Old 06-09-2013, 04:30 PM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve?
I'm trying to spend an extra $20 to get free shipping from FT86 Speed Factory and the Greddy Drain Plug would work, but I've always been intrigued but the Fumoto Drain Valve (which they don't sell). The Greddy Magnetic Plug is more functional, but I've always hated loosening drain plugs during oil changes...
tracerit is offline   Reply With Quote
Old 06-09-2013, 05:59 PM   #2
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
+1 for Fumoto valve for easy oil changes. Very functional too!
tintumz22 is offline   Reply With Quote
Old 06-10-2013, 10:29 AM   #3
Bullnettles
Drives: Scion FR-S 2013
Just installed the Fumoto this weekend. Seems like a quality piece, and people have been using them for a while now. No leaks. I will miss the magnet, but maybe every few oil changes, I'll throw a plug with a magnetic pickup on it...
Bullnettles is offline   Reply With Quote
Old 06-10-2013, 03:46 PM   #4
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
I installed Fumoto valve on my first oil change this past weekend as well, I bought the security clip they sold for $1 just to be safe.
Myv is offline   Reply With Quote
Old 06-10-2013, 04:03 PM   #5
Bullnettles
Link? Didn't see a clip when I bought mine...
Old 07-06-2013, 05:59 PM   #6
j2digit
j2digit's Avatar
Drives: 2000 Integra LS, 2013 FRS Firestorm
+1 for the fumoto valve. no more oily hands after switching. get the hose as well for an even faster cleanup cause you can directly drain to your bottles now too.
"Power is nothing without Control"
j2digit is offline   Reply With Quote
Old 07-07-2013, 12:33 AM   #7
PANDA86
Old School Status
Drives: .
any pics of fumoto on any FRS/BRZ?...
PANDA86 is offline   Reply With Quote
Old 07-07-2013, 01:07 AM   #8
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
To the OP.
This is an older Thread with almost the same Title.
help me decide: Fumoto Valve or Greddy MagDrain
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 07-07-2013, 01:15 AM   #9
TemeCal
Drives: 86
+1 for fumoto. I run them on all my vehicles, never had an issue with them.
TemeCal is offline   Reply With Quote
Old 07-15-2013, 09:46 AM   #10
pgeist
pgeist's Avatar
Drives: 2013 Black BRZ Limited 6MT
FUMOTO, no brainer +1
Zeta Stage 2 Drop In + Red Silicone Tubing || Zeta SS Cat Back || DC Sports Cat-Delete Front Pipe || Torque Pro + MiniOBD Bluetooth || Fumoto F-108 Drain Valve || Konig Daylite Gold 17x7 +40 14.2lbs || Anarchy Motive Shift Knob
Future: Catted header, OEM Audio+
pgeist is offline   Reply With Quote
Old 07-15-2013, 10:08 AM   #11
Wo6M
Keep Calm And Drift On~
Wo6M's Avatar
Drives: Scion FR-S WhiteOut 6 Speed Manual
Where can we order on of these :0
As a technician at Lexus , we would love if someone came in with this ahaha
2013 Scion FR-S White Out Six Speed Manual
Mods:
Wo6M is offline   Reply With Quote
Old 07-15-2013, 10:29 AM   #12
Turbowned
Turbowned's Avatar
Welp, I went with the GReddy plug. I'm not too lazy to turn one bolt once every 6 months or so.
Old 03-11-2015, 12:54 PM   #13
Tmo
Drives: 2013 FRS
This is a really old post, but I just now had an epiphany. I am more of a computer geek than a real gear head so please excuse my nerdyness. I personally wouldn't want to exchange function for the ease of changing my oil. I do however believe in finding a way
The idea I had was to insert a magnet around the drain plug. If you have an old hard drive laying around, this should work perfectly and would be about the same strength I would think. A hard drive has 2 magnets attached to a metal piece in the shape of about a half circle so you could surround the valve. I'd leave the metal on but you can take it off I suppose. Might make it harder to remove though. I'd throw a little grease on it to prevent corrosion too. The metal should get stuck to the bottom of the pan and should be removed when you drain the oil (provided you removed the magnets). I'm sure that there are other magnets that would serve the purpose, but this is the first thing that I thought of when looking for a roundish magnet to surround the valve. Any thoughts about this or do you see any problems with this setup??
Tmo is offline   Reply With Quote
Old 03-11-2015, 12:59 PM   #14
gramicci101
Off Topic
A similar idea is already being produced. Look into a product called filtermag.
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 05:18 PM
Magnetic oil drain plug, effective? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 02-16-2013 11:59 PM
Greedy Magnetic Drain Plug USMC -FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-10-2013 06:04 PM
GReddy Magnetic Drain Plug BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 01-05-2013 10:19 PM
Greddy Neodymium Magnetic Drain Bolt Subaru FRZ Scion FR-S Toyota GT86 any reviews? FRS-HHH Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 12-22-2012 04:55 AM
