Old 06-26-2016, 02:04 PM   #1
RedFR-s
Builder/Driver/Enthusiast
RedFR-s's Avatar
Drives: 2013 FR-S 6MT Turbo Firestorm
Transmission Grinding Noise
I have a grinding noise when the clutch is engaged. It happens N-1-2-3-4 but is is 5-6. I replaced the clutch, release bearing, and tranny fluid. Noise is still there. I took a video and will attach when I have a chance to upload. I though I might be a synchro or another bearing in the transmission but not sure what. Tranny fluid had no metal flakes and looked as clean or cleaner from other posts on here.
Before the comments come in I have searched and haven't seen this issue yet.
Car now has exedy stage 1 clutch, fa20 club turbo, and AEM meth injection. Noise started 1 year after turbo on stock clutch.
Andy
1977 Triumph Spitfire 1500 - New Project
2013 Firestorm FR-S 6MT Turbo - Sold
2013 Honda CBR 250 Repsol- Toy
2017 Toyota Tacoma - The Rig
RedFR-s is offline   Reply With Quote
Old 06-27-2016, 12:06 AM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Post up the clip and we'll give it a listen.
Old 06-27-2016, 01:55 AM   #3
humfrz
My crystal ball tells me it may be a bad pilot bearing .......
humfrz
Old 06-27-2016, 08:46 AM   #4
RedFR-s
RedFR-s's Avatar
humfrz
Would the pilot bearing not make noise even when the clutch was disengaged?
Unless the forces of the clutch are causing it...
Andy
Old 06-27-2016, 10:50 AM   #5
RedFR-s
RedFR-s's Avatar
Updated with video link.
Andy
Old 06-27-2016, 01:05 PM   #6
Ultramaroon
not playing cards
Very loud neutral rollover. What do you hear when it's in gear? Can you have someone take a clip of you rowing through the gears?
@humfrz was teasing because without a clip we need his crystal ball. It was wrong this time.
Please elaborate on how it sounds for each gear. Your OP is unclear about that.
Old 06-27-2016, 01:55 PM   #7
RedFR-s
RedFR-s's Avatar
Sorry for the limited video, its very illegal to run a phone and drive in Ontario ($500 and 2 points). It sounds identical through 4th, its gone in 5th, and low rpm in 6 sounds different still.
I'm a but nervous to drive it. I've sourced a used tranny with 2k km on it to swap it out while I rebuild this one.
Andy
Old 06-27-2016, 02:03 PM   #8
humfrz
Yep, you're right!
After I turned my crystal ball "right side up" it said this:
"When the clutch is disengaged, the transmission’s input shaft and the engine’s crankshaft are rotating at different speeds. The pilot bearing allows for this difference. This is why a faulty pilot bearing makes its most noise when the clutch pedal is completely depressed and the clutch itself is completely disengaged. It’s located in the center of the crankshaft flange or flywheel."
OK, back to you @Ultramaroon.
humfrz
Old 06-27-2016, 02:12 PM   #9
I will be in Cambridge for a few hours tomorrow night if you want to swing by and we can take another recording and I can give my 2 cents worth in person.
Just holler if you want a hand and I can PM you the address.
Old 06-27-2016, 02:15 PM   #10
RedFR-s
RedFR-s's Avatar
I feel honored to be getting help from the lengendary @Tcoat in person!
Andy
Old 06-27-2016, 02:17 PM   #11
humfrz
Ah .....ha ........ Tcoat is willing to make a house call (road call) ........
humfrz
Old 06-27-2016, 02:30 PM   #12
humfrz
Gonna be in town anyway so easy. Wife is going to the grandson's graduation but they can only take 4 people. Just planning on chilling with the younger one so I will now introduce him to the wonderful world of car diagnostics.
Old 06-27-2016, 03:10 PM   #13
humfrz
Yes, but, dad, where is the dyno, laptop, OBDII cable and tuning program ...... ??
Oh, so you think you are going to figure it out with that long screwdriver stuck up to your ear .......
OK, give it to me ..... I'll give it a try.
DANG! ...... no matter where I put the tip of the screwdriver on this engine ..... it sounds like it's about to fly apart .....
@RedFR-s ..... I suggest you sell this POS before it completely comes unglued....
Tcoat jr is done here!
humfrz
Old 06-27-2016, 03:16 PM   #14
humfrz
Grandson!
Son couldn't even tell you what make it is, has never touched a wrench and at 32 years old has never driven a mile in his life.
I am ashamed.
Grinding noise in neutral WGMGR Issues | Warranty | Recalls / TSB 28 04-12-2018 02:22 AM
Grinding noise when shifting into 4th wise345 Issues | Warranty | Recalls / TSB 4 04-19-2016 11:53 AM
clutch grinding noise BoxerBlock88 Engine, Exhaust, Transmission 13 11-14-2015 06:12 AM
Transmission Grinding Into 6th Mister Issues | Warranty | Recalls / TSB 13 11-12-2013 10:06 AM
Grinding noise? frs10 Issues | Warranty | Recalls / TSB 7 09-20-2013 10:57 AM
