stalled out about 50 times within a week... I want to perform preventative maintenance for the transmission and saw that you can install a magnetic drain plug to collect all the metal shavings I’ve been creating... I want to know if you can install the same size magnetic drain plug in the rear differential as well. Wondering if someone did it before.
jc7993 is offline   Reply With Quote
Old 03-31-2019, 05:55 PM   #2
Subaru's got your back, bro. Standard equipment on the BRZ.
DarkPira7e (04-01-2019)
Old 03-31-2019, 06:05 PM   #3
jc7993
I’m the type of guy that always wants to upgrade with aftermarket parts. So would just 1 magnetic drain plug be sufficient in catching most of the metal shavings?
Old 03-31-2019, 06:15 PM   #4
Prodigalson
ThisGuyLoves86's
Prodigalson's Avatar
Drives: 2013 Scion FRS
The stock Subaru magnetic drain plug is sufficient. If you're worried, change your fluid and clean off the drain plug.
2013 Scion FRS (current car)
1991 Mazda Miata MX5 (current car)
2003 Nissan Pathfinder (R50) (current car)
2018 Lexus GX460 (current car)
2023 GR86 Neptune M6 Premium (Leased)
Prodigalson is offline   Reply With Quote
Old 03-31-2019, 06:33 PM   #5
They catch 99.9997% of the iron stuff. The brass/bronze particles from the blocking rings float around but they don't hurt anything.
If you never do anything with your trans and diff fluid, it's ok. Even when serviced, only fluid level inspection is specified. People go apeshit over transmission fluid. Meh.
Old 04-01-2019, 09:57 AM   #6
jc7993
I am just paranoid of all the metal shavings I have created since this is my first learner car. I just don’t want the magnet to be filled with shavings and not take it out and clean it. I think for the peace of mind, I’m going to switch out the fluids and put in brand new everything.
Old 04-01-2019, 11:36 AM   #7
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Seeing how the FRS and BRZ share engines is it safe to say the FRS also has the magnetic plug?
TommyW is offline   Reply With Quote
Old 04-01-2019, 11:42 AM   #8
Other than some gizmos and gadgets the cars are identical and share all the same mechanicals.
Old 04-01-2019, 11:48 AM   #9
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I can confirm, my 2013 was covered in metallic sludge the first couple fluid changes in the diff and trans.
Old 04-01-2019, 11:57 AM   #10
maslin
Benz Tech
Drives: 2017 BRZ Premium
Just to note, magnetic drain plug isn't going to help your clutch one bit.
Stalling has nothing to do with the inside of your transmission. Grinding gears does, but that isn't stalling.
maslin is offline   Reply With Quote
The Following 2 Users Say Thank You to maslin For This Useful Post:
DarkPira7e (04-01-2019), Tcoat (04-01-2019)
Old 04-01-2019, 12:42 PM   #11
jc7993
Agreed. But since this is my first manual car, the stalling and grinding gears unfortunately is what I did the first couple of days learning to drive stick...
Old 04-01-2019, 01:20 PM   #12
~sigh~ Why do I even bother?
It's normal. That's what the magnet is for. Leave it alone.
maslin (04-01-2019), Tcoat (04-01-2019)
Old 04-01-2019, 03:15 PM   #13
oaroyale
Drives: Black BRZ
I think this has something to do with today being April 1st.
oaroyale is offline   Reply With Quote
The Following 2 Users Say Thank You to oaroyale For This Useful Post:
bcj (04-01-2019), Ultramaroon (04-01-2019)
Old 04-01-2019, 03:30 PM   #14
No it is real. Started yesterday. Everyday can be like April 1 on here.
maslin (04-01-2019), Ultramaroon (04-01-2019)
Transmission and rear differential drain plugs: Are they magnetic? Seanzky Engine, Exhaust, Transmission 22 07-25-2018 08:55 AM
Magnetic Drain Plugs come stock for Transmission/Differential? razahuss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 07-03-2018 09:42 AM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Best magnetic drain plug? FR-Sizzle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-28-2015 02:07 PM
Magnetic oil drain plug, effective? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 02-17-2013 12:59 AM
