Old 07-18-2018, 07:17 PM   #1
Seanzky
Drives: Slow
Transmission and rear differential drain plugs: Are they magnetic?
So every car I've owned, I've always changed the engine oil, transmission fluid and rear differential oil after the break-in period. I'm not sure how well the 86's fluids hold up after break-in but I figure I'll keep with what I've always done anyway since it can't possibly hurt except maybe a little in the wallet.
My question is, does the drain plugs for the transmission and rear diff come magnetic from the factory or should I upgrade both? Obviously, I can't check because I'll end up draining them.
I've tried watching videos but I've seen some showing the transmission's drain plug not having one but the read diff having one and vice versa. So, I'm a little confused. I have the 2018 Toyota 86 GT Black, if that makes a difference. I'm not sure if Toyota/Subaru has changed from previous year models or not.
Seanzky is offline   Reply With Quote
Old 07-18-2018, 08:29 PM   #2
NRXRaptor
they are magnetic. take them out and see for yourself
NRXRaptor is offline   Reply With Quote
Old 07-18-2018, 08:36 PM   #3
Seanzky
Drives: Slow
So both are magnetic???
I saw the FT86SpeedFactory video where Tomas upgraded the transmission drain plug with a magnetic one on his 2017 and not the rear diff because it was already magnetic.
I can't take mine out to check for myself until I'm ready to change them out in about 40-50 miles or so. Before I do that, I'd want the magnetic drain plugs in hand already if I do need to upgrade them. Otherwise, I'd be doing the work twice not to mention buying more gear oil. Hehe.
Old 07-18-2018, 08:51 PM   #4
humfrz
It's my understanding that they both are magnetic (2013 FR-S).
I will be able to confirm that when and if I ever reach 50,000 some miles (maybe in another 5 years) -
humfrz
Old 07-18-2018, 08:53 PM   #5
Seanzky
Drives: Slow
humfrz
Hahaha. Thanks, @humfrz. I appreciate it. I'm looking to change out the fluids by next week, though. I'll take yours and @NRXRaptor word for it and not order those then.
Old 07-19-2018, 12:03 PM   #6
celek
Resident Gear Head
celek's Avatar
I can confirm the trans is magnetic I just pulled it a few weeks ago
2013 BRZ
celek is offline   Reply With Quote
Old 07-20-2018, 05:45 AM   #7
scottman
scottman's Avatar
Drives: 13 mt fr-s
Can confirm the diff drain plug is also magnetic.
scottman is offline   Reply With Quote
Old 07-20-2018, 05:54 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Makes me think what aftermarket magnetic ones were made for then.
Old 07-20-2018, 10:30 AM   #9
nico_rsx
Drives: BRZ 2017 Pure Red, MT
To make money?
nico_rsx is offline   Reply With Quote
Old 07-20-2018, 10:36 AM   #10
The drain plug is sorrta standard across many different makes and models of cars. Many of them are not magnetic so an aftermarket one makes sense. Just because they fit our cars doesn't mean they are needed.
Old 07-20-2018, 11:12 AM   #11
They are both magnetic from the factory.
Old 07-20-2018, 11:56 AM   #12
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Yep! and you're gonna find some nice sludge on both of them.
MCTeeJ is offline   Reply With Quote
Old 07-20-2018, 02:20 PM   #13
humfrz
Bigger and stronger magnets? -
humfrz
Old 07-20-2018, 02:36 PM   #14
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Gimmick item.
Current DD: M235i
8RZ is offline   Reply With Quote
Changing Differential and Transmission fluid Seabass47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 02-20-2017 12:21 AM
Changing Automatic Transmission Fluid euthqt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 06-01-2016 03:16 AM
Different brand rear fluid changing torque bias? zooki Engine, Exhaust, Transmission 1 09-06-2015 10:13 PM
Differential and Transmission Fluid Swap with Red Line Oil - 2013 Subaru BRZ JPxM0Dz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-05-2013 05:12 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
